2016-05-23, 18:57
(2016-05-16, 18:34)tymmy Wrote: Kodi does not exit or completly close.
I updated to jarvis 16.1 in early april and I am using madox from the last week in april. I am using windows 10. Recently Kodi was not closing completely on exit and had to manually close the program.
After watching it for a couple of weeks since it was random, I found this was happening only when I updated my music database. I have 3 systems running and it is happening on all 3 systems. I have updated Movies and no problem
closing kodi. It will always happen after updated music. It will not happen if there is no update, only when a change is made (album added or nfo created), So running the update scan is not the problem. Not even sure if this is a Kodi or skin problem. Hopefully someone
can get me looking in the right direction for some help. Here are the lines when it wont close. If that's any help
Thanks for the catch, I've just fixed this on Git. It will be on the repo soon.
You can manually download the updated version from Git but in that case make sure to manually unpack the zip file and overwrite into the addons folder in Kodi, do not install the zip directly in Kodi...
https://github.com/marcelveldt/script.sk...master.zip
