Release IPTV Recorder
(2018-12-17, 18:19)Big2hd Wrote:
(2018-12-17, 10:12)primaeval Wrote:
(2018-12-17, 02:50)Big2hd Wrote: Yeah, that's the first thing I did cause I had no clue lol, but just in case Downloaded both versions(arm64 btw but according to article I can still use arm if wanted to) unpacked and copied contents to an external drive. This where my problems start. In settings under Jobs and Rule, it is asking for "ffmpeg.exe" but the zip/tar only contains ffmpeg file, which I added the .exe extension and still didn't work. Is there some other setting I should be using the file to point it?
 You don't need to rename it. Just unzip it and point to the unzipped ffmpeg file.
The Setting does say "ffmpeg exe" rather than ffmpeg.exe. Maybe I should have just said "ffmpeg program".
I know it does work on a Shield because I've got one.
@nashnash has one of the later models than mine and he used arm64_v8a_full.
2769634 (post)
His problem was needing to turn the Settings \ Debug \ Debug off again.
2769691 (post)
There are more posts about the Shield in this thread that might help.
2767246 (post)
Ah I see so ignore the .exe thing gotcha, still giving me "ffmpeg exe not found" no matter what version I use. FFmpeg Debug option doesn't even give me log so yeah. Maybe Kodi log will point in the right direction. gonna set up my Windows machine just to see if I'm just not missing something general here.  I use SPMC fork so maybe that is a problem too gonna RC 18 a whirl while I'm at.  Looked at posts you gave I just don't see my issue in there.
 I expect it is SPMC. Try Kodi on the Shield.
SPMC still uses Jarvis. I haven't tested IPTV Recorder in Jarvis or SPMC.
  • 4 Vote(s) - 5 Average
IPTV Recorder - by primaeval - 2018-03-22, 12:03
RE: IPTV Recorder - by locoguano - 2018-03-23, 04:56
RE: IPTV Recorder - by primaeval - 2018-03-23, 09:53
RE: IPTV Recorder - by locoguano - 2018-03-23, 14:18
RE: IPTV Recorder - by primaeval - 2018-03-23, 14:23
RE: IPTV Recorder - by primaeval - 2018-03-23, 15:50
RE: IPTV Recorder - by coremailrx8 - 2018-03-23, 17:43
RE: IPTV Recorder - by primaeval - 2018-03-23, 18:03
RE: IPTV Recorder - by primaeval - 2018-03-23, 18:15
RE: IPTV Recorder - by ray2301 - 2018-03-23, 18:56
RE: IPTV Recorder - by primaeval - 2018-03-23, 21:24
RE: IPTV Recorder - by primaeval - 2018-03-23, 21:41
RE: IPTV Recorder - by ray2301 - 2018-03-24, 01:41
RE: IPTV Recorder - by primaeval - 2018-03-24, 08:57
RE: IPTV Recorder - by primaeval - 2018-03-24, 17:49
RE: IPTV Recorder - by locoguano - 2018-03-24, 20:14
RE: IPTV Recorder - by primaeval - 2018-03-24, 18:35
RE: IPTV Recorder - by ray2301 - 2018-03-24, 20:11
RE: IPTV Recorder - by ray2301 - 2018-03-24, 20:59
RE: IPTV Recorder - by primaeval - 2018-03-24, 21:12
RE: IPTV Recorder - by Chychy - 2018-03-24, 21:15
RE: IPTV Recorder - by primaeval - 2018-03-24, 21:25
RE: IPTV Recorder - by Chychy - 2018-03-24, 21:32
RE: IPTV Recorder - by primaeval - 2018-03-24, 21:49
RE: IPTV Recorder - by ray2301 - 2018-03-24, 22:37
RE: IPTV Recorder - by primaeval - 2018-03-24, 23:05
RE: IPTV Recorder - by ray2301 - 2018-03-24, 23:13
RE: IPTV Recorder - by ray2301 - 2018-03-24, 23:28
RE: IPTV Recorder - by primaeval - 2018-03-24, 23:29
RE: IPTV Recorder - by Chychy - 2018-03-24, 23:32
RE: IPTV Recorder - by primaeval - 2018-03-24, 23:38
RE: IPTV Recorder - by primaeval - 2018-03-24, 23:52
RE: IPTV Recorder - by Chychy - 2018-03-25, 00:08
RE: IPTV Recorder - by primaeval - 2018-03-25, 00:17
RE: IPTV Recorder - by primaeval - 2018-03-25, 00:21
RE: IPTV Recorder - by Chychy - 2018-03-25, 03:12
RE: IPTV Recorder - by primaeval - 2018-03-25, 10:43
RE: IPTV Recorder - by ray2301 - 2018-03-25, 03:47
RE: IPTV Recorder - by primaeval - 2018-03-25, 11:25
RE: IPTV Recorder - by primaeval - 2018-03-25, 10:47
RE: IPTV Recorder - by Chychy - 2018-03-25, 11:44
RE: IPTV Recorder - by primaeval - 2018-03-25, 12:03
RE: IPTV Recorder - by Chychy - 2018-03-25, 12:07
RE: IPTV Recorder - by primaeval - 2018-03-25, 12:19
RE: IPTV Recorder - by Chychy - 2018-03-25, 12:39
RE: IPTV Recorder - by primaeval - 2018-03-25, 12:48
RE: IPTV Recorder - by Chychy - 2018-03-25, 13:14
RE: IPTV Recorder - by primaeval - 2018-03-25, 13:26
RE: IPTV Recorder - by Chychy - 2018-03-25, 14:58
RE: IPTV Recorder - by primaeval - 2018-03-25, 15:04
RE: IPTV Recorder - by primaeval - 2018-03-25, 15:06
RE: IPTV Recorder - by Chychy - 2018-03-25, 15:30
RE: IPTV Recorder - by primaeval - 2018-03-25, 15:42
RE: IPTV Recorder - by Chychy - 2018-03-25, 17:18
RE: IPTV Recorder - by primaeval - 2018-03-25, 17:52
RE: IPTV Recorder - by Chychy - 2018-03-25, 18:23
RE: IPTV Recorder - by primaeval - 2018-03-25, 18:29
RE: IPTV Recorder - by Chychy - 2018-03-25, 19:07
RE: IPTV Recorder - by primaeval - 2018-03-25, 19:53
RE: IPTV Recorder - by primaeval - 2018-03-25, 19:58
RE: IPTV Recorder - by Chychy - 2018-03-25, 20:10
RE: IPTV Recorder - by primaeval - 2018-03-25, 21:23
RE: IPTV Recorder - by Chychy - 2018-03-25, 21:34
RE: IPTV Recorder - by primaeval - 2018-03-25, 21:44
RE: IPTV Recorder - by primaeval - 2018-03-25, 22:13
RE: IPTV Recorder - by primaeval - 2018-03-25, 22:51
RE: IPTV Recorder - by Chychy - 2018-03-25, 23:42
RE: IPTV Recorder - by primaeval - 2018-03-26, 18:22
RE: IPTV Recorder - by Chychy - 2018-03-26, 19:40
RE: IPTV Recorder - by primaeval - 2018-03-26, 19:42
RE: IPTV Recorder - by Chychy - 2018-03-26, 20:15
RE: IPTV Recorder - by primaeval - 2018-03-26, 20:18
RE: IPTV Recorder - by primaeval - 2018-03-26, 20:28
RE: IPTV Recorder - by Chychy - 2018-03-26, 21:01
RE: IPTV Recorder - by primaeval - 2018-03-26, 21:16
RE: IPTV Recorder - by primaeval - 2018-03-26, 21:24
RE: IPTV Recorder - by Chychy - 2018-03-26, 21:56
RE: IPTV Recorder - by primaeval - 2018-03-26, 21:59
RE: IPTV Recorder - by Chychy - 2018-03-26, 23:13
RE: IPTV Recorder - by primaeval - 2018-03-26, 23:22
RE: IPTV Recorder - by Chychy - 2018-03-26, 23:41
RE: IPTV Recorder - by primaeval - 2018-03-27, 09:17
RE: IPTV Recorder - by primaeval - 2018-03-27, 09:56
RE: IPTV Recorder - by Chychy - 2018-03-27, 10:34
RE: IPTV Recorder - by primaeval - 2018-03-27, 10:44
RE: IPTV Recorder - by Chychy - 2018-03-27, 11:45
RE: IPTV Recorder - by primaeval - 2018-03-27, 11:52
RE: IPTV Recorder - by primaeval - 2018-03-27, 12:36
RE: IPTV Recorder - by Chychy - 2018-03-27, 12:36
RE: IPTV Recorder - by Chychy - 2018-03-27, 13:52
RE: IPTV Recorder - by primaeval - 2018-03-27, 17:25
RE: IPTV Recorder - by primaeval - 2018-03-27, 17:28
RE: IPTV Recorder - by primaeval - 2018-03-27, 17:36
RE: IPTV Recorder - by Chychy - 2018-03-27, 17:53
RE: IPTV Recorder - by primaeval - 2018-03-27, 18:19
RE: IPTV Recorder - by primaeval - 2018-03-27, 19:01
RE: IPTV Recorder - by Chychy - 2018-03-27, 19:46
RE: IPTV Recorder - by wigee - 2018-03-31, 12:17
RE: IPTV Recorder - by MikeKL - 2018-03-31, 22:35
RE: IPTV Recorder - by Chychy - 2018-03-31, 14:00
RE: IPTV Recorder - by primaeval - 2018-03-31, 18:02
RE: IPTV Recorder - by struthm8 - 2018-04-09, 07:27
RE: IPTV Recorder - by primaeval - 2018-04-09, 08:19
RE: IPTV Recorder - by struthm8 - 2018-04-09, 08:36
RE: IPTV Recorder - by primaeval - 2018-04-09, 09:09
RE: IPTV Recorder - by primaeval - 2018-03-31, 21:14
RE: IPTV Recorder - by primaeval - 2018-04-02, 18:31
RE: IPTV Recorder - by primaeval - 2018-04-02, 19:56
RE: IPTV Recorder - by ray2301 - 2018-04-03, 02:44
RE: IPTV Recorder - by locoguano - 2018-04-03, 06:03
RE: IPTV Recorder - by primaeval - 2018-04-03, 08:44
RE: IPTV Recorder - by primaeval - 2018-04-03, 10:02
RE: IPTV Recorder - by ray2301 - 2018-04-09, 17:29
RE: IPTV Recorder - by primaeval - 2018-04-09, 17:39
RE: IPTV Recorder - by ray2301 - 2018-04-09, 18:01
RE: IPTV Recorder - by primaeval - 2018-04-09, 20:01
RE: IPTV Recorder - by ray2301 - 2018-04-10, 00:15
