2019-04-27, 23:34
(2019-04-26, 18:04)primaeval Wrote:(2019-04-26, 17:52)Radikaal Wrote: Hello. Has anyone found a working ffmpeg for android shield (2017 version) with the latest kodi? I managed to get it work about a week ago with what i think was "armeabi-v7a" that was mentioned in this thread, since then i have upgraded my internal storage to a SSD, after that i have been keep getting "ffmpeg exe not found" everytime i try to record something. I factory resetted, nuked, tried downloading alot of ffmpegs (not sure if im doing this part right) by downloading, extracting and then point to fmpeg i just extracted (under Jobs and Rules in iptvrecorder settings). Everytime no matter that version of ffmpeg i point to i get the same error in the right upper corner when i try to record something, ffmpeg exe not found.
I downloaded droidinfo and saw i had arm64-v8a as architecture. I tried downloading arm64-v8a-full.tar.bz2 and then point to it after extracting, same thing happens.
Any help would be appreciated if someone had a similar issue and found a fix.
The ssd installation could have messed up the folder locations and ffmpeg permissions.
To make sure IPTV Recorder overwrites the old ffmpeg version, rename the new ffmpeg to something else like ffmpeg.new
Only if the filename location is different than before will it try to overwrite the old version.
If you have rooted your shield you could delete the old ffmpeg version directly.
It should be in /data/data at the top of the kodi folder.
thanks for the reply, it seems it was indeed the ssd messing it up. It started working after ejecting the ssd, reinstalling kodi on the "normal" storage then making the ssd internal again. Luckily Kodi stayed on the "old" internal with a few other apps after data migrate and then it worked first try with arm64-v8a. Is there btw any way to make the recordings to go anywhere other then a "hidden" kodi folder? (or make that folder unhidden) The recordings can still be opened within kodi but it would be nice to be able to have them directly to a plex media server for example which seem to not support hidden files.
