2018-05-06, 10:24
(2018-05-06, 00:34)GriffeyJuni0r Wrote: New version works great!Thanks.
One suggestion would be for a few additional ffmpeg options:
- It would be great to allow users to pick the output container and codecs (I personally prefer using MP4's with h264/AAC instead of fls files).
- Given the many many arguments ffmpeg accepts, it might be cool to add an 'Add Custom Argument' option. For instance, iMovie only accepts MP4 files with the yuv444p pixel format, so I usually add the "-pix_fmt yuv420p" argument to any recordings.
version 0.0.50
- ffmpeg args / extension
- post-processing command
Have a try with this.
There are many stream types that fail with anything other than a simple ts transport stream container.
Many of the reformatting options overload your cpu too.
So don't come crying to me if you add anything in there and your recordings don't work.
The post-processing command splits the string by spaces for the subprocess command so you shouldn't need quotes around the paths.
Have a look at the code for details on how it works.
https://github.com/primaeval/plugin.vide...abd08ef1b9
I'm sure this will fail for some combination of operating system and unicode.