RE: IPTV Recorder - by hotshot2k3 - 2018-04-10, 19:17
RE: IPTV Recorder - by primaeval - 2018-04-10, 19:20
RE: IPTV Recorder - by hotshot2k3 - 2018-04-10, 19:30
RE: IPTV Recorder - by primaeval - 2018-04-10, 19:36
RE: IPTV Recorder - by hotshot2k3 - 2018-04-10, 19:50
RE: IPTV Recorder - by primaeval - 2018-04-10, 19:58
RE: IPTV Recorder - by primaeval - 2018-04-10, 20:02
RE: IPTV Recorder - by hotshot2k3 - 2018-04-10, 20:04
RE: IPTV Recorder - by primaeval - 2018-04-10, 20:07
RE: IPTV Recorder - by primaeval - 2018-04-10, 21:15
RE: IPTV Recorder - by hotshot2k3 - 2018-04-11, 00:00
RE: IPTV Recorder - by primaeval - 2018-04-11, 09:09
IPTV Recorder - by ed_davidson01 - 2018-04-11, 01:43
RE: IPTV Recorder - by primaeval - 2018-04-11, 09:17
RE: IPTV Recorder - by hotshot2k3 - 2018-04-11, 13:20
RE: IPTV Recorder - by primaeval - 2018-04-11, 13:26
RE: IPTV Recorder - by hotshot2k3 - 2018-04-11, 13:39
RE: IPTV Recorder - by primaeval - 2018-04-11, 14:41
RE: IPTV Recorder - by hotshot2k3 - 2018-04-11, 15:12
RE: IPTV Recorder - by Alfredo Pérez - 2018-04-13, 12:55
RE: IPTV Recorder - by primaeval - 2018-04-13, 15:08
RE: IPTV Recorder - by wigee - 2018-04-13, 13:49
RE: IPTV Recorder - by primaeval - 2018-04-13, 15:19
RE: IPTV Recorder - by primaeval - 2018-04-13, 15:37
RE: IPTV Recorder - by wigee - 2018-04-13, 16:00
RE: IPTV Recorder - by primaeval - 2018-04-13, 16:10
RE: IPTV Recorder - by wigee - 2018-04-13, 16:12
RE: IPTV Recorder - by primaeval - 2018-04-13, 16:16
RE: IPTV Recorder - by DarrenHill - 2018-04-13, 17:37
RE: IPTV Recorder - by wigee - 2018-04-14, 10:30
RE: IPTV Recorder - by primaeval - 2018-04-14, 11:06
RE: IPTV Recorder - by primaeval - 2018-04-14, 18:17
RE: IPTV Recorder - by wigee - 2018-04-15, 10:34
RE: IPTV Recorder - by primaeval - 2018-04-15, 10:55
RE: IPTV Recorder - by wigee - 2018-04-15, 13:24
RE: IPTV Recorder - by primaeval - 2018-04-15, 13:29
RE: IPTV Recorder - by primaeval - 2018-04-15, 13:49
IPTV Recorder - by ed_davidson01 - 2018-04-15, 15:37
RE: IPTV Recorder - by wigee - 2018-04-15, 17:21
RE: IPTV Recorder - by primaeval - 2018-04-15, 17:34
RE: IPTV Recorder - by hotshot2k3 - 2018-04-16, 03:21
RE: IPTV Recorder - by primaeval - 2018-04-16, 08:07
RE: IPTV Recorder - by primaeval - 2018-04-16, 08:32
RE: IPTV Recorder - by wigee - 2018-04-16, 13:13
RE: IPTV Recorder - by primaeval - 2018-04-16, 13:31
RE: IPTV Recorder - by primaeval - 2018-04-16, 14:03
RE: IPTV Recorder - by hotshot2k3 - 2018-04-16, 14:48
RE: IPTV Recorder - by primaeval - 2018-04-16, 14:52
RE: IPTV Recorder - by wigee - 2018-04-16, 15:02
RE: IPTV Recorder - by primaeval - 2018-04-16, 15:10
RE: IPTV Recorder - by primaeval - 2018-04-16, 15:06
RE: IPTV Recorder - by primaeval - 2018-04-16, 15:48
RE: IPTV Recorder - by primaeval - 2018-04-16, 17:03
RE: IPTV Recorder - by hotshot2k3 - 2018-04-17, 03:40
RE: IPTV Recorder - by primaeval - 2018-04-17, 10:48
IPTV Recorder - by ed_davidson01 - 2018-04-17, 07:35
RE: IPTV Recorder - by primaeval - 2018-04-17, 11:28
RE: IPTV Recorder - by bladerunner82 - 2018-04-17, 13:02
RE: IPTV Recorder - by primaeval - 2018-04-17, 13:10
RE: IPTV Recorder - by hotshot2k3 - 2018-04-17, 13:24
RE: IPTV Recorder - by primaeval - 2018-04-17, 13:30
RE: IPTV Recorder - by hotshot2k3 - 2018-04-17, 13:39
RE: IPTV Recorder - by primaeval - 2018-04-17, 13:52
RE: IPTV Recorder - by hotshot2k3 - 2018-04-17, 14:00
RE: IPTV Recorder - by primaeval - 2018-04-17, 14:10
RE: IPTV Recorder - by primaeval - 2018-04-17, 19:59
RE: IPTV Recorder - by Nojustice - 2018-04-18, 10:54
RE: IPTV Recorder - by primaeval - 2018-04-18, 19:41
RE: IPTV Recorder - by primaeval - 2018-04-18, 11:09
IPTV Recorder - by ed_davidson01 - 2018-04-18, 15:47
RE: IPTV Recorder - by Publish3r - 2018-04-18, 16:14
RE: IPTV Recorder - by primaeval - 2018-04-18, 19:00
RE: IPTV Recorder - by primaeval - 2018-04-18, 16:22
RE: IPTV Recorder - by GriffeyJuni0r - 2018-04-19, 04:51
RE: IPTV Recorder - by primaeval - 2018-04-19, 10:28
RE: IPTV Recorder - by primaeval - 2018-04-19, 12:38
RE: IPTV Recorder - by primaeval - 2018-04-19, 14:33
RE: IPTV Recorder - by Publish3r - 2018-04-19, 15:58
RE: IPTV Recorder - by primaeval - 2018-04-19, 16:13
RE: IPTV Recorder - by Publish3r - 2018-04-19, 16:32
RE: IPTV Recorder - by Publish3r - 2018-04-19, 16:34
RE: IPTV Recorder - by primaeval - 2018-04-19, 16:35
IPTV Recorder - by ed_davidson01 - 2018-04-19, 16:42
RE: IPTV Recorder - by Publish3r - 2018-04-19, 16:45
RE: IPTV Recorder - by primaeval - 2018-04-19, 17:18
RE: IPTV Recorder - by Publish3r - 2018-04-19, 17:31
RE: IPTV Recorder - by primaeval - 2018-04-19, 17:45
RE: IPTV Recorder - by Publish3r - 2018-04-19, 18:02
RE: IPTV Recorder - by primaeval - 2018-04-19, 18:18
RE: IPTV Recorder - by GriffeyJuni0r - 2018-04-20, 03:16
RE: IPTV Recorder - by primaeval - 2018-04-20, 09:28
RE: IPTV Recorder - by Karellen - 2018-04-20, 06:31
RE: IPTV Recorder - by GriffeyJuni0r - 2018-04-20, 18:02
RE: IPTV Recorder - by primaeval - 2018-04-20, 18:04
RE: IPTV Recorder - by primaeval - 2018-04-28, 13:09
RE: IPTV Recorder - by gb160 - 2018-05-05, 10:37
RE: IPTV Recorder - by primaeval - 2018-05-05, 11:00
RE: IPTV Recorder - by gb160 - 2018-05-05, 11:13
RE: IPTV Recorder - by gb160 - 2018-05-05, 11:33
RE: IPTV Recorder - by primaeval - 2018-05-05, 12:09
RE: IPTV Recorder - by gb160 - 2018-05-05, 12:54
RE: IPTV Recorder - by primaeval - 2018-05-05, 13:09
RE: IPTV Recorder - by GriffeyJuni0r - 2018-05-06, 00:34
RE: IPTV Recorder - by primaeval - 2018-05-06, 10:24
RE: IPTV Recorder - by locoguano - 2018-05-06, 01:53
RE: IPTV Recorder - by primaeval - 2018-05-06, 10:30
RE: IPTV Recorder - by clones - 2018-05-28, 18:40
RE: IPTV Recorder - by dzejms - 2018-05-21, 13:36
RE: IPTV Recorder - by primaeval - 2018-05-21, 18:49
RE: IPTV Recorder - by dzejms - 2018-05-22, 08:51
RE: IPTV Recorder - by kaable - 2018-05-21, 21:11
RE: IPTV Recorder - by primaeval - 2018-05-21, 21:51
RE: IPTV Recorder - by kaable - 2018-05-22, 01:40
RE: IPTV Recorder - by primaeval - 2018-05-22, 10:44
RE: IPTV Recorder - by kaable - 2018-05-26, 11:30
RE: IPTV Recorder - by primaeval - 2018-05-22, 10:52
RE: IPTV Recorder - by dzejms - 2018-05-22, 11:25
RE: IPTV Recorder - by dzejms - 2018-05-22, 11:43
RE: IPTV Recorder - by primaeval - 2018-05-22, 11:44
RE: IPTV Recorder - by dzejms - 2018-05-22, 12:11
RE: IPTV Recorder - by primaeval - 2018-05-22, 12:14
RE: IPTV Recorder - by primaeval - 2018-05-22, 15:09
RE: IPTV Recorder - by primaeval - 2018-05-22, 15:17
RE: IPTV Recorder - by dzejms - 2018-05-22, 16:45
RE: IPTV Recorder - by primaeval - 2018-05-22, 20:13
RE: IPTV Recorder - by dzejms - 2018-05-22, 20:24
RE: IPTV Recorder - by dzejms - 2018-05-23, 11:56
RE: IPTV Recorder - by primaeval - 2018-05-23, 12:40
RE: IPTV Recorder - by dzejms - 2018-05-23, 12:49
RE: IPTV Recorder - by primaeval - 2018-05-23, 12:52
RE: IPTV Recorder - by dzejms - 2018-05-23, 13:05
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:00
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:03
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:10
RE: IPTV Recorder - by dzejms - 2018-05-23, 13:14
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:17
RE: IPTV Recorder - by dzejms - 2018-05-23, 13:33
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:46
RE: IPTV Recorder - by dzejms - 2018-05-23, 14:27
RE: IPTV Recorder - by primaeval - 2018-05-26, 11:58
RE: IPTV Recorder - by dzejms - 2018-05-28, 09:51
RE: IPTV Recorder - by primaeval - 2018-05-28, 11:15
RE: IPTV Recorder - by primaeval - 2018-05-28, 19:13
RE: IPTV Recorder - by primaeval - 2018-05-28, 19:17
RE: IPTV Recorder - by primaeval - 2018-05-28, 19:26
RE: IPTV Recorder - by dzejms - 2018-05-29, 12:20
RE: IPTV Recorder - by be2p - 2019-09-06, 18:46
RE: IPTV Recorder - by primaeval - 2018-05-29, 12:45
