2017-10-10, 15:18
(2016-11-29, 16:39)marcelveldt Wrote: If an exiting thumb esists in the Kodi database, that entry is always prefered. If you enable to grab artwork from local folders (in the addon settings) it will use that data. Only if there are no images locally and if it's enabled it will use the scraper to get the images.
You can check whatever it collected if you press the contextmenu. Also note that I fixed a bug yesterday where the local image was never getting overwritten by the selected image. And another note is that the Kodi image system can sometimes confuse you if the same filename is replaced by another image.
It maybe sounds crazy but using the online sources (not saving locally) works best. The image is in that case also cached locally so it really doesn't matter.
I am having a problem that for some shows I have content in an /extrafanart folder.
It never loads the images in this folder.
I noticed in the above post it was stated that for it to do this I must select the option "to grab artwork from local folders (in the addon settings) " I do not see this option anywhere. Where should it be? (When I look at the Skin Helper Service Addon it does not give me an option to configure anything, using version 1.1.23)
