Release IPTV Recorder
(2019-05-02, 17:50)erikprimo Wrote:
(2019-05-02, 16:15)primaeval Wrote:
(2019-05-02, 15:57)erikprimo Wrote: Thank you for your help. I am still getting program not found when I try to record in Simple IPTV Sad
The program that is not found is the tv program not ffmpeg.
The same xmltv and m3us need to be loaded in both IPTV Simple Client and IPTV Recorder.
IPTV Recorder will try to load the IPTV Simple Client xmltv and m3u files 60 seconds after Kodi starts.
Make sure you can record directly from the IPTV Recorder addon first by going into the Channel Groups folder.
Check if the program you are trying to record from IPTV Simple Client is in the Channel Groups folder.
If that works then we need to find out why they aren't getting matched.
update: reading from the iptv recorder also does not record
When I try to record from the channel group nothing happens. I tried the record and watch and it just sits there.  Aslo I see in the IPTV recorder settings its reading from the IPTV simple client m3u and xmltv files... could that be the issue ? I so want this to work haha
In
Channel Groups \ All Channels
there should be your channels.
In the channels should be programs.
In the programs should be a list of things you can do like Record or Watch.
How far do you get?
IPTV Recorder - by primaeval - 2018-03-22, 12:03
RE: IPTV Recorder - by locoguano - 2018-03-23, 04:56
RE: IPTV Recorder - by primaeval - 2018-03-23, 09:53
RE: IPTV Recorder - by locoguano - 2018-03-23, 14:18
RE: IPTV Recorder - by primaeval - 2018-03-23, 14:23
RE: IPTV Recorder - by primaeval - 2018-03-23, 15:50
RE: IPTV Recorder - by coremailrx8 - 2018-03-23, 17:43
RE: IPTV Recorder - by primaeval - 2018-03-23, 18:03
RE: IPTV Recorder - by primaeval - 2018-03-23, 18:15
RE: IPTV Recorder - by ray2301 - 2018-03-23, 18:56
RE: IPTV Recorder - by primaeval - 2018-03-23, 21:24
RE: IPTV Recorder - by primaeval - 2018-03-23, 21:41
RE: IPTV Recorder - by ray2301 - 2018-03-24, 01:41
RE: IPTV Recorder - by primaeval - 2018-03-24, 08:57
RE: IPTV Recorder - by primaeval - 2018-03-24, 17:49
RE: IPTV Recorder - by locoguano - 2018-03-24, 20:14
RE: IPTV Recorder - by primaeval - 2018-03-24, 18:35
RE: IPTV Recorder - by ray2301 - 2018-03-24, 20:11
RE: IPTV Recorder - by ray2301 - 2018-03-24, 20:59
RE: IPTV Recorder - by primaeval - 2018-03-24, 21:12
RE: IPTV Recorder - by Chychy - 2018-03-24, 21:15
RE: IPTV Recorder - by primaeval - 2018-03-24, 21:25
RE: IPTV Recorder - by Chychy - 2018-03-24, 21:32
RE: IPTV Recorder - by primaeval - 2018-03-24, 21:49
RE: IPTV Recorder - by ray2301 - 2018-03-24, 22:37
RE: IPTV Recorder - by primaeval - 2018-03-24, 23:05
RE: IPTV Recorder - by ray2301 - 2018-03-24, 23:13
RE: IPTV Recorder - by ray2301 - 2018-03-24, 23:28
RE: IPTV Recorder - by primaeval - 2018-03-24, 23:29
RE: IPTV Recorder - by Chychy - 2018-03-24, 23:32
RE: IPTV Recorder - by primaeval - 2018-03-24, 23:38
RE: IPTV Recorder - by primaeval - 2018-03-24, 23:52
RE: IPTV Recorder - by Chychy - 2018-03-25, 00:08
RE: IPTV Recorder - by primaeval - 2018-03-25, 00:17
RE: IPTV Recorder - by primaeval - 2018-03-25, 00:21
RE: IPTV Recorder - by Chychy - 2018-03-25, 03:12