RE: IPTV Recorder - by dzejms - 2018-05-29, 13:04
RE: IPTV Recorder - by dzejms - 2018-05-29, 13:19
RE: IPTV Recorder - by primaeval - 2018-05-29, 13:19
RE: IPTV Recorder - by primaeval - 2018-05-29, 13:21
RE: IPTV Recorder - by dzejms - 2018-05-29, 13:35
RE: IPTV Recorder - by dzejms - 2018-05-29, 13:38
RE: IPTV Recorder - by primaeval - 2018-05-29, 13:54
RE: IPTV Recorder - by dzejms - 2018-05-29, 14:10
RE: IPTV Recorder - by primaeval - 2018-05-29, 14:16
RE: IPTV Recorder - by dzejms - 2018-05-29, 14:25
RE: IPTV Recorder - by dzejms - 2018-06-01, 02:04
RE: IPTV Recorder - by primaeval - 2018-06-01, 10:31
RE: IPTV Recorder - by primaeval - 2018-06-01, 12:18
RE: IPTV Recorder - by princesabt821 - 2018-06-05, 16:22
RE: IPTV Recorder - by primaeval - 2018-06-05, 17:26
RE: IPTV Recorder - by kt666 - 2018-06-10, 17:28
RE: IPTV Recorder - by dzejms - 2018-06-10, 17:40
RE: IPTV Recorder - by kt666 - 2018-06-10, 17:52
RE: IPTV Recorder - by primaeval - 2018-06-10, 17:37
RE: IPTV Recorder - by primaeval - 2018-06-10, 18:12
RE: IPTV Recorder - by kt666 - 2018-06-10, 18:46
RE: IPTV Recorder - by dzejms - 2018-06-10, 18:43
RE: IPTV Recorder - by primaeval - 2018-06-10, 18:52
RE: IPTV Recorder - by dzejms - 2018-06-12, 00:12
RE: IPTV Recorder - by primaeval - 2018-06-12, 10:09
RE: IPTV Recorder - by dzejms - 2018-06-12, 13:20
RE: IPTV Recorder - by primaeval - 2018-06-12, 13:43
RE: IPTV Recorder - by dzejms - 2018-07-10, 12:05
RE: IPTV Recorder - by primaeval - 2018-07-10, 12:20
RE: IPTV Recorder - by brumbie - 2018-06-17, 02:05
RE: IPTV Recorder - by primaeval - 2018-06-17, 08:51
RE: IPTV Recorder - by brumbie - 2018-06-18, 09:32
RE: IPTV Recorder - by primaeval - 2018-06-18, 09:48
RE: IPTV Recorder - by brumbie - 2018-06-18, 12:50
RE: IPTV Recorder - by primaeval - 2018-06-18, 13:29
RE: IPTV Recorder - by brumbie - 2018-06-18, 14:10
RE: IPTV Recorder - by primaeval - 2018-06-18, 14:42
RE: IPTV Recorder - by brumbie - 2018-06-18, 14:45
RE: IPTV Recorder - by primaeval - 2018-06-18, 14:48
RE: IPTV Recorder - by brumbie - 2018-06-18, 14:52
RE: IPTV Recorder - by primaeval - 2018-06-18, 14:59
RE: IPTV Recorder - by brumbie - 2018-06-18, 15:23
RE: IPTV Recorder - by primaeval - 2018-06-18, 16:06
RE: IPTV Recorder - by brumbie - 2018-06-18, 16:48
RE: IPTV Recorder - by xryuu - 2018-06-20, 19:48
RE: IPTV Recorder - by primaeval - 2018-06-20, 20:36
RE: IPTV Recorder - by DarrenHill - 2018-06-20, 20:46
RE: IPTV Recorder - by xryuu - 2018-06-20, 23:06
RE: IPTV Recorder - by primaeval - 2018-06-20, 23:14
RE: IPTV Recorder - by ed_davidson - 2018-06-22, 06:31
RE: IPTV Recorder - by m1pnk - 2018-07-13, 21:07
RE: IPTV Recorder - by primaeval - 2018-07-13, 21:25
RE: IPTV Recorder - by JQZ* - 2018-09-01, 21:00
RE: IPTV Recorder - by primaeval - 2018-09-01, 21:31
RE: IPTV Recorder - by JQZ* - 2018-09-01, 22:08
RE: IPTV Recorder - by m1pnk - 2018-07-15, 18:54
RE: IPTV Recorder - by primaeval - 2018-07-16, 19:25
RE: IPTV Recorder - by m1pnk - 2018-07-17, 00:15
RE: IPTV Recorder - by rb01 - 2018-07-22, 19:33
RE: IPTV Recorder - by primaeval - 2018-07-22, 21:23
RE: IPTV Recorder - by rb01 - 2018-07-23, 08:47
RE: IPTV Recorder - by primaeval - 2018-07-23, 10:19
RE: IPTV Recorder - by rb01 - 2018-07-23, 13:25
RE: IPTV Recorder - by primaeval - 2018-07-23, 13:31
RE: IPTV Recorder - by rb01 - 2018-07-23, 16:30
RE: IPTV Recorder - by primaeval - 2018-07-23, 16:59
RE: IPTV Recorder - by rb01 - 2018-07-23, 17:05
RE: IPTV Recorder - by primaeval - 2018-07-23, 17:14
RE: IPTV Recorder - by rb01 - 2018-07-23, 17:24
RE: IPTV Recorder - by primaeval - 2018-07-23, 17:28
RE: IPTV Recorder - by Hesse - 2018-08-08, 14:50
RE: IPTV Recorder - by primaeval - 2018-08-08, 14:57
RE: IPTV Recorder - by Samboy08 - 2018-08-23, 02:48
RE: IPTV Recorder - by primaeval - 2018-08-23, 09:51
RE: IPTV Recorder - by snaitaz - 2018-08-24, 06:17
RE: IPTV Recorder - by primaeval - 2018-08-24, 10:33
RE: IPTV Recorder - by snaitaz - 2018-08-24, 16:38
RE: IPTV Recorder - by snaitaz - 2018-08-25, 00:57
RE: IPTV Recorder - by snaitaz - 2018-08-25, 07:48
RE: IPTV Recorder - by primaeval - 2018-08-27, 09:24
RE: IPTV Recorder - by purplehorseshoes - 2018-08-27, 19:51
RE: IPTV Recorder - by primaeval - 2018-08-27, 20:01
IPTV Recorder - by ed_davidson01 - 2018-08-27, 19:54
RE: IPTV Recorder - by purplehorseshoes - 2018-08-27, 20:07
RE: IPTV Recorder - by primaeval - 2018-08-27, 20:11
RE: IPTV Recorder - by purplehorseshoes - 2018-08-27, 20:10
RE: IPTV Recorder - by primaeval - 2018-08-27, 20:13
RE: IPTV Recorder - by primaeval - 2018-09-01, 22:23
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:00
RE: IPTV Recorder - by primaeval - 2018-09-01, 23:09
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:12
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:16
RE: IPTV Recorder - by primaeval - 2018-09-01, 23:20
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:45
RE: IPTV Recorder - by primaeval - 2018-09-01, 23:29
RE: IPTV Recorder - by primaeval - 2018-09-01, 23:37
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:48
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:59
RE: IPTV Recorder - by primaeval - 2018-09-02, 09:28
RE: IPTV Recorder - by JQZ* - 2018-09-02, 12:25
RE: IPTV Recorder - by gekados - 2018-09-02, 01:00
RE: IPTV Recorder - by primaeval - 2018-09-02, 09:35
RE: IPTV Recorder - by gekados - 2018-09-02, 10:50
RE: IPTV Recorder - by primaeval - 2018-09-02, 12:48
RE: IPTV Recorder - by JQZ* - 2018-09-02, 13:30
RE: IPTV Recorder - by primaeval - 2018-09-02, 18:56
RE: IPTV Recorder - by JQZ* - 2018-09-03, 08:31
RE: IPTV Recorder - by primaeval - 2018-09-03, 08:46
RE: IPTV Recorder - by JQZ* - 2018-09-03, 09:21
RE: IPTV Recorder - by primaeval - 2018-09-03, 09:46
RE: IPTV Recorder - by JQZ* - 2018-09-03, 10:13
RE: IPTV Recorder - by primaeval - 2018-09-03, 10:27
RE: IPTV Recorder - by JQZ* - 2018-09-03, 11:35
RE: IPTV Recorder - by primaeval - 2018-09-03, 10:32
RE: IPTV Recorder - by JQZ* - 2018-09-03, 11:01
RE: IPTV Recorder - by primaeval - 2018-09-03, 11:53
RE: IPTV Recorder - by JQZ* - 2018-09-03, 13:02
RE: IPTV Recorder - by primaeval - 2018-09-03, 14:07
RE: IPTV Recorder - by JQZ* - 2018-09-03, 17:17
RE: IPTV Recorder - by primaeval - 2018-09-03, 17:58
RE: IPTV Recorder - by JQZ* - 2018-09-03, 18:53
RE: IPTV Recorder - by primaeval - 2018-09-03, 19:31
RE: IPTV Recorder - by JQZ* - 2018-09-03, 20:11
RE: IPTV Recorder - by primaeval - 2018-09-03, 20:18
RE: IPTV Recorder - by JQZ* - 2018-09-03, 21:14
RE: IPTV Recorder - by primaeval - 2018-09-03, 21:37
RE: IPTV Recorder - by JQZ* - 2018-09-03, 23:39
RE: IPTV Recorder - by JQZ* - 2018-09-04, 05:43
RE: IPTV Recorder - by nashnash - 2018-09-12, 08:41
RE: IPTV Recorder - by primaeval - 2018-09-12, 08:59
RE: IPTV Recorder - by nashnash - 2018-09-12, 09:59
RE: IPTV Recorder - by primaeval - 2018-09-12, 10:36
RE: IPTV Recorder - by REralte - 2018-09-12, 17:52
RE: IPTV Recorder - by Foxxyfox - 2018-09-12, 18:59
RE: IPTV Recorder - by primaeval - 2018-09-12, 19:10
RE: IPTV Recorder - by Foxxyfox - 2018-09-12, 20:27
RE: IPTV Recorder - by Foxxyfox - 2018-09-12, 20:48
RE: IPTV Recorder - by primaeval - 2018-09-12, 20:55
RE: IPTV Recorder - by Foxxyfox - 2018-09-12, 23:37
RE: IPTV Recorder - by primaeval - 2018-09-13, 07:07
RE: IPTV Recorder - by Foxxyfox - 2018-09-13, 10:54
RE: IPTV Recorder - by primaeval - 2018-09-13, 11:01
RE: IPTV Recorder - by Foxxyfox - 2018-09-13, 13:18
RE: IPTV Recorder - by nashnash - 2018-09-13, 02:17
RE: IPTV Recorder - by nashnash - 2018-09-13, 02:50
RE: IPTV Recorder - by primaeval - 2018-09-13, 07:15
RE: IPTV Recorder - by nashnash - 2018-09-13, 09:31
RE: IPTV Recorder - by primaeval - 2018-09-13, 10:11
RE: IPTV Recorder - by nashnash - 2018-09-13, 19:46
RE: IPTV Recorder - by primaeval - 2018-09-13, 10:18
