I hope I'm not off-topic with this but I've spent the last week with my HiMedia Q5 4K3D. It's not as out-of-the box ready as they say, but once you get it going,
it works really well. At least, that's been my experience. You see, I was looking for a player that supported full-quality BD-rips (from my personal collection). I
bought 12TB of space and another 12TB of archive drives to manually back my files up. It's a little expensive but I don't care about that. I wanted to have
full BD quality without having to deal with a shelf for my movies, unskippable commercials and my girlfriend misplacing/scratching my discs. I have a Macbook Pro
to which I attached my Cineraid enclosure with two 6TB Western Digital Green Drives (in RAID 0 configuration, they put out almost 400MB/s -- perfect for my needs).
My
HiMedia Q5 supports Dolby TrueHD, DTS-MA AND 3D MVC ISO's! The trick is figuring out how to get them
to all play nicely.
So, here goes. Here's what you'll need and how you'll have to use it to get your HiMedia Q5 4K3D running:
HiMedia Q5 4K3D - The most recent European Quad Core version:
Update It's Firmware to whatever the most recent version is as they usually provide great improvements
Install the HiMedia Wrapper (
http://www.mediafire.com/download/73ydkv...rapper.apk. )
This allows the external HiMedia player to run the movies which gives you Dolby TrueHD and DTS-MA as
well as 3D MVC ISO Support (Full 3D -- not htbab, sbs, etc.)
- DTS-MA encoded movies work fine as MKV's (haven't tested in ISOs but I'm sure they work there, too... feel free to test for yourself)
Dolby TrueHD movies worked in ISOs for me (I downloaded a free app called Aurora Bluray Copy as I'm on a Mac. It'll extract a bluray ISO)
On my machine, Dolby True HD movies seem to jitter/stutter when you try to play them back from a MKV file. Others have reported positive results
with Dolby TrueHD MKVs but that wasn't the case for me. I'd recommend running a test on your system before committing to one or the other.
In order for 3D ISO settings to work, your AVR (home theater receiver) has to pass through the HDMI signal
if you have any kind of processing on or, even, an 'auto' setting, the
3D WILL NOT WORK -- NO VIDEO PROCESSING
ONLY PASSTHROUGH!
- Now, for my Mac users, you'll notice that finding your Mac over the network with the Q5 will be a spectacular
pain in the butt. This was my issue, too. Long story short: SMBUP It's a free app that will allow you to share
your designated media drive(s) with your Q5 (and, I'm guessing, other HiMedia models).
Following the instructions at the link below, I was able to get my SMB up and running in no-time flat!
( http://www.tweaking4all.com/os-tips-and-...x-smb-fix/ )
- You'll need to adhere to file naming structure. Otherwise, those fancy skins (Aeon Mq6) with the bluray covers won't work properly,
and the 3d functions may not work either.
For example:
Moonraker (1979).bluray.mkv
San Andreas (2015).bluray.3d.iso
The Rock (1995).dvd.mkv
You can find more info on how Kodi works with file names here: (
http://kodi.wiki/view/Naming_video_files/Movies )
- Last but not least, the remote. I have two Logitech Harmony remotes (a harmony smart control with a hub and a 650. Both work with the
HiMedia box and Logitech's customer support suggests all their remotes do. I love my Harmony Smart control
http://www.amazon.com/Logitech-Harmony-C...B00BQ5RYI4 ) as it comes with an IR blaster
in addition to the ones built into the hub itself. Since I have a projector, it's weird to point the control off to the side of the room
instead of at the tv or where ever else I want. This lets me do that and it's compatible with everything. Seriously, one time,
I pointed it at my mother and hit mute -- worked..
Anyways, I hope this is helpful to others as I, myself, was up until recently a newbie at this and would have LOVED to find this kind of
step-by-step tutorial. Please feel free to ask questions about the HiMedia Q5 and I'll help out however I can!