RE: IPTV Recorder - by primaeval - 2018-03-25, 10:43
RE: IPTV Recorder - by ray2301 - 2018-03-25, 03:47
RE: IPTV Recorder - by primaeval - 2018-03-25, 11:25
RE: IPTV Recorder - by primaeval - 2018-03-25, 10:47
RE: IPTV Recorder - by Chychy - 2018-03-25, 11:44
RE: IPTV Recorder - by primaeval - 2018-03-25, 12:03
RE: IPTV Recorder - by Chychy - 2018-03-25, 12:07
RE: IPTV Recorder - by primaeval - 2018-03-25, 12:19
RE: IPTV Recorder - by Chychy - 2018-03-25, 12:39
RE: IPTV Recorder - by primaeval - 2018-03-25, 12:48
RE: IPTV Recorder - by Chychy - 2018-03-25, 13:14
RE: IPTV Recorder - by primaeval - 2018-03-25, 13:26
RE: IPTV Recorder - by Chychy - 2018-03-25, 14:58
RE: IPTV Recorder - by primaeval - 2018-03-25, 15:04
RE: IPTV Recorder - by primaeval - 2018-03-25, 15:06
RE: IPTV Recorder - by Chychy - 2018-03-25, 15:30
RE: IPTV Recorder - by primaeval - 2018-03-25, 15:42
RE: IPTV Recorder - by Chychy - 2018-03-25, 17:18
RE: IPTV Recorder - by primaeval - 2018-03-25, 17:52
RE: IPTV Recorder - by Chychy - 2018-03-25, 18:23
RE: IPTV Recorder - by primaeval - 2018-03-25, 18:29
RE: IPTV Recorder - by Chychy - 2018-03-25, 19:07
RE: IPTV Recorder - by primaeval - 2018-03-25, 19:53
RE: IPTV Recorder - by primaeval - 2018-03-25, 19:58
RE: IPTV Recorder - by Chychy - 2018-03-25, 20:10
RE: IPTV Recorder - by primaeval - 2018-03-25, 21:23
RE: IPTV Recorder - by Chychy - 2018-03-25, 21:34
RE: IPTV Recorder - by primaeval - 2018-03-25, 21:44
RE: IPTV Recorder - by primaeval - 2018-03-25, 22:13
RE: IPTV Recorder - by primaeval - 2018-03-25, 22:51
RE: IPTV Recorder - by Chychy - 2018-03-25, 23:42
RE: IPTV Recorder - by primaeval - 2018-03-26, 18:22
RE: IPTV Recorder - by Chychy - 2018-03-26, 19:40
RE: IPTV Recorder - by primaeval - 2018-03-26, 19:42
RE: IPTV Recorder - by Chychy - 2018-03-26, 20:15
RE: IPTV Recorder - by primaeval - 2018-03-26, 20:18
RE: IPTV Recorder - by primaeval - 2018-03-26, 20:28
RE: IPTV Recorder - by Chychy - 2018-03-26, 21:01
RE: IPTV Recorder - by primaeval - 2018-03-26, 21:16
RE: IPTV Recorder - by primaeval - 2018-03-26, 21:24
RE: IPTV Recorder - by Chychy - 2018-03-26, 21:56
RE: IPTV Recorder - by primaeval - 2018-03-26, 21:59
RE: IPTV Recorder - by Chychy - 2018-03-26, 23:13
RE: IPTV Recorder - by primaeval - 2018-03-26, 23:22
RE: IPTV Recorder - by Chychy - 2018-03-26, 23:41
RE: IPTV Recorder - by primaeval - 2018-03-27, 09:17
RE: IPTV Recorder - by primaeval - 2018-03-27, 09:56
RE: IPTV Recorder - by Chychy - 2018-03-27, 10:34
RE: IPTV Recorder - by primaeval - 2018-03-27, 10:44
RE: IPTV Recorder - by Chychy - 2018-03-27, 11:45
RE: IPTV Recorder - by primaeval - 2018-03-27, 11:52
RE: IPTV Recorder - by primaeval - 2018-03-27, 12:36
RE: IPTV Recorder - by Chychy - 2018-03-27, 12:36
RE: IPTV Recorder - by Chychy - 2018-03-27, 13:52
RE: IPTV Recorder - by primaeval - 2018-03-27, 17:25
RE: IPTV Recorder - by primaeval - 2018-03-27, 17:28
RE: IPTV Recorder - by primaeval - 2018-03-27, 17:36
RE: IPTV Recorder - by Chychy - 2018-03-27, 17:53
RE: IPTV Recorder - by primaeval - 2018-03-27, 18:19
RE: IPTV Recorder - by primaeval - 2018-03-27, 19:01
RE: IPTV Recorder - by Chychy - 2018-03-27, 19:46
