2018-09-22, 22:25
Primaeval....
I did all the set up again. But using the a new ffmpeg found in the other link you posted ....int's an arm64_v8a_full. I did finally pick this since running Droidinfo on my Shield it's showing V8a. Not sure if they changed the arm cpu arch with newer Shields.
Anyway after full set up, I was still getting an error message. However with debug settings, I'm getting a this text file below. This look similar to what I get on my pc while running ffmpeg thu command line to copy a stream. Can you take a look at this stderr.txt uploaded into paste bin here?
It seems ffmpeg is running fine. But why the error message? and why recorded file is 0 bytes? Do we have to wait until the end of the recording to get the full file?
The log itself showing the error is below...Look at the error at 14:28.
Thanks again for looking into this.
