2019-05-01, 20:54
(2019-05-01, 20:48)luna128 Wrote:(2019-05-01, 08:14)primaeval Wrote: Are there any error messages in kodi.log to do with plugin.video.iptv.recorder?Not that I can see.
(2019-05-01, 08:14)primaeval Wrote: Is it just the Record and Play function that doesn't work from the IPTV Recorder Timer context menu for the same channel?Yes, just Record and Play.
(2019-05-01, 08:14)primaeval Wrote: Does Add Timed Recording work?Yes, perfectly as intended.
(2019-05-01, 08:14)primaeval Wrote: Does the IPTV Recorder button on the Program Information dialog record for the same channel?Yes.
(2019-05-01, 08:14)primaeval Wrote: What skin are you using?Your official fork of Estuary for IPTV Recorder.
(2019-05-01, 08:14)primaeval Wrote: What Kodi regional setting are you using?USA [12h]. 24h doesn't work, either.
Hardware is a 2nd Gen Fire TV unit. Leia.
Curiously, the job I had been trying to set with Record and Play seemed to take upon a random reboot I did of Kodi for a separate reason, and everything worked. I haven't been able to reproduce this behavior, but it did make me notice that the Record jobs from my Record and Play commands were being processed and moved into the active jobs directory under maintenance, but were not executing.
I'm going to do some hard resetting and I'll get back to you soon. Thanks for the free software.
What version of kodi are you using?
I wonder if there have been some changes with the way Kodi caches links.