RE: IPTV Recorder - by wigee - 2018-03-31, 12:17
RE: IPTV Recorder - by MikeKL - 2018-03-31, 22:35
RE: IPTV Recorder - by Chychy - 2018-03-31, 14:00
RE: IPTV Recorder - by primaeval - 2018-03-31, 18:02
RE: IPTV Recorder - by struthm8 - 2018-04-09, 07:27
RE: IPTV Recorder - by primaeval - 2018-04-09, 08:19
RE: IPTV Recorder - by struthm8 - 2018-04-09, 08:36
RE: IPTV Recorder - by primaeval - 2018-04-09, 09:09
RE: IPTV Recorder - by primaeval - 2018-03-31, 21:14
RE: IPTV Recorder - by primaeval - 2018-04-02, 18:31
RE: IPTV Recorder - by primaeval - 2018-04-02, 19:56
RE: IPTV Recorder - by ray2301 - 2018-04-03, 02:44
RE: IPTV Recorder - by locoguano - 2018-04-03, 06:03
RE: IPTV Recorder - by primaeval - 2018-04-03, 08:44
RE: IPTV Recorder - by primaeval - 2018-04-03, 10:02
RE: IPTV Recorder - by ray2301 - 2018-04-09, 17:29
RE: IPTV Recorder - by primaeval - 2018-04-09, 17:39
RE: IPTV Recorder - by ray2301 - 2018-04-09, 18:01
RE: IPTV Recorder - by primaeval - 2018-04-09, 20:01
RE: IPTV Recorder - by ray2301 - 2018-04-10, 00:15
RE: IPTV Recorder - by hotshot2k3 - 2018-04-10, 19:17
RE: IPTV Recorder - by primaeval - 2018-04-10, 19:20
RE: IPTV Recorder - by hotshot2k3 - 2018-04-10, 19:30
RE: IPTV Recorder - by primaeval - 2018-04-10, 19:36
RE: IPTV Recorder - by hotshot2k3 - 2018-04-10, 19:50
RE: IPTV Recorder - by primaeval - 2018-04-10, 19:58
RE: IPTV Recorder - by primaeval - 2018-04-10, 20:02
RE: IPTV Recorder - by hotshot2k3 - 2018-04-10, 20:04
RE: IPTV Recorder - by primaeval - 2018-04-10, 20:07
RE: IPTV Recorder - by primaeval - 2018-04-10, 21:15
RE: IPTV Recorder - by hotshot2k3 - 2018-04-11, 00:00
RE: IPTV Recorder - by primaeval - 2018-04-11, 09:09
IPTV Recorder - by ed_davidson01 - 2018-04-11, 01:43
RE: IPTV Recorder - by primaeval - 2018-04-11, 09:17
RE: IPTV Recorder - by hotshot2k3 - 2018-04-11, 13:20
RE: IPTV Recorder - by primaeval - 2018-04-11, 13:26
RE: IPTV Recorder - by hotshot2k3 - 2018-04-11, 13:39
RE: IPTV Recorder - by primaeval - 2018-04-11, 14:41
RE: IPTV Recorder - by hotshot2k3 - 2018-04-11, 15:12
RE: IPTV Recorder - by Alfredo Pérez - 2018-04-13, 12:55
RE: IPTV Recorder - by primaeval - 2018-04-13, 15:08
RE: IPTV Recorder - by wigee - 2018-04-13, 13:49
RE: IPTV Recorder - by primaeval - 2018-04-13, 15:19
RE: IPTV Recorder - by primaeval - 2018-04-13, 15:37
RE: IPTV Recorder - by wigee - 2018-04-13, 16:00
RE: IPTV Recorder - by primaeval - 2018-04-13, 16:10
RE: IPTV Recorder - by wigee - 2018-04-13, 16:12
RE: IPTV Recorder - by primaeval - 2018-04-13, 16:16
RE: IPTV Recorder - by DarrenHill - 2018-04-13, 17:37
RE: IPTV Recorder - by wigee - 2018-04-14, 10:30
RE: IPTV Recorder - by primaeval - 2018-04-14, 11:06
RE: IPTV Recorder - by primaeval - 2018-04-14, 18:17
RE: IPTV Recorder - by wigee - 2018-04-15, 10:34
RE: IPTV Recorder - by primaeval - 2018-04-15, 10:55
RE: IPTV Recorder - by wigee - 2018-04-15, 13:24
RE: IPTV Recorder - by primaeval - 2018-04-15, 13:29
RE: IPTV Recorder - by primaeval - 2018-04-15, 13:49
IPTV Recorder - by ed_davidson01 - 2018-04-15, 15:37
RE: IPTV Recorder - by wigee - 2018-04-15, 17:21
RE: IPTV Recorder - by primaeval - 2018-04-15, 17:34
