2015-11-06, 10:41
(2015-11-06, 10:28)marcelveldt Wrote: This one is very classy but for ome users maybe not enough colors ?Might be difficult to display properly if you have one container size and varying numbers of colors in each color.xml?
Idea that just popped into my head: Maybe it's a good thing if you can have multiple color profiles/schemes.
So you can have multiple color.xml files and select from one ?
For example "blue tints" will show all blue related colors etc
Something I should consider coding or not that great idea ?
I like the looks of the color table with 500+ colors, but for my purposes the smaller color table (~100 colors) has all of the ones I need. Like you say though, some will likely want more.
Would it be possible to pass the header label to the script when calling the color picker? Something like...
RunScript(script.skin.helper.service,action=colorpicker,skinstring=highlight,label="Header label")
I work around this with a variable that displays the appropriate header label based on a skin setting.
Thanks again for the script, it opens up so many opportunities.