RE: IPTV Recorder - by nashnash - 2018-09-15, 09:09
RE: IPTV Recorder - by primaeval - 2018-09-15, 09:18
RE: IPTV Recorder - by nashnash - 2018-09-15, 17:55
RE: IPTV Recorder - by primaeval - 2018-09-15, 18:06
RE: IPTV Recorder - by nashnash - 2018-09-15, 19:21
RE: IPTV Recorder - by primaeval - 2018-09-15, 19:27
RE: IPTV Recorder - by nashnash - 2018-09-15, 20:59
RE: IPTV Recorder - by primaeval - 2018-09-15, 21:10
RE: IPTV Recorder - by nashnash - 2018-09-15, 21:05
RE: IPTV Recorder - by nashnash - 2018-09-15, 21:31
RE: IPTV Recorder - by primaeval - 2018-09-15, 21:43
RE: IPTV Recorder - by nashnash - 2018-09-15, 22:42
RE: IPTV Recorder - by primaeval - 2018-09-15, 22:58
RE: IPTV Recorder - by primaeval - 2018-09-15, 23:16
RE: IPTV Recorder - by nashnash - 2018-09-16, 07:03
RE: IPTV Recorder - by primaeval - 2018-09-16, 07:33
RE: IPTV Recorder - by primaeval - 2018-09-18, 09:57
RE: IPTV Recorder - by ciorci - 2018-09-18, 12:33
RE: IPTV Recorder - by primaeval - 2018-09-18, 12:49
RE: IPTV Recorder - by ciorci - 2018-09-19, 10:49
RE: IPTV Recorder - by nashnash - 2018-09-19, 18:30
RE: IPTV Recorder - by primaeval - 2018-09-19, 18:39
RE: IPTV Recorder - by nashnash - 2018-09-19, 21:14
RE: IPTV Recorder - by nashnash - 2018-09-21, 06:23
RE: IPTV Recorder - by Klojum - 2018-09-19, 19:06
RE: IPTV Recorder - by primaeval - 2018-09-22, 22:17
RE: IPTV Recorder - by nashnash - 2018-09-22, 22:25
RE: IPTV Recorder - by primaeval - 2018-09-22, 22:31
RE: IPTV Recorder - by nashnash - 2018-09-22, 22:52
RE: IPTV Recorder - by nashnash - 2018-09-23, 05:07
RE: IPTV Recorder - by primaeval - 2018-09-24, 12:43
RE: IPTV Recorder - by nashnash - 2018-09-28, 02:40
RE: IPTV Recorder - by primaeval - 2018-09-28, 07:46
RE: IPTV Recorder - by nashnash - 2018-09-30, 07:34
RE: IPTV Recorder - by primaeval - 2018-09-30, 09:04
RE: IPTV Recorder - by nashnash - 2018-10-01, 05:16
RE: IPTV Recorder - by primaeval - 2018-10-01, 07:45
RE: IPTV Recorder - by 01520717 - 2018-11-04, 08:01
RE: IPTV Recorder - by primaeval - 2018-11-04, 09:34
RE: IPTV Recorder - by 01520717 - 2018-11-04, 18:23
RE: IPTV Recorder - by primaeval - 2018-11-04, 18:28
RE: IPTV Recorder - by psbguy - 2018-11-11, 14:24
RE: IPTV Recorder - by primaeval - 2018-11-11, 14:29
RE: IPTV Recorder - by psbguy - 2018-11-11, 19:42
RE: IPTV Recorder - by primaeval - 2018-11-11, 19:49
RE: IPTV Recorder - by psbguy - 2018-11-11, 22:38
RE: IPTV Recorder - by primaeval - 2018-11-11, 22:41
RE: IPTV Recorder - by primaeval - 2018-11-12, 10:54
RE: IPTV Recorder - by psbguy - 2018-11-12, 17:24
RE: IPTV Recorder - by primaeval - 2018-11-12, 17:55
RE: IPTV Recorder - by psbguy - 2018-11-12, 19:24
RE: IPTV Recorder - by primaeval - 2018-11-12, 19:45
RE: IPTV Recorder - by psbguy - 2018-11-12, 22:24
RE: IPTV Recorder - by primaeval - 2018-11-12, 22:42
RE: IPTV Recorder - by Boromick - 2018-11-12, 22:36
RE: IPTV Recorder - by primaeval - 2018-11-12, 22:48
RE: IPTV Recorder - by Boromick - 2018-11-16, 13:42
RE: IPTV Recorder - by primaeval - 2018-11-16, 14:35
RE: IPTV Recorder - by Boromick - 2018-11-16, 18:28
RE: IPTV Recorder - by primaeval - 2018-11-16, 21:03
RE: IPTV Recorder - by Boromick - 2018-11-16, 21:04
RE: IPTV Recorder - by Boromick - 2018-11-17, 18:20
RE: IPTV Recorder - by primaeval - 2018-11-17, 20:53
RE: IPTV Recorder - by Boromick - 2018-11-18, 12:00
RE: IPTV Recorder - by Boromick - 2018-11-12, 23:09
RE: IPTV Recorder - by primaeval - 2018-11-23, 16:52
RE: IPTV Recorder - by RuneS - 2018-11-28, 13:14
RE: IPTV Recorder - by primaeval - 2018-11-28, 13:22
RE: IPTV Recorder - by RuneS - 2018-11-28, 13:31
RE: IPTV Recorder - by primaeval - 2018-11-28, 13:38
RE: IPTV Recorder - by RuneS - 2018-11-28, 13:47
RE: IPTV Recorder - by javidial - 2018-11-28, 22:07
RE: IPTV Recorder - by primaeval - 2018-11-28, 22:17
RE: IPTV Recorder - by Big2hd - 2018-12-16, 23:05
RE: IPTV Recorder - by primaeval - 2018-12-16, 23:18
RE: IPTV Recorder - by Big2hd - 2018-12-17, 02:50
RE: IPTV Recorder - by primaeval - 2018-12-17, 10:12
RE: IPTV Recorder - by Big2hd - 2018-12-17, 18:19
RE: IPTV Recorder - by primaeval - 2018-12-17, 18:29
RE: IPTV Recorder - by Big2hd - 2018-12-17, 22:09
RE: IPTV Recorder - by mwkurt - 2018-12-26, 15:28
RE: IPTV Recorder - by primaeval - 2018-12-26, 15:42
RE: IPTV Recorder - by mwkurt - 2018-12-26, 18:02
RE: IPTV Recorder - by primaeval - 2018-12-26, 18:10
RE: IPTV Recorder - by pmcnamara - 2018-12-26, 16:30
RE: IPTV Recorder - by primaeval - 2018-12-26, 17:11
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 13:35
RE: IPTV Recorder - by primaeval - 2018-12-27, 13:39
RE: IPTV Recorder - by DarrenHill - 2018-12-26, 18:19
RE: IPTV Recorder - by mwkurt - 2018-12-26, 21:04
RE: IPTV Recorder - by primaeval - 2018-12-26, 21:11
RE: IPTV Recorder - by mwkurt - 2018-12-26, 21:27
RE: IPTV Recorder - by primaeval - 2018-12-27, 00:15
RE: IPTV Recorder - by mwkurt - 2018-12-27, 03:12
RE: IPTV Recorder - by mwkurt - 2018-12-27, 03:35
RE: IPTV Recorder - by primaeval - 2018-12-27, 10:25
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 13:25
RE: IPTV Recorder - by primaeval - 2018-12-27, 13:31
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 13:39
RE: IPTV Recorder - by mwkurt - 2018-12-27, 18:41
RE: IPTV Recorder - by primaeval - 2018-12-27, 19:05
RE: IPTV Recorder - by primaeval - 2018-12-27, 13:44
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 14:21
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 14:20
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 17:28
RE: IPTV Recorder - by primaeval - 2018-12-27, 17:47
RE: IPTV Recorder - by floatingshed - 2019-01-05, 02:09
RE: IPTV Recorder - by primaeval - 2019-01-05, 10:39
RE: IPTV Recorder - by pirlone - 2019-01-05, 11:53
RE: IPTV Recorder - by primaeval - 2019-01-05, 12:15
RE: IPTV Recorder - by pirlone - 2019-01-05, 12:28
RE: IPTV Recorder - by primaeval - 2019-01-05, 12:32
RE: IPTV Recorder - by pirlone - 2019-01-05, 12:31
RE: IPTV Recorder - by pirlone - 2019-01-05, 16:13
RE: IPTV Recorder - by primaeval - 2019-01-05, 16:31
RE: IPTV Recorder - by pirlone - 2019-01-06, 14:03
RE: IPTV Recorder - by primaeval - 2019-01-06, 14:24
RE: IPTV Recorder - by primaeval - 2019-01-06, 16:26
RE: IPTV Recorder - by pirlone - 2019-01-06, 14:42
RE: IPTV Recorder - by pmcnamara - 2019-01-06, 15:16
RE: IPTV Recorder - by primaeval - 2019-01-06, 15:48
RE: IPTV Recorder - by pmcnamara - 2019-01-06, 16:22
RE: IPTV Recorder - by primaeval - 2019-01-06, 16:25
RE: IPTV Recorder - by pmcnamara - 2019-01-06, 17:30
RE: IPTV Recorder - by pmcnamara - 2019-01-06, 17:33
RE: IPTV Recorder - by primaeval - 2019-01-06, 17:53
RE: IPTV Recorder - by pmcnamara - 2019-01-07, 03:17
RE: IPTV Recorder - by pirlone - 2019-01-06, 16:59
RE: IPTV Recorder - by icthruu - 2019-01-07, 19:47
RE: IPTV Recorder - by primaeval - 2019-01-07, 20:24
RE: IPTV Recorder - by pmcnamara - 2019-01-08, 15:22
RE: IPTV Recorder - by primaeval - 2019-01-08, 17:44
IPTV Recorder - by ed_davidson01 - 2019-01-08, 16:15
RE: IPTV Recorder - by pmcnamara - 2019-01-08, 18:46
RE: IPTV Recorder - by maiers12 - 2019-01-11, 14:41
RE: IPTV Recorder - by primaeval - 2019-01-11, 14:53
RE: IPTV Recorder - by maiers12 - 2019-01-11, 16:30
RE: IPTV Recorder - by maiers12 - 2019-01-11, 19:18
RE: IPTV Recorder - by primaeval - 2019-01-12, 11:01
RE: IPTV Recorder - by DarrenHill - 2019-01-11, 15:28
RE: IPTV Recorder - by maiers12 - 2019-01-12, 11:27
RE: IPTV Recorder - by maiers12 - 2019-01-12, 11:28
RE: IPTV Recorder - by primaeval - 2019-01-12, 11:47
RE: IPTV Recorder - by maiers12 - 2019-01-12, 14:34
RE: IPTV Recorder - by primaeval - 2019-01-12, 15:06
RE: IPTV Recorder - by maiers12 - 2019-01-12, 15:17
RE: IPTV Recorder - by primaeval - 2019-01-12, 15:26
RE: IPTV Recorder - by maiers12 - 2019-01-12, 16:23