RE: IPTV Recorder - by hotshot2k3 - 2018-04-16, 03:21
RE: IPTV Recorder - by primaeval - 2018-04-16, 08:07
RE: IPTV Recorder - by primaeval - 2018-04-16, 08:32
RE: IPTV Recorder - by wigee - 2018-04-16, 13:13
RE: IPTV Recorder - by primaeval - 2018-04-16, 13:31
RE: IPTV Recorder - by primaeval - 2018-04-16, 14:03
RE: IPTV Recorder - by hotshot2k3 - 2018-04-16, 14:48
RE: IPTV Recorder - by primaeval - 2018-04-16, 14:52
RE: IPTV Recorder - by wigee - 2018-04-16, 15:02
RE: IPTV Recorder - by primaeval - 2018-04-16, 15:10
RE: IPTV Recorder - by primaeval - 2018-04-16, 15:06
RE: IPTV Recorder - by primaeval - 2018-04-16, 15:48
RE: IPTV Recorder - by primaeval - 2018-04-16, 17:03
RE: IPTV Recorder - by hotshot2k3 - 2018-04-17, 03:40
RE: IPTV Recorder - by primaeval - 2018-04-17, 10:48
IPTV Recorder - by ed_davidson01 - 2018-04-17, 07:35
RE: IPTV Recorder - by primaeval - 2018-04-17, 11:28
RE: IPTV Recorder - by bladerunner82 - 2018-04-17, 13:02
RE: IPTV Recorder - by primaeval - 2018-04-17, 13:10
RE: IPTV Recorder - by hotshot2k3 - 2018-04-17, 13:24
RE: IPTV Recorder - by primaeval - 2018-04-17, 13:30
RE: IPTV Recorder - by hotshot2k3 - 2018-04-17, 13:39
RE: IPTV Recorder - by primaeval - 2018-04-17, 13:52
RE: IPTV Recorder - by hotshot2k3 - 2018-04-17, 14:00
RE: IPTV Recorder - by primaeval - 2018-04-17, 14:10
RE: IPTV Recorder - by primaeval - 2018-04-17, 19:59
RE: IPTV Recorder - by Nojustice - 2018-04-18, 10:54
RE: IPTV Recorder - by primaeval - 2018-04-18, 19:41
RE: IPTV Recorder - by primaeval - 2018-04-18, 11:09
IPTV Recorder - by ed_davidson01 - 2018-04-18, 15:47
RE: IPTV Recorder - by Publish3r - 2018-04-18, 16:14
RE: IPTV Recorder - by primaeval - 2018-04-18, 19:00
RE: IPTV Recorder - by primaeval - 2018-04-18, 16:22
RE: IPTV Recorder - by GriffeyJuni0r - 2018-04-19, 04:51
RE: IPTV Recorder - by primaeval - 2018-04-19, 10:28
RE: IPTV Recorder - by primaeval - 2018-04-19, 12:38
RE: IPTV Recorder - by primaeval - 2018-04-19, 14:33
RE: IPTV Recorder - by Publish3r - 2018-04-19, 15:58
RE: IPTV Recorder - by primaeval - 2018-04-19, 16:13
RE: IPTV Recorder - by Publish3r - 2018-04-19, 16:32
RE: IPTV Recorder - by Publish3r - 2018-04-19, 16:34
RE: IPTV Recorder - by primaeval - 2018-04-19, 16:35
IPTV Recorder - by ed_davidson01 - 2018-04-19, 16:42
RE: IPTV Recorder - by Publish3r - 2018-04-19, 16:45
RE: IPTV Recorder - by primaeval - 2018-04-19, 17:18
RE: IPTV Recorder - by Publish3r - 2018-04-19, 17:31
RE: IPTV Recorder - by primaeval - 2018-04-19, 17:45
RE: IPTV Recorder - by Publish3r - 2018-04-19, 18:02
RE: IPTV Recorder - by primaeval - 2018-04-19, 18:18
RE: IPTV Recorder - by GriffeyJuni0r - 2018-04-20, 03:16
RE: IPTV Recorder - by primaeval - 2018-04-20, 09:28
RE: IPTV Recorder - by Karellen - 2018-04-20, 06:31
RE: IPTV Recorder - by GriffeyJuni0r - 2018-04-20, 18:02
RE: IPTV Recorder - by primaeval - 2018-04-20, 18:04
RE: IPTV Recorder - by primaeval - 2018-04-28, 13:09
RE: IPTV Recorder - by gb160 - 2018-05-05, 10:37
RE: IPTV Recorder - by primaeval - 2018-05-05, 11:00
RE: IPTV Recorder - by gb160 - 2018-05-05, 11:13
RE: IPTV Recorder - by gb160 - 2018-05-05, 11:33
RE: IPTV Recorder - by primaeval - 2018-05-05, 12:09
