2016-12-02, 22:23
(2016-12-02, 10:11)Mike_Doc Wrote: I know it's not your scripts, but I'm on a recent nightly on Win 10 and most of the time updates fail to install, just now on startup all your scripts failed to auto-update, they generally work when done manually but the lastest cache on is just 'update failed'
Any ideas why this is happening? as I said I know it's not your scripts but maybe you have some insight into the install process?
I think this happens because I'm pushing updates very frequently atm. In some cases I have just uploaded a new version on the repo and it's still syncing on the servers.
Kodi in that case grabs an incomplete file on the server. It's a timing issue if you ask me.
I think it will work correctly if you try to install again at a later time.