RE: IPTV Recorder - by primaeval - 2019-01-12, 11:32
RE: IPTV Recorder - by Elluminatus - 2019-01-12, 14:37
RE: IPTV Recorder - by primaeval - 2019-01-12, 15:00
RE: IPTV Recorder - by primaeval - 2019-01-12, 16:35
RE: IPTV Recorder - by maiers12 - 2019-01-12, 16:48
RE: IPTV Recorder - by primaeval - 2019-01-12, 17:05
RE: IPTV Recorder - by maiers12 - 2019-01-12, 18:03
RE: IPTV Recorder - by primaeval - 2019-01-12, 18:34
RE: IPTV Recorder - by maiers12 - 2019-01-12, 19:02
RE: IPTV Recorder - by primaeval - 2019-01-12, 19:15
RE: IPTV Recorder - by maiers12 - 2019-01-13, 15:36
RE: IPTV Recorder - by DarrenHill - 2019-01-12, 19:14
RE: IPTV Recorder - by primaeval - 2019-01-12, 19:16
RE: IPTV Recorder - by Elluminatus - 2019-01-13, 01:26
RE: IPTV Recorder - by primaeval - 2019-01-13, 10:09
RE: IPTV Recorder - by Elluminatus - 2019-01-13, 16:05
RE: IPTV Recorder - by primaeval - 2019-01-13, 16:43
RE: IPTV Recorder - by maiers12 - 2019-01-13, 21:53
RE: IPTV Recorder - by primaeval - 2019-01-13, 22:00
RE: IPTV Recorder - by martybob - 2019-01-16, 08:35
RE: IPTV Recorder - by primaeval - 2019-01-16, 10:30
RE: IPTV Recorder - by martybob - 2019-01-16, 17:00
RE: IPTV Recorder - by maiers12 - 2019-01-22, 09:53
RE: IPTV Recorder - by primaeval - 2019-01-22, 11:26
RE: IPTV Recorder - by maiers12 - 2019-01-22, 13:55
RE: IPTV Recorder - by primaeval - 2019-01-22, 14:20
RE: IPTV Recorder - by maiers12 - 2019-01-22, 15:11
RE: IPTV Recorder - by dzejms - 2019-01-23, 12:35
RE: IPTV Recorder - by primaeval - 2019-01-23, 13:01
RE: IPTV Recorder - by dzejms - 2019-01-23, 13:46
RE: IPTV Recorder - by primaeval - 2019-01-23, 13:57
RE: IPTV Recorder - by dzejms - 2019-01-23, 13:56
RE: IPTV Recorder - by dzejms - 2019-01-23, 14:04
RE: IPTV Recorder - by primaeval - 2019-01-23, 14:10
RE: IPTV Recorder - by dzejms - 2019-01-23, 14:14
RE: IPTV Recorder - by primaeval - 2019-01-23, 14:37
RE: IPTV Recorder - by dzejms - 2019-01-23, 14:45
RE: IPTV Recorder - by dzejms - 2019-01-23, 17:05
RE: IPTV Recorder - by primaeval - 2019-01-23, 17:31
RE: IPTV Recorder - by maiers12 - 2019-01-27, 17:46
RE: IPTV Recorder - by primaeval - 2019-01-27, 18:20
RE: IPTV Recorder - by maiers12 - 2019-01-27, 19:17
RE: IPTV Recorder - by Nath_Explosion - 2019-01-27, 22:58
RE: IPTV Recorder - by primaeval - 2019-01-28, 11:07
IPTV Recorder - by ed_davidson01 - 2019-01-27, 23:38
RE: IPTV Recorder - by Nath_Explosion - 2019-01-27, 23:48
RE: IPTV Recorder - by Nath_Explosion - 2019-01-28, 13:55
RE: IPTV Recorder - by primaeval - 2019-01-28, 14:17
RE: IPTV Recorder - by Nath_Explosion - 2019-01-29, 12:03
RE: IPTV Recorder - by maiers12 - 2019-02-05, 13:56
RE: IPTV Recorder - by primaeval - 2019-02-05, 14:19
RE: IPTV Recorder - by maiers12 - 2019-02-05, 14:59
RE: IPTV Recorder - by primaeval - 2019-02-05, 16:23
RE: IPTV Recorder - by km4lin - 2019-02-07, 17:12
RE: IPTV Recorder - by primaeval - 2019-02-07, 17:28
RE: IPTV Recorder - by km4lin - 2019-02-07, 17:34
RE: IPTV Recorder - by primaeval - 2019-02-07, 17:55
RE: IPTV Recorder - by joerock - 2019-02-07, 21:37
RE: IPTV Recorder - by primaeval - 2019-02-07, 21:54
RE: IPTV Recorder - by joerock - 2019-02-07, 22:33
RE: IPTV Recorder - by primaeval - 2019-02-07, 22:46
RE: IPTV Recorder - by joerock - 2019-02-07, 22:40
RE: IPTV Recorder - by Laser78 - 2019-02-13, 00:16
RE: IPTV Recorder - by primaeval - 2019-02-13, 11:29
RE: IPTV Recorder - by Laser78 - 2019-02-13, 11:39
RE: IPTV Recorder - by primaeval - 2019-02-13, 11:45
IPTV Recorder - by Laser78 - 2019-02-13, 11:48
RE: IPTV Recorder - by Laser78 - 2019-02-13, 13:20
RE: IPTV Recorder - by primaeval - 2019-02-13, 13:23
RE: IPTV Recorder - by primaeval - 2019-02-13, 14:09
RE: IPTV Recorder - by Laser78 - 2019-02-13, 23:40
RE: IPTV Recorder - by Laser78 - 2019-02-14, 00:16
RE: IPTV Recorder - by primaeval - 2019-02-14, 00:28
RE: IPTV Recorder - by Laser78 - 2019-02-14, 00:30
RE: IPTV Recorder - by hsh24 - 2019-02-14, 02:55
RE: IPTV Recorder - by primaeval - 2019-02-14, 10:30
RE: IPTV Recorder - by hsh24 - 2019-02-15, 22:50
RE: IPTV Recorder - by primaeval - 2019-02-15, 23:00
RE: IPTV Recorder - by hsh24 - 2019-02-15, 23:14
RE: IPTV Recorder - by invincible - 2019-02-14, 19:26
RE: IPTV Recorder - by primaeval - 2019-02-14, 20:00
RE: IPTV Recorder - by primaeval - 2019-02-14, 20:55
RE: IPTV Recorder - by invincible - 2019-02-14, 21:05
RE: IPTV Recorder - by primaeval - 2019-02-14, 21:10
RE: IPTV Recorder - by invincible - 2019-02-14, 22:22
IPTV Recorder - by ed_davidson01 - 2019-02-15, 00:00
RE: IPTV Recorder - by maiers12 - 2019-02-16, 19:20
RE: IPTV Recorder - by primaeval - 2019-02-16, 21:18
RE: IPTV Recorder - by xpax - 2019-02-17, 15:31
RE: IPTV Recorder - by primaeval - 2019-02-17, 16:57
RE: IPTV Recorder - by kt666 - 2019-02-17, 22:01
RE: IPTV Recorder - by primaeval - 2019-02-17, 22:31
RE: IPTV Recorder - by kt666 - 2019-02-17, 23:20
RE: IPTV Recorder - by primaeval - 2019-02-17, 23:30
RE: IPTV Recorder - by primaeval - 2019-02-18, 12:01
RE: IPTV Recorder - by km4lin - 2019-02-18, 12:22
RE: IPTV Recorder - by primaeval - 2019-02-18, 12:26
RE: IPTV Recorder - by invincible - 2019-02-18, 13:19
RE: IPTV Recorder - by primaeval - 2019-02-18, 13:32
RE: IPTV Recorder - by primaeval - 2019-02-18, 14:53
RE: IPTV Recorder - by pirlone - 2019-02-18, 19:58
RE: IPTV Recorder - by pirlone - 2019-02-18, 20:08
RE: IPTV Recorder - by Timoty - 2019-02-18, 23:13
RE: IPTV Recorder - by primaeval - 2019-02-18, 23:53
RE: IPTV Recorder - by primaeval - 2019-02-19, 00:03
RE: IPTV Recorder - by Timoty - 2019-02-19, 00:42
RE: IPTV Recorder - by ed_davidson - 2019-02-19, 05:15
RE: IPTV Recorder - by primaeval - 2019-02-19, 09:37
RE: IPTV Recorder - by maiers12 - 2019-02-19, 17:27
RE: IPTV Recorder - by primaeval - 2019-02-19, 17:56
RE: IPTV Recorder - by maiers12 - 2019-02-19, 19:57
RE: IPTV Recorder - by maiers12 - 2019-02-21, 09:00
RE: IPTV Recorder - by primaeval - 2019-02-21, 10:25
RE: IPTV Recorder - by primaeval - 2019-02-21, 11:05
RE: IPTV Recorder - by maiers12 - 2019-02-21, 12:11
RE: IPTV Recorder - by primaeval - 2019-02-21, 12:15
RE: IPTV Recorder - by maiers12 - 2019-02-21, 13:01
RE: IPTV Recorder - by primaeval - 2019-02-21, 13:07
RE: IPTV Recorder - by maiers12 - 2019-02-21, 14:36
RE: IPTV Recorder - by primaeval - 2019-02-21, 14:59
RE: IPTV Recorder - by maiers12 - 2019-02-21, 15:00
RE: IPTV Recorder - by primaeval - 2019-02-21, 15:12
RE: IPTV Recorder - by maiers12 - 2019-02-21, 15:38
RE: IPTV Recorder - by primaeval - 2019-02-21, 15:42
RE: IPTV Recorder - by maiers12 - 2019-02-21, 16:18
RE: IPTV Recorder - by primaeval - 2019-02-21, 17:10
RE: IPTV Recorder - by invincible - 2019-02-19, 22:15
RE: IPTV Recorder - by primaeval - 2019-02-19, 22:26
RE: IPTV Recorder - by invincible - 2019-02-19, 22:31
RE: IPTV Recorder - by trutolo - 2019-02-20, 17:56
RE: IPTV Recorder - by primaeval - 2019-02-20, 18:01
RE: IPTV Recorder - by primaeval - 2019-02-21, 12:18
RE: IPTV Recorder - by trutolo - 2019-02-21, 13:42
RE: IPTV Recorder - by primaeval - 2019-02-21, 14:53
RE: IPTV Recorder - by primaeval - 2019-02-21, 20:16
RE: IPTV Recorder - by primaeval - 2019-02-21, 21:31
RE: IPTV Recorder - by mcxpert - 2019-02-21, 14:25
RE: IPTV Recorder - by primaeval - 2019-02-21, 17:14
RE: IPTV Recorder - by mcxpert - 2019-02-22, 10:14
RE: IPTV Recorder - by primaeval - 2019-02-22, 11:01
RE: IPTV Recorder - by mcxpert - 2019-02-22, 21:56
RE: IPTV Recorder - by primaeval - 2019-02-22, 22:03
RE: IPTV Recorder - by Spiderfish - 2019-02-22, 13:03
RE: IPTV Recorder - by primaeval - 2019-02-22, 13:27
RE: IPTV Recorder - by Spiderfish - 2019-02-22, 13:59
RE: IPTV Recorder - by primaeval - 2019-02-22, 14:01
RE: IPTV Recorder - by Spiderfish - 2019-02-22, 14:15
RE: IPTV Recorder - by mcxpert - 2019-02-22, 22:02