RE: IPTV Recorder - by gb160 - 2018-05-05, 12:54
RE: IPTV Recorder - by primaeval - 2018-05-05, 13:09
RE: IPTV Recorder - by GriffeyJuni0r - 2018-05-06, 00:34
RE: IPTV Recorder - by primaeval - 2018-05-06, 10:24
RE: IPTV Recorder - by locoguano - 2018-05-06, 01:53
RE: IPTV Recorder - by primaeval - 2018-05-06, 10:30
RE: IPTV Recorder - by clones - 2018-05-28, 18:40
RE: IPTV Recorder - by dzejms - 2018-05-21, 13:36
RE: IPTV Recorder - by primaeval - 2018-05-21, 18:49
RE: IPTV Recorder - by dzejms - 2018-05-22, 08:51
RE: IPTV Recorder - by kaable - 2018-05-21, 21:11
RE: IPTV Recorder - by primaeval - 2018-05-21, 21:51
RE: IPTV Recorder - by kaable - 2018-05-22, 01:40
RE: IPTV Recorder - by primaeval - 2018-05-22, 10:44
RE: IPTV Recorder - by kaable - 2018-05-26, 11:30
RE: IPTV Recorder - by primaeval - 2018-05-22, 10:52
RE: IPTV Recorder - by dzejms - 2018-05-22, 11:25
RE: IPTV Recorder - by dzejms - 2018-05-22, 11:43
RE: IPTV Recorder - by primaeval - 2018-05-22, 11:44
RE: IPTV Recorder - by dzejms - 2018-05-22, 12:11
RE: IPTV Recorder - by primaeval - 2018-05-22, 12:14
RE: IPTV Recorder - by primaeval - 2018-05-22, 15:09
RE: IPTV Recorder - by primaeval - 2018-05-22, 15:17
RE: IPTV Recorder - by dzejms - 2018-05-22, 16:45
RE: IPTV Recorder - by primaeval - 2018-05-22, 20:13
RE: IPTV Recorder - by dzejms - 2018-05-22, 20:24
RE: IPTV Recorder - by dzejms - 2018-05-23, 11:56
RE: IPTV Recorder - by primaeval - 2018-05-23, 12:40
RE: IPTV Recorder - by dzejms - 2018-05-23, 12:49
RE: IPTV Recorder - by primaeval - 2018-05-23, 12:52
RE: IPTV Recorder - by dzejms - 2018-05-23, 13:05
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:00
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:03
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:10
RE: IPTV Recorder - by dzejms - 2018-05-23, 13:14
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:17
RE: IPTV Recorder - by dzejms - 2018-05-23, 13:33
RE: IPTV Recorder - by primaeval - 2018-05-23, 13:46
RE: IPTV Recorder - by dzejms - 2018-05-23, 14:27
RE: IPTV Recorder - by primaeval - 2018-05-26, 11:58
RE: IPTV Recorder - by dzejms - 2018-05-28, 09:51
RE: IPTV Recorder - by primaeval - 2018-05-28, 11:15
RE: IPTV Recorder - by primaeval - 2018-05-28, 19:13
RE: IPTV Recorder - by primaeval - 2018-05-28, 19:17
RE: IPTV Recorder - by primaeval - 2018-05-28, 19:26
RE: IPTV Recorder - by dzejms - 2018-05-29, 12:20
RE: IPTV Recorder - by be2p - 2019-09-06, 18:46
RE: IPTV Recorder - by primaeval - 2018-05-29, 12:45
RE: IPTV Recorder - by dzejms - 2018-05-29, 13:04
RE: IPTV Recorder - by dzejms - 2018-05-29, 13:19
RE: IPTV Recorder - by primaeval - 2018-05-29, 13:19
RE: IPTV Recorder - by primaeval - 2018-05-29, 13:21
RE: IPTV Recorder - by dzejms - 2018-05-29, 13:35
RE: IPTV Recorder - by dzejms - 2018-05-29, 13:38
RE: IPTV Recorder - by primaeval - 2018-05-29, 13:54
RE: IPTV Recorder - by dzejms - 2018-05-29, 14:10
RE: IPTV Recorder - by primaeval - 2018-05-29, 14:16
RE: IPTV Recorder - by dzejms - 2018-05-29, 14:25
RE: IPTV Recorder - by dzejms - 2018-06-01, 02:04
RE: IPTV Recorder - by primaeval - 2018-06-01, 10:31
RE: IPTV Recorder - by primaeval - 2018-06-01, 12:18
