2017-04-30, 15:14
Quote:Brian Fritz
I do, but the response from the origin doesn't match the attribute format currently used. So it might be time to change the overall XML response to a more standardized element structure.
Marcelveldt:
Don't know what this exactly means, but if you use XML instead of JSON you get all the rotten tomato ratings. Not sure if this is a permanent change and if it is something you can easily change in your code.