RE: IPTV Recorder - by mcxpert - 2019-02-22, 22:31
RE: IPTV Recorder - by mcxpert - 2019-02-22, 23:07
RE: IPTV Recorder - by primaeval - 2019-02-22, 23:21
RE: IPTV Recorder - by Laser78 - 2019-02-22, 23:56
RE: IPTV Recorder - by Laser78 - 2019-02-22, 23:59
RE: IPTV Recorder - by Laser78 - 2019-02-23, 01:55
RE: IPTV Recorder - by DarrenHill - 2019-02-23, 10:18
RE: IPTV Recorder - by Laser78 - 2019-02-23, 10:23
RE: IPTV Recorder - by primaeval - 2019-02-23, 11:23
RE: IPTV Recorder - by mcxpert - 2019-02-23, 15:21
RE: IPTV Recorder - by primaeval - 2019-02-23, 15:28
RE: IPTV Recorder - by mcxpert - 2019-02-24, 20:39
RE: IPTV Recorder - by primaeval - 2019-02-24, 20:53
RE: IPTV Recorder - by Laser78 - 2019-02-24, 10:16
RE: IPTV Recorder - by primaeval - 2019-02-24, 10:24
RE: IPTV Recorder - by Laser78 - 2019-02-24, 10:27
RE: IPTV Recorder - by primaeval - 2019-02-24, 10:31
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 14:28
RE: IPTV Recorder - by primaeval - 2019-02-23, 14:59
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 15:37
RE: IPTV Recorder - by primaeval - 2019-02-23, 15:40
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 15:41
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 15:45
RE: IPTV Recorder - by primaeval - 2019-02-23, 15:51
RE: IPTV Recorder - by 1deep - 2019-02-23, 22:54
RE: IPTV Recorder - by primaeval - 2019-02-24, 09:43
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 17:39
RE: IPTV Recorder - by primaeval - 2019-02-23, 18:02
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 18:14
RE: IPTV Recorder - by primaeval - 2019-02-23, 18:20
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 18:24
RE: IPTV Recorder - by Laser78 - 2019-02-24, 10:34
RE: IPTV Recorder - by Laser78 - 2019-02-24, 10:42
RE: IPTV Recorder - by primaeval - 2019-02-24, 11:32
RE: IPTV Recorder - by mcxpert - 2019-02-24, 21:24
RE: IPTV Recorder - by primaeval - 2019-02-24, 22:23
RE: IPTV Recorder - by beatmasterrs - 2019-02-24, 22:43
RE: IPTV Recorder - by primaeval - 2019-02-24, 23:01
RE: IPTV Recorder - by beatmasterrs - 2019-02-24, 23:30
RE: IPTV Recorder - by primaeval - 2019-02-25, 09:54
RE: IPTV Recorder - by beatmasterrs - 2019-02-25, 10:10
RE: IPTV Recorder - by Laser78 - 2019-02-24, 22:47
RE: IPTV Recorder - by primaeval - 2019-02-24, 23:05
RE: IPTV Recorder - by Laser78 - 2019-02-24, 23:10
RE: IPTV Recorder - by primaeval - 2019-02-24, 23:25
RE: IPTV Recorder - by Laser78 - 2019-02-25, 22:29
RE: IPTV Recorder - by samueljones - 2019-02-26, 02:39
RE: IPTV Recorder - by primaeval - 2019-02-26, 09:21
IPTV Recorder - by ed_davidson01 - 2019-02-26, 05:59
IPTV Recorder - by ed_davidson01 - 2019-02-26, 06:01
RE: IPTV Recorder - by mcxpert - 2019-02-26, 09:21
RE: IPTV Recorder - by Laser78 - 2019-02-26, 09:26
RE: IPTV Recorder - by samueljones - 2019-02-26, 14:55
RE: IPTV Recorder - by mcxpert - 2019-02-26, 21:51
RE: IPTV Recorder - by primaeval - 2019-02-26, 22:00
RE: IPTV Recorder - by mcxpert - 2019-02-27, 10:02
RE: IPTV Recorder - by primaeval - 2019-02-27, 11:11
RE: IPTV Recorder - by mcxpert - 2019-02-27, 22:20
RE: IPTV Recorder - by Foxxyfox - 2019-02-27, 12:42
RE: IPTV Recorder - by primaeval - 2019-02-27, 13:30
RE: IPTV Recorder - by Foxxyfox - 2019-02-27, 18:22
RE: IPTV Recorder - by primaeval - 2019-02-27, 18:30
RE: IPTV Recorder - by giaur - 2019-03-01, 00:06
RE: IPTV Recorder - by dzejms - 2019-03-01, 01:00
RE: IPTV Recorder - by primaeval - 2019-03-01, 09:10
IPTV Recorder - by ed_davidson01 - 2019-03-01, 01:07
RE: IPTV Recorder - by giaur - 2019-03-01, 02:09
RE: IPTV Recorder - by Hoggens - 2019-03-01, 08:52
RE: IPTV Recorder - by primaeval - 2019-03-01, 09:42
RE: IPTV Recorder - by mcxpert - 2019-03-01, 15:13
RE: IPTV Recorder - by primaeval - 2019-03-01, 15:33
RE: IPTV Recorder - by Hoggens - 2019-03-02, 13:23
RE: IPTV Recorder - by Nathcloud9 - 2019-03-02, 20:35
RE: IPTV Recorder - by primaeval - 2019-03-02, 21:38
RE: IPTV Recorder - by Laser78 - 2019-03-04, 17:37
RE: IPTV Recorder - by primaeval - 2019-03-04, 18:17
RE: IPTV Recorder - by Laser78 - 2019-03-04, 18:43
RE: IPTV Recorder - by primaeval - 2019-03-04, 19:28
RE: IPTV Recorder - by Laser78 - 2019-03-04, 20:36
IPTV Recorder - by Laser78 - 2019-03-04, 23:25
RE: IPTV Recorder - by primaeval - 2019-03-05, 09:28
RE: IPTV Recorder - by CpTHOOK - 2019-03-05, 00:29
RE: IPTV Recorder - by primaeval - 2019-03-05, 09:33
RE: IPTV Recorder - by CpTHOOK - 2019-03-06, 05:24
RE: IPTV Recorder - by primaeval - 2019-03-06, 09:20
RE: IPTV Recorder - by CpTHOOK - 2019-03-07, 05:35
RE: IPTV Recorder - by primaeval - 2019-03-07, 09:46
RE: IPTV Recorder - by CpTHOOK - 2019-03-08, 00:06
RE: IPTV Recorder - by primaeval - 2019-03-08, 09:26
RE: IPTV Recorder - by CpTHOOK - 2019-03-08, 17:51
RE: IPTV Recorder - by primaeval - 2019-03-08, 18:03
RE: IPTV Recorder - by Laser78 - 2019-03-05, 10:04
RE: IPTV Recorder - by primaeval - 2019-03-05, 10:10
RE: IPTV Recorder - by Laser78 - 2019-03-06, 00:37
RE: IPTV Recorder - by primaeval - 2019-03-06, 09:21
RE: IPTV Recorder - by dzejms - 2019-03-06, 12:42
RE: IPTV Recorder - by primaeval - 2019-03-06, 12:52
RE: IPTV Recorder - by dzejms - 2019-03-06, 13:05
RE: IPTV Recorder - by primaeval - 2019-03-06, 13:34
RE: IPTV Recorder - by dzejms - 2019-03-06, 13:56
RE: IPTV Recorder - by primaeval - 2019-03-06, 14:06
IPTV Recorder - by ed_davidson01 - 2019-03-08, 22:52
RE: IPTV Recorder - by CpTHOOK - 2019-03-09, 18:55
RE: IPTV Recorder - by primaeval - 2019-03-09, 19:21
RE: IPTV Recorder - by CpTHOOK - 2019-03-09, 20:04
RE: IPTV Recorder - by primaeval - 2019-03-09, 20:14
RE: IPTV Recorder - by CpTHOOK - 2019-03-09, 20:27
RE: IPTV Recorder - by primaeval - 2019-03-09, 20:54
RE: IPTV Recorder - by Laser78 - 2019-03-10, 01:04
RE: IPTV Recorder - by primaeval - 2019-03-10, 09:03
RE: IPTV Recorder - by Laser78 - 2019-03-10, 09:49
RE: IPTV Recorder - by primaeval - 2019-03-10, 10:55
RE: IPTV Recorder - by Laser78 - 2019-03-10, 12:14
RE: IPTV Recorder - by Spiderfish - 2019-03-10, 19:57
RE: IPTV Recorder - by primaeval - 2019-03-10, 20:29
RE: IPTV Recorder - by mcxpert - 2019-03-10, 20:32
RE: IPTV Recorder - by mcxpert - 2019-03-12, 09:28
IPTV Recorder - by ed_davidson01 - 2019-03-12, 16:24
RE: IPTV Recorder - by mcxpert - 2019-03-12, 17:48
RE: IPTV Recorder - by primaeval - 2019-03-13, 22:06
RE: IPTV Recorder - by Minefield247 - 2019-03-14, 14:08
RE: IPTV Recorder - by primaeval - 2019-03-14, 15:24
IPTV Recorder - by ed_davidson01 - 2019-03-14, 15:52
RE: IPTV Recorder - by primaeval - 2019-03-14, 16:08
RE: IPTV Recorder - by Minefield247 - 2019-03-14, 16:11
RE: IPTV Recorder - by primaeval - 2019-03-14, 16:16
RE: IPTV Recorder - by primaeval - 2019-03-14, 16:52
RE: IPTV Recorder - by Gordon Bleu - 2019-03-14, 17:00
RE: IPTV Recorder - by primaeval - 2019-03-14, 17:22
IPTV Recorder - by ed_davidson01 - 2019-03-14, 17:04
RE: IPTV Recorder - by primaeval - 2019-03-14, 17:11
RE: IPTV Recorder - by primaeval - 2019-03-15, 16:25
RE: IPTV Recorder - by Gordon Bleu - 2019-03-15, 10:05
RE: IPTV Recorder - by primaeval - 2019-03-15, 14:46
IPTV Recorder - by ed_davidson01 - 2019-03-15, 16:27
IPTV Recorder - by ed_davidson01 - 2019-03-15, 16:29
RE: IPTV Recorder - by primaeval - 2019-03-15, 17:49
IPTV Recorder - by ed_davidson01 - 2019-03-15, 17:56
IPTV Recorder - by ed_davidson01 - 2019-03-16, 21:52
RE: IPTV Recorder - by primaeval - 2019-03-16, 22:47
IPTV Recorder - by ed_davidson01 - 2019-03-17, 02:44
RE: IPTV Recorder - by encol - 2019-03-17, 12:11
RE: IPTV Recorder - by primaeval - 2019-03-17, 12:18
RE: IPTV Recorder - by encol - 2019-03-17, 12:24
RE: IPTV Recorder - by primaeval - 2019-03-17, 12:59
RE: IPTV Recorder - by encol - 2019-03-17, 13:06
RE: IPTV Recorder - by encol - 2019-03-17, 13:24
RE: IPTV Recorder - by primaeval - 2019-03-17, 14:06