RE: IPTV Recorder - by princesabt821 - 2018-06-05, 16:22
RE: IPTV Recorder - by primaeval - 2018-06-05, 17:26
RE: IPTV Recorder - by kt666 - 2018-06-10, 17:28
RE: IPTV Recorder - by dzejms - 2018-06-10, 17:40
RE: IPTV Recorder - by kt666 - 2018-06-10, 17:52
RE: IPTV Recorder - by primaeval - 2018-06-10, 17:37
RE: IPTV Recorder - by primaeval - 2018-06-10, 18:12
RE: IPTV Recorder - by kt666 - 2018-06-10, 18:46
RE: IPTV Recorder - by dzejms - 2018-06-10, 18:43
RE: IPTV Recorder - by primaeval - 2018-06-10, 18:52
RE: IPTV Recorder - by dzejms - 2018-06-12, 00:12
RE: IPTV Recorder - by primaeval - 2018-06-12, 10:09
RE: IPTV Recorder - by dzejms - 2018-06-12, 13:20
RE: IPTV Recorder - by primaeval - 2018-06-12, 13:43
RE: IPTV Recorder - by dzejms - 2018-07-10, 12:05
RE: IPTV Recorder - by primaeval - 2018-07-10, 12:20
RE: IPTV Recorder - by brumbie - 2018-06-17, 02:05
RE: IPTV Recorder - by primaeval - 2018-06-17, 08:51
RE: IPTV Recorder - by brumbie - 2018-06-18, 09:32
RE: IPTV Recorder - by primaeval - 2018-06-18, 09:48
RE: IPTV Recorder - by brumbie - 2018-06-18, 12:50
RE: IPTV Recorder - by primaeval - 2018-06-18, 13:29
RE: IPTV Recorder - by brumbie - 2018-06-18, 14:10
RE: IPTV Recorder - by primaeval - 2018-06-18, 14:42
RE: IPTV Recorder - by brumbie - 2018-06-18, 14:45
RE: IPTV Recorder - by primaeval - 2018-06-18, 14:48
RE: IPTV Recorder - by brumbie - 2018-06-18, 14:52
RE: IPTV Recorder - by primaeval - 2018-06-18, 14:59
RE: IPTV Recorder - by brumbie - 2018-06-18, 15:23
RE: IPTV Recorder - by primaeval - 2018-06-18, 16:06
RE: IPTV Recorder - by brumbie - 2018-06-18, 16:48
RE: IPTV Recorder - by xryuu - 2018-06-20, 19:48
RE: IPTV Recorder - by primaeval - 2018-06-20, 20:36
RE: IPTV Recorder - by DarrenHill - 2018-06-20, 20:46
RE: IPTV Recorder - by xryuu - 2018-06-20, 23:06
RE: IPTV Recorder - by primaeval - 2018-06-20, 23:14
RE: IPTV Recorder - by ed_davidson - 2018-06-22, 06:31
RE: IPTV Recorder - by m1pnk - 2018-07-13, 21:07
RE: IPTV Recorder - by primaeval - 2018-07-13, 21:25
RE: IPTV Recorder - by JQZ* - 2018-09-01, 21:00
RE: IPTV Recorder - by primaeval - 2018-09-01, 21:31
RE: IPTV Recorder - by JQZ* - 2018-09-01, 22:08
RE: IPTV Recorder - by m1pnk - 2018-07-15, 18:54
RE: IPTV Recorder - by primaeval - 2018-07-16, 19:25
RE: IPTV Recorder - by m1pnk - 2018-07-17, 00:15
RE: IPTV Recorder - by rb01 - 2018-07-22, 19:33
RE: IPTV Recorder - by primaeval - 2018-07-22, 21:23
RE: IPTV Recorder - by rb01 - 2018-07-23, 08:47
RE: IPTV Recorder - by primaeval - 2018-07-23, 10:19
RE: IPTV Recorder - by rb01 - 2018-07-23, 13:25
RE: IPTV Recorder - by primaeval - 2018-07-23, 13:31
RE: IPTV Recorder - by rb01 - 2018-07-23, 16:30
RE: IPTV Recorder - by primaeval - 2018-07-23, 16:59
RE: IPTV Recorder - by rb01 - 2018-07-23, 17:05
RE: IPTV Recorder - by primaeval - 2018-07-23, 17:14
RE: IPTV Recorder - by rb01 - 2018-07-23, 17:24
RE: IPTV Recorder - by primaeval - 2018-07-23, 17:28
RE: IPTV Recorder - by Hesse - 2018-08-08, 14:50
RE: IPTV Recorder - by primaeval - 2018-08-08, 14:57
RE: IPTV Recorder - by Samboy08 - 2018-08-23, 02:48
RE: IPTV Recorder - by primaeval - 2018-08-23, 09:51
