2017-02-03, 10:03
I am using the latest beta of the addon from your repo with Braz's Mimic 5 skin and it works great thank you so much.
Just wondering if it is possible to set the widgets to preload and then update on a schedule rather than loading the first time the menu item is selected. I have my Kodi set up on multiple Pis so they are left on most of the time with a cron reboot during the night. It would be nice if the widgets were preloaded and updated on a schedule, if its possible or maybe this is the behaviour and my set up isn't working?
Also just curious if there is an issue displaying favourites, I use a network share for my favourites and have noticed that the favourites widget I have setup never loads even though my favourites are selectable via a menu link. Maybe an issue with the widget trying to access the data before the share is available?
Any thoughts would be great,
Thanks,
Shane
Thanks,
Shane
