2015-08-18, 09:34
I tested a few things already,
some works fine, and some of them I didn't success to work with,
for example the smartshortcut option.
I Added to my overrieds.xml:
Now I choose "Choose shortcut" or "choose widget" and I see "Smart shortcut" - but they both empty.
also in the choose shortcut button, the smart shortcut is the only item now (all the rest dissapeared)
what i'm doing wrong ?
http://i.imgur.com/o6R7mRg.png
http://i.imgur.com/1n1QD52.png
(after I click enter in both images- they show an empty list)
this one:
Is working fine.
Sorry If I miss something obvious, I am checking it very quickly for now...
Other Stuff:
currently I use script.skin.info.service by Phil for some thing I will glad to see in your script instead.
1. http://i.imgur.com/HdwMLaN.jpg - cdart for moviesets [Set.Movie.%d.Art(discart)]
2. AudioLanguage of movie, which return: ENG \ ITA \ RUS or something simillar according to the audio tracks
3. Artist.Albums.Count - to count the numbers of albums for artist
and more things from that addon will be great, I want to use few scripts as possible.
4. As I requested before, to create "smart background browser" that I can use from skinshortcuts, for exmaple, being able to add menu "youtube" add assign to it the Fanart from the addon as a background.
5. as I write this, I get scripts error from the script, and also from extendedinfo which says invalid ID and more stuff, ill post debug log later: http://pastebin.com/7NAWsT71
maybe unicode errors, or the fact i'm using mysql server... ill check it out later.
many thanks
<groupings>
<shortcut label="Smart Shortcuts" type="32010">||BROWSE||script.skin.helper.service/?action=smartshortcuts</shortcut>
</groupings>
<widget label="Smart Shortcuts" type="32010">||BROWSE||script.skin.helper.service/?action=smartshortcuts</widget>
this one:
<widget label="Widgets" type="32010">||BROWSE||script.skin.helper.service/?action=widgets&path=skinplaylists,librarydataprovider,scriptwidgets,extendedinfo,smartshortcuts,pvr,smartishwidgets</widget>
Other Stuff:
many thanks