RE: IPTV Recorder - by snaitaz - 2018-08-24, 06:17
RE: IPTV Recorder - by primaeval - 2018-08-24, 10:33
RE: IPTV Recorder - by snaitaz - 2018-08-24, 16:38
RE: IPTV Recorder - by snaitaz - 2018-08-25, 00:57
RE: IPTV Recorder - by snaitaz - 2018-08-25, 07:48
RE: IPTV Recorder - by primaeval - 2018-08-27, 09:24
RE: IPTV Recorder - by purplehorseshoes - 2018-08-27, 19:51
RE: IPTV Recorder - by primaeval - 2018-08-27, 20:01
IPTV Recorder - by ed_davidson01 - 2018-08-27, 19:54
RE: IPTV Recorder - by purplehorseshoes - 2018-08-27, 20:07
RE: IPTV Recorder - by primaeval - 2018-08-27, 20:11
RE: IPTV Recorder - by purplehorseshoes - 2018-08-27, 20:10
RE: IPTV Recorder - by primaeval - 2018-08-27, 20:13
RE: IPTV Recorder - by primaeval - 2018-09-01, 22:23
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:00
RE: IPTV Recorder - by primaeval - 2018-09-01, 23:09
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:12
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:16
RE: IPTV Recorder - by primaeval - 2018-09-01, 23:20
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:45
RE: IPTV Recorder - by primaeval - 2018-09-01, 23:29
RE: IPTV Recorder - by primaeval - 2018-09-01, 23:37
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:48
RE: IPTV Recorder - by JQZ* - 2018-09-01, 23:59
RE: IPTV Recorder - by primaeval - 2018-09-02, 09:28
RE: IPTV Recorder - by JQZ* - 2018-09-02, 12:25
RE: IPTV Recorder - by gekados - 2018-09-02, 01:00
RE: IPTV Recorder - by primaeval - 2018-09-02, 09:35
RE: IPTV Recorder - by gekados - 2018-09-02, 10:50
RE: IPTV Recorder - by primaeval - 2018-09-02, 12:48
RE: IPTV Recorder - by JQZ* - 2018-09-02, 13:30
RE: IPTV Recorder - by primaeval - 2018-09-02, 18:56
RE: IPTV Recorder - by JQZ* - 2018-09-03, 08:31
RE: IPTV Recorder - by primaeval - 2018-09-03, 08:46
RE: IPTV Recorder - by JQZ* - 2018-09-03, 09:21
RE: IPTV Recorder - by primaeval - 2018-09-03, 09:46
RE: IPTV Recorder - by JQZ* - 2018-09-03, 10:13
RE: IPTV Recorder - by primaeval - 2018-09-03, 10:27
RE: IPTV Recorder - by JQZ* - 2018-09-03, 11:35
RE: IPTV Recorder - by primaeval - 2018-09-03, 10:32
RE: IPTV Recorder - by JQZ* - 2018-09-03, 11:01
RE: IPTV Recorder - by primaeval - 2018-09-03, 11:53
RE: IPTV Recorder - by JQZ* - 2018-09-03, 13:02
RE: IPTV Recorder - by primaeval - 2018-09-03, 14:07
RE: IPTV Recorder - by JQZ* - 2018-09-03, 17:17
RE: IPTV Recorder - by primaeval - 2018-09-03, 17:58
RE: IPTV Recorder - by JQZ* - 2018-09-03, 18:53
RE: IPTV Recorder - by primaeval - 2018-09-03, 19:31
RE: IPTV Recorder - by JQZ* - 2018-09-03, 20:11
RE: IPTV Recorder - by primaeval - 2018-09-03, 20:18
RE: IPTV Recorder - by JQZ* - 2018-09-03, 21:14
RE: IPTV Recorder - by primaeval - 2018-09-03, 21:37
RE: IPTV Recorder - by JQZ* - 2018-09-03, 23:39
RE: IPTV Recorder - by JQZ* - 2018-09-04, 05:43
RE: IPTV Recorder - by nashnash - 2018-09-12, 08:41
RE: IPTV Recorder - by primaeval - 2018-09-12, 08:59
RE: IPTV Recorder - by nashnash - 2018-09-12, 09:59
RE: IPTV Recorder - by primaeval - 2018-09-12, 10:36
RE: IPTV Recorder - by REralte - 2018-09-12, 17:52
RE: IPTV Recorder - by Foxxyfox - 2018-09-12, 18:59
RE: IPTV Recorder - by primaeval - 2018-09-12, 19:10