RE: IPTV Recorder - by primaeval - 2019-03-17, 17:17
IPTV Recorder - by ed_davidson01 - 2019-03-17, 15:10
RE: IPTV Recorder - by encol - 2019-03-17, 15:26
RE: IPTV Recorder - by encol - 2019-03-17, 15:29
IPTV Recorder - by ed_davidson01 - 2019-03-17, 16:42
RE: IPTV Recorder - by encol - 2019-03-17, 18:56
RE: IPTV Recorder - by primaeval - 2019-03-17, 19:52
RE: IPTV Recorder - by encol - 2019-03-17, 21:44
RE: IPTV Recorder - by primaeval - 2019-03-17, 22:12
RE: IPTV Recorder - by encol - 2019-03-17, 22:26
RE: IPTV Recorder - by primaeval - 2019-03-17, 22:34
RE: IPTV Recorder - by encol - 2019-03-17, 22:38
RE: IPTV Recorder - by primaeval - 2019-03-17, 23:09
RE: IPTV Recorder - by encol - 2019-03-17, 23:55
RE: IPTV Recorder - by primaeval - 2019-03-18, 10:02
RE: IPTV Recorder - by encol - 2019-03-18, 11:14
RE: IPTV Recorder - by primaeval - 2019-03-18, 11:48
RE: IPTV Recorder - by encol - 2019-03-18, 12:12
RE: IPTV Recorder - by primaeval - 2019-03-18, 12:26
IPTV Recorder - by ed_davidson01 - 2019-03-18, 15:23
RE: IPTV Recorder - by primaeval - 2019-03-18, 15:26
IPTV Recorder - by ed_davidson01 - 2019-03-18, 15:33
IPTV Recorder - by ed_davidson01 - 2019-03-18, 15:35
RE: IPTV Recorder - by encol - 2019-03-18, 15:59
RE: IPTV Recorder - by primaeval - 2019-03-18, 16:24
RE: IPTV Recorder - by encol - 2019-03-18, 16:25
RE: IPTV Recorder - by primaeval - 2019-03-18, 16:28
RE: IPTV Recorder - by primaeval - 2019-03-18, 16:30
RE: IPTV Recorder - by encol - 2019-03-21, 18:22
RE: IPTV Recorder - by primaeval - 2019-03-21, 18:31
RE: IPTV Recorder - by encol - 2019-03-21, 19:26
RE: IPTV Recorder - by primaeval - 2019-03-21, 19:49
RE: IPTV Recorder - by encol - 2019-03-21, 19:55
RE: IPTV Recorder - by primaeval - 2019-03-21, 20:00
RE: IPTV Recorder - by encol - 2019-03-25, 10:51
RE: IPTV Recorder - by primaeval - 2019-03-25, 11:18
RE: IPTV Recorder - by encol - 2019-03-25, 12:49
RE: IPTV Recorder - by encol - 2019-03-18, 17:57
IPTV Recorder - by ed_davidson01 - 2019-03-18, 20:12
RE: IPTV Recorder - by primaeval - 2019-03-18, 21:25
IPTV Recorder - by ed_davidson01 - 2019-03-18, 21:37
IPTV Recorder - by ed_davidson01 - 2019-03-18, 23:02
RE: IPTV Recorder - by invincible - 2019-03-19, 00:35
RE: IPTV Recorder - by primaeval - 2019-03-19, 08:48
RE: IPTV Recorder - by invincible - 2019-03-19, 22:17
RE: IPTV Recorder - by primaeval - 2019-03-19, 22:24
RE: IPTV Recorder - by samueljones - 2019-03-19, 16:38
RE: IPTV Recorder - by primaeval - 2019-03-19, 17:10
RE: IPTV Recorder - by invincible - 2019-03-19, 18:33
RE: IPTV Recorder - by primaeval - 2019-03-19, 18:37
RE: IPTV Recorder - by McDaz - 2019-03-19, 23:30
RE: IPTV Recorder - by primaeval - 2019-03-20, 08:45
RE: IPTV Recorder - by Abba2 - 2019-03-22, 18:25
RE: IPTV Recorder - by primaeval - 2019-03-22, 18:50
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 21:59
RE: IPTV Recorder - by primaeval - 2019-03-24, 22:15
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 22:28
RE: IPTV Recorder - by primaeval - 2019-03-24, 22:31
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:01
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:05
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:08
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:11
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:20
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:26
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:37
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:41
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:45
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:48
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:54
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:58
RE: IPTV Recorder - by primaeval - 2019-03-25, 00:02
RE: IPTV Recorder - by Nathcloud9 - 2019-03-25, 00:30
RE: IPTV Recorder - by invincible - 2019-03-25, 09:21
RE: IPTV Recorder - by darealwy - 2019-03-25, 20:03
RE: IPTV Recorder - by primaeval - 2019-03-25, 20:33
IPTV Recorder - by ed_davidson01 - 2019-03-30, 05:21
RE: IPTV Recorder - by primaeval - 2019-03-30, 08:44
RE: IPTV Recorder - by pirlone - 2019-03-31, 08:30
RE: IPTV Recorder - by primaeval - 2019-03-31, 08:41
RE: IPTV Recorder - by pirlone - 2019-03-31, 14:31
RE: IPTV Recorder - by primaeval - 2019-03-31, 15:27
RE: IPTV Recorder - by pirlone - 2019-03-31, 15:31
RE: IPTV Recorder - by primaeval - 2019-03-31, 15:40
RE: IPTV Recorder - by Ampsys - 2019-04-07, 01:33
RE: IPTV Recorder - by primaeval - 2019-04-07, 08:09
RE: IPTV Recorder - by Ampsys - 2019-04-07, 22:13
RE: IPTV Recorder - by Ampsys - 2019-04-07, 22:17
RE: IPTV Recorder - by Ampsys - 2019-04-07, 22:37
RE: IPTV Recorder - by primaeval - 2019-04-08, 09:04
RE: IPTV Recorder - by Ampsys - 2019-04-09, 01:51
RE: IPTV Recorder - by primaeval - 2019-04-09, 07:48
RE: IPTV Recorder - by Ampsys - 2019-04-09, 16:11
RE: IPTV Recorder - by primaeval - 2019-04-09, 17:37
RE: IPTV Recorder - by Ampsys - 2019-04-09, 18:59
RE: IPTV Recorder - by primaeval - 2019-04-09, 19:08
RE: IPTV Recorder - by Ampsys - 2019-04-09, 19:33
RE: IPTV Recorder - by primaeval - 2019-04-09, 19:48
RE: IPTV Recorder - by DarrenHill - 2019-04-08, 09:23
RE: IPTV Recorder - by primaeval - 2019-04-08, 09:27
RE: IPTV Recorder - by lagman - 2019-04-08, 16:17
RE: IPTV Recorder - by lagman - 2019-04-08, 16:25
RE: IPTV Recorder - by primaeval - 2019-04-08, 16:39
RE: IPTV Recorder - by lagman - 2019-04-08, 19:01
RE: IPTV Recorder - by primaeval - 2019-04-08, 19:26
RE: IPTV Recorder - by Ampsys - 2019-04-09, 19:45
RE: IPTV Recorder - by lagman - 2019-04-09, 19:57
RE: IPTV Recorder - by primaeval - 2019-04-09, 20:12
RE: IPTV Recorder - by lagman - 2019-04-09, 23:03
RE: IPTV Recorder - by primaeval - 2019-04-10, 08:24
RE: IPTV Recorder - by lagman - 2019-04-10, 13:18
RE: IPTV Recorder - by primaeval - 2019-04-10, 13:30
RE: IPTV Recorder - by lagman - 2019-04-10, 16:14
RE: IPTV Recorder - by primaeval - 2019-04-10, 17:05
RE: IPTV Recorder - by lagman - 2019-04-10, 17:20
RE: IPTV Recorder - by primaeval - 2019-04-10, 17:33
RE: IPTV Recorder - by lagman - 2019-04-10, 18:02
RE: IPTV Recorder - by primaeval - 2019-04-10, 18:14
RE: IPTV Recorder - by lagman - 2019-04-10, 18:37
RE: IPTV Recorder - by primaeval - 2019-04-10, 18:53
RE: IPTV Recorder - by primaeval - 2019-04-12, 21:10
RE: IPTV Recorder - by lagman - 2019-04-15, 18:46
IPTV Recorder - by ed_davidson01 - 2019-04-11, 02:57
RE: IPTV Recorder - by lagman - 2019-04-12, 20:53
RE: IPTV Recorder - by DarrenHill - 2019-04-12, 22:29
IPTV Recorder - by ed_davidson01 - 2019-04-13, 05:35
RE: IPTV Recorder - by lagman - 2019-04-15, 02:31
RE: IPTV Recorder - by ed_davidson - 2019-04-15, 02:46
RE: IPTV Recorder - by lagman - 2019-04-15, 18:44
RE: IPTV Recorder - by kaner007 - 2019-04-19, 19:10
RE: IPTV Recorder - by primaeval - 2019-04-19, 19:41
RE: IPTV Recorder - by kaner007 - 2019-04-19, 20:37
RE: IPTV Recorder - by primaeval - 2019-04-19, 20:47
RE: IPTV Recorder - by kaner007 - 2019-04-19, 21:24
RE: IPTV Recorder - by primaeval - 2019-04-19, 21:27
RE: IPTV Recorder - by kaner007 - 2019-04-19, 22:05
RE: IPTV Recorder - by primaeval - 2019-04-20, 08:20
RE: IPTV Recorder - by kaner007 - 2019-04-20, 08:58
RE: IPTV Recorder - by primaeval - 2019-04-20, 09:21
RE: IPTV Recorder - by kaner007 - 2019-04-20, 10:06
RE: IPTV Recorder - by primaeval - 2019-04-20, 10:10
RE: IPTV Recorder - by kaner007 - 2019-04-20, 10:49
RE: IPTV Recorder - by primaeval - 2019-04-20, 11:02
RE: IPTV Recorder - by kaner007 - 2019-04-19, 22:30
RE: IPTV Recorder - by DarrenHill - 2019-04-20, 11:50
RE: IPTV Recorder - by primaeval - 2019-04-20, 12:02
RE: IPTV Recorder - by kaner007 - 2019-04-20, 12:27
RE: IPTV Recorder - by primaeval - 2019-04-20, 12:38
RE: IPTV Recorder - by kaner007 - 2019-04-20, 14:02
RE: IPTV Recorder - by primaeval - 2019-04-20, 14:11
