TVDB are updating their site. Their site currently has a number of bugs that have broken the TVDB scraper and any add-on that relies on TVDB data. TVDB are working to rectify the problems.
Xbox?
Hi all
Will xbox (original) recognise external hard drive plugged in direct rather than via a pc?
Thanks in advance
JS
js72 Wrote:Hi all
Thanks in advance
JS
for all your xbox question you can go here bro, as xbox is not supported here anymore.
Link: http://www.xbmc4xbox.org/
Only up to 4Gb - ie a memory stick. Internally up to 2TB can be installed. But NAS is by far the best thing to use.
But yep get over to xbmc4xbox - good bunch over there Wink
  • 0 Vote(s) - 0 Average
Xbox?00
