2015-10-02, 09:50
(2015-10-02, 04:28)jurialmunkey Wrote: Is it possible to have the colour swatches that are included with the skin be copied to addon folder also?
This would ensure a single path whilst still being able to include pre-generated swatches with the skin.
Also, is it possible to have a swatch generated when creating a custom colour in the dialog?
Latest Git should include your request:
1) Color swatch PNG files will be copied by default to the addons folder AND skin folder (if custom colors used)
2) Color swatch is also generated when a manual color or opacity is set
The only problem is Android because of the missing PIL module. I coded it that the script won't crash when the PIL is missing but it won't be able to generate the swatches.
