2015-10-26, 04:36
(2015-10-26, 02:48)marcelveldt Wrote:(2015-10-25, 14:26)wyrm Wrote: First, you don't have a recommended Albums/Songs widget, you do on the other hand have various Recentxxx Albums/Songs which is great. Second, all of the Recentxxx Album/Songs widgets takes the user to the album listing instead of playing the songs as service.library.data.provider does.
Could we please have a widget for recommended Albums/Songs and could we also get an additional parameter to select if songs are played or displayed.
The albums widgets will now default to play instead of browse (with optional param to override)
Also added recommended albums and songs widgets.
Note that the first load can take a while as it needs to build a cache. After that it will be quick.
See updated readme
Marcel,
Just tested it and it works perfectly. Good job, thanks mate.
Wyrm (AppTV)
