2016-05-23, 18:12
(2016-05-04, 09:15)Mike_Doc Wrote: Gotcha, I wanted to use it differently, my busy spinner at the moment is a single .png with a rotate on it so in effect it is animated by the control not by the number of pngs, so it would be an image not a multiimage control. I guess I'll have to design some new spinners before I can build this in? I'll code it some the existing is used when path,none and then use multiimage when !path.none.
If you want I can add in an extra check for png file sin the root folder.
