Weird, I refreshed my svn last night, but refreshed again just now and now it works but still shows the same version.
Whatever, it works... hooray!
MacMini 2.3gHz i7, OS X 10.13.6
Running Kodi 18.9
donabi
Senior Member
i have to set the systemlanguage to english.
as long as it set to german, no text will appear. (and the babelfish translation-option has to be disabled)
My bad. I had updated the addon by zip but when checking by FTP some files had not been updated. Did that and now the little video icon appears so I can now access Sky Weather reports for the UK. Unfortunately the weather reporter sounds like Max Headroom lol. I have a 20 meg wired connection so I need to see if the problem is with Sky.
I installed this from zip as usual, into settings to use this plugin instead of the default weather view, restarted xbmc, and even though this plugin is selected in weather settings, the display i'm getting is the default one?
Any ideas as to what i need to enable or do to get this nifty plugin working on my set-up?
Thanks guys