RE: IPTV Recorder - by kaner007 - 2019-04-20, 14:19
RE: IPTV Recorder - by zloty777 - 2019-04-22, 14:13
RE: IPTV Recorder - by primaeval - 2019-04-22, 14:23
RE: IPTV Recorder - by zloty777 - 2019-04-22, 21:37
RE: IPTV Recorder - by primaeval - 2019-04-22, 21:55
RE: IPTV Recorder - by zloty777 - 2019-04-22, 22:12
RE: IPTV Recorder - by zloty777 - 2019-04-22, 22:14
RE: IPTV Recorder - by primaeval - 2019-04-22, 22:19
RE: IPTV Recorder - by zloty777 - 2019-04-22, 23:10
RE: IPTV Recorder - by primaeval - 2019-04-23, 08:56
RE: IPTV Recorder - by zloty777 - 2019-04-23, 14:18
RE: IPTV Recorder - by zloty777 - 2019-04-23, 15:50
RE: IPTV Recorder - by primaeval - 2019-04-23, 16:01
RE: IPTV Recorder - by zloty777 - 2019-04-22, 21:39
RE: IPTV Recorder - by Atamans - 2019-04-26, 14:43
RE: IPTV Recorder - by primaeval - 2019-04-26, 14:51
RE: IPTV Recorder - by Atamans - 2019-04-26, 15:00
RE: IPTV Recorder - by primaeval - 2019-04-26, 15:03
RE: IPTV Recorder - by Atamans - 2019-04-26, 15:07
RE: IPTV Recorder - by primaeval - 2019-04-26, 15:14
RE: IPTV Recorder - by Atamans - 2019-04-26, 15:33
RE: IPTV Recorder - by primaeval - 2019-04-26, 15:38
RE: IPTV Recorder - by Atamans - 2019-04-26, 16:11
RE: IPTV Recorder - by primaeval - 2019-04-26, 16:20
RE: IPTV Recorder - by Atamans - 2019-04-26, 16:26
RE: IPTV Recorder - by primaeval - 2019-04-26, 16:31
RE: IPTV Recorder - by Atamans - 2019-04-26, 16:41
RE: IPTV Recorder - by primaeval - 2019-04-26, 16:45
RE: IPTV Recorder - by Atamans - 2019-04-26, 17:17
RE: IPTV Recorder - by Radikaal - 2019-04-26, 17:52
RE: IPTV Recorder - by primaeval - 2019-04-26, 18:04
RE: IPTV Recorder - by Radikaal - 2019-04-27, 23:34
RE: IPTV Recorder - by primaeval - 2019-04-28, 09:25
RE: IPTV Recorder - by Atamans - 2019-04-27, 04:43
IPTV Recorder - by Abba2 - 2019-04-28, 22:07
RE: IPTV Recorder - by primaeval - 2019-04-28, 22:16
RE: IPTV Recorder - by Abba2 - 2019-04-28, 22:52
RE: IPTV Recorder - by Abba2 - 2019-04-28, 23:02
RE: IPTV Recorder - by primaeval - 2019-04-29, 08:56
RE: IPTV Recorder - by Abba2 - 2019-04-29, 13:02
RE: IPTV Recorder - by primaeval - 2019-04-29, 13:18
RE: IPTV Recorder - by Radikaal - 2019-04-29, 19:03
RE: IPTV Recorder - by primaeval - 2019-04-29, 19:09
RE: IPTV Recorder - by Abba2 - 2019-04-29, 23:59
RE: IPTV Recorder - by primaeval - 2019-04-30, 08:35
RE: IPTV Recorder - by Abba2 - 2019-04-30, 10:08
RE: IPTV Recorder - by primaeval - 2019-04-30, 10:32
RE: IPTV Recorder - by Abba2 - 2019-04-30, 13:01
RE: IPTV Recorder - by Abba2 - 2019-04-30, 13:03
RE: IPTV Recorder - by primaeval - 2019-04-30, 13:20
RE: IPTV Recorder - by luna128 - 2019-05-01, 00:52
RE: IPTV Recorder - by primaeval - 2019-05-01, 08:14
RE: IPTV Recorder - by luna128 - 2019-05-01, 20:48
RE: IPTV Recorder - by primaeval - 2019-05-01, 20:54
RE: IPTV Recorder - by luna128 - 2019-05-02, 00:07
RE: IPTV Recorder - by primaeval - 2019-05-02, 08:44
RE: IPTV Recorder - by luna128 - 2019-05-03, 01:45
RE: IPTV Recorder - by primaeval - 2019-05-03, 08:25
RE: IPTV Recorder - by erikprimo - 2019-05-02, 14:57
RE: IPTV Recorder - by primaeval - 2019-05-02, 15:05
RE: IPTV Recorder - by erikprimo - 2019-05-02, 15:57
RE: IPTV Recorder - by primaeval - 2019-05-02, 16:15
RE: IPTV Recorder - by erikprimo - 2019-05-02, 17:50
RE: IPTV Recorder - by primaeval - 2019-05-02, 19:06
IPTV Recorder - by ed_davidson01 - 2019-05-03, 03:59
RE: IPTV Recorder - by luna128 - 2019-05-03, 04:39
IPTV Recorder - by ed_davidson01 - 2019-05-03, 14:54
RE: IPTV Recorder - by samueljones - 2019-05-04, 18:22
RE: IPTV Recorder - by primaeval - 2019-05-04, 18:36
RE: IPTV Recorder - by samueljones - 2019-05-04, 19:53
RE: IPTV Recorder - by primaeval - 2019-05-04, 19:57
RE: IPTV Recorder - by samueljones - 2019-05-04, 20:02
RE: IPTV Recorder - by primaeval - 2019-05-04, 20:03
RE: IPTV Recorder - by samueljones - 2019-05-04, 20:07
RE: IPTV Recorder - by primaeval - 2019-05-04, 20:14
RE: IPTV Recorder - by samueljones - 2019-05-04, 20:18
RE: IPTV Recorder - by Abba2 - 2019-05-04, 22:45
RE: IPTV Recorder - by primaeval - 2019-05-05, 07:34
RE: IPTV Recorder - by rossi29 - 2019-05-05, 09:51
RE: IPTV Recorder - by primaeval - 2019-05-05, 09:56
RE: IPTV Recorder - by rossi29 - 2019-05-05, 13:28
RE: IPTV Recorder - by primaeval - 2019-05-05, 13:32
RE: IPTV Recorder - by Abba2 - 2019-05-05, 09:57
RE: IPTV Recorder - by primaeval - 2019-05-05, 09:58
RE: IPTV Recorder - by Abba2 - 2019-05-05, 13:19
RE: IPTV Recorder - by primaeval - 2019-05-05, 13:27
IPTV Recorder - by Abba2 - 2019-05-09, 02:06
RE: IPTV Recorder - by primaeval - 2019-05-09, 08:17
RE: IPTV Recorder - by Atamans - 2019-05-10, 10:03
RE: IPTV Recorder - by ramia - 2019-05-14, 02:53
RE: IPTV Recorder - by berkhornet - 2019-05-14, 15:41
RE: IPTV Recorder - by Atamans - 2019-05-14, 21:48
RE: IPTV Recorder - by berkhornet - 2019-05-15, 09:40
RE: IPTV Recorder - by Atamans - 2019-05-15, 11:15
IPTV Recorder - by berkhornet - 2019-05-15, 15:09
RE: IPTV Recorder - by fabd - 2019-05-16, 21:36
RE: IPTV Recorder - by seveneleven - 2019-05-22, 23:07
RE: IPTV Recorder - by Laser78 - 2019-05-26, 20:05
RE: IPTV Recorder - by giaur - 2019-05-29, 19:08
RE: IPTV Recorder - by mixpc - 2019-06-14, 14:25
RE: IPTV Recorder - by jhr1948 - 2019-06-14, 20:05
RE: IPTV Recorder - by ray2301 - 2019-11-11, 03:55
RE: IPTV Recorder - by Elluminatus - 2019-07-09, 10:36
RE: IPTV Recorder - by DarrenHill - 2019-07-09, 10:55
IPTV Recorder - by ZeroZorro - 2019-07-09, 11:57
RE: IPTV Recorder - by bartek35355 - 2019-07-24, 16:24
RE: IPTV Recorder - by VaderP - 2019-08-09, 00:18
RE: IPTV Recorder - by seveneleven - 2019-08-13, 00:26
RE: IPTV Recorder - by jarlaxx - 2019-09-01, 23:52
RE: IPTV Recorder - by jarlaxx - 2019-09-02, 04:54
RE: IPTV Recorder - by ramia - 2019-09-05, 08:31
RE: IPTV Recorder - by Arber - 2019-09-05, 11:16
RE: IPTV Recorder - by ramia - 2019-09-05, 16:52
RE: IPTV Recorder - by Arber - 2019-09-07, 10:14
RE: IPTV Recorder - by ramia - 2019-09-07, 19:15
RE: IPTV Recorder - by Nappis - 2019-09-07, 08:35
RE: IPTV Recorder - by Foxxyfox - 2019-09-07, 12:16
RE: IPTV Recorder - by DarrenHill - 2019-09-07, 20:37
RE: IPTV Recorder - by ramia - 2019-09-08, 02:08
RE: IPTV Recorder - by DarrenHill - 2019-09-08, 10:28
RE: IPTV Recorder - by ramia - 2019-09-08, 15:15
RE: IPTV Recorder - by DarrenHill - 2019-09-08, 15:27
RE: IPTV Recorder - by chezpaul - 2019-09-12, 23:01
RE: IPTV Recorder - by conFigureThat - 2019-10-13, 16:45
RE: IPTV Recorder - by conFigureThat - 2019-11-13, 08:19
RE: IPTV Recorder - by ryadre - 2019-11-09, 06:32
RE: IPTV Recorder - by mwkurt - 2019-11-10, 00:51
RE: IPTV Recorder - by Gtmnyc - 2019-11-10, 06:30
RE: IPTV Recorder - by mwkurt - 2019-11-18, 17:45
RE: IPTV Recorder - by snoopyjoe - 2019-11-20, 23:13
RE: IPTV Recorder - by conFigureThat - 2019-12-19, 21:33
RE: IPTV Recorder - by PeterWeb - 2019-12-19, 23:23
RE: IPTV Recorder - by thestupidbloke - 2019-12-28, 17:13
RE: IPTV Recorder - by powermarcel10 - 2019-12-28, 17:53
RE: IPTV Recorder - by thestupidbloke - 2019-12-28, 23:18
RE: IPTV Recorder - by powermarcel10 - 2020-01-02, 15:20
RE: IPTV Recorder - by Matt Sculley - 2019-12-29, 06:08
RE: IPTV Recorder - by thestupidbloke - 2019-12-30, 01:12
RE: IPTV Recorder - by Matt Sculley - 2019-12-30, 03:26
RE: IPTV Recorder - by thestupidbloke - 2019-12-30, 04:51
RE: IPTV Recorder - by damagom - 2020-01-01, 13:06
RE: IPTV Recorder - by dzejms - 2020-01-03, 20:51
RE: IPTV Recorder - by fcalcav - 2020-01-04, 22:40
RE: IPTV Recorder - by Erario - 2020-01-13, 09:20
RE: IPTV Recorder - by dzejms - 2020-01-13, 18:18
RE: IPTV Recorder - by Erario - 2020-01-13, 20:32
RE: IPTV Recorder - by pdario - 2020-01-16, 11:14
RE: IPTV Recorder - by dzejms - 2020-01-19, 14:37
RE: IPTV Recorder - by taker-` - 2020-01-27, 11:21
IPTV Recorder54