RE: IPTV Recorder - by Foxxyfox - 2018-09-12, 20:27
RE: IPTV Recorder - by Foxxyfox - 2018-09-12, 20:48
RE: IPTV Recorder - by primaeval - 2018-09-12, 20:55
RE: IPTV Recorder - by Foxxyfox - 2018-09-12, 23:37
RE: IPTV Recorder - by primaeval - 2018-09-13, 07:07
RE: IPTV Recorder - by Foxxyfox - 2018-09-13, 10:54
RE: IPTV Recorder - by primaeval - 2018-09-13, 11:01
RE: IPTV Recorder - by Foxxyfox - 2018-09-13, 13:18
RE: IPTV Recorder - by nashnash - 2018-09-13, 02:17
RE: IPTV Recorder - by nashnash - 2018-09-13, 02:50
RE: IPTV Recorder - by primaeval - 2018-09-13, 07:15
RE: IPTV Recorder - by nashnash - 2018-09-13, 09:31
RE: IPTV Recorder - by primaeval - 2018-09-13, 10:11
RE: IPTV Recorder - by nashnash - 2018-09-13, 19:46
RE: IPTV Recorder - by primaeval - 2018-09-13, 10:18
RE: IPTV Recorder - by nashnash - 2018-09-15, 09:09
RE: IPTV Recorder - by primaeval - 2018-09-15, 09:18
RE: IPTV Recorder - by nashnash - 2018-09-15, 17:55
RE: IPTV Recorder - by primaeval - 2018-09-15, 18:06
RE: IPTV Recorder - by nashnash - 2018-09-15, 19:21
RE: IPTV Recorder - by primaeval - 2018-09-15, 19:27
RE: IPTV Recorder - by nashnash - 2018-09-15, 20:59
RE: IPTV Recorder - by primaeval - 2018-09-15, 21:10
RE: IPTV Recorder - by nashnash - 2018-09-15, 21:05
RE: IPTV Recorder - by nashnash - 2018-09-15, 21:31
RE: IPTV Recorder - by primaeval - 2018-09-15, 21:43
RE: IPTV Recorder - by nashnash - 2018-09-15, 22:42
RE: IPTV Recorder - by primaeval - 2018-09-15, 22:58
RE: IPTV Recorder - by primaeval - 2018-09-15, 23:16
RE: IPTV Recorder - by nashnash - 2018-09-16, 07:03
RE: IPTV Recorder - by primaeval - 2018-09-16, 07:33
RE: IPTV Recorder - by primaeval - 2018-09-18, 09:57
RE: IPTV Recorder - by ciorci - 2018-09-18, 12:33
RE: IPTV Recorder - by primaeval - 2018-09-18, 12:49
RE: IPTV Recorder - by ciorci - 2018-09-19, 10:49
RE: IPTV Recorder - by nashnash - 2018-09-19, 18:30
RE: IPTV Recorder - by primaeval - 2018-09-19, 18:39
RE: IPTV Recorder - by nashnash - 2018-09-19, 21:14
RE: IPTV Recorder - by nashnash - 2018-09-21, 06:23
RE: IPTV Recorder - by Klojum - 2018-09-19, 19:06
RE: IPTV Recorder - by primaeval - 2018-09-22, 22:17
RE: IPTV Recorder - by nashnash - 2018-09-22, 22:25
RE: IPTV Recorder - by primaeval - 2018-09-22, 22:31
RE: IPTV Recorder - by nashnash - 2018-09-22, 22:52
RE: IPTV Recorder - by nashnash - 2018-09-23, 05:07
RE: IPTV Recorder - by primaeval - 2018-09-24, 12:43
RE: IPTV Recorder - by nashnash - 2018-09-28, 02:40
RE: IPTV Recorder - by primaeval - 2018-09-28, 07:46
RE: IPTV Recorder - by nashnash - 2018-09-30, 07:34
RE: IPTV Recorder - by primaeval - 2018-09-30, 09:04
RE: IPTV Recorder - by nashnash - 2018-10-01, 05:16
RE: IPTV Recorder - by primaeval - 2018-10-01, 07:45
RE: IPTV Recorder - by 01520717 - 2018-11-04, 08:01
RE: IPTV Recorder - by primaeval - 2018-11-04, 09:34
RE: IPTV Recorder - by 01520717 - 2018-11-04, 18:23
RE: IPTV Recorder - by primaeval - 2018-11-04, 18:28
RE: IPTV Recorder - by psbguy - 2018-11-11, 14:24
RE: IPTV Recorder - by primaeval - 2018-11-11, 14:29
RE: IPTV Recorder - by psbguy - 2018-11-11, 19:42
RE: IPTV Recorder - by primaeval - 2018-11-11, 19:49
RE: IPTV Recorder - by psbguy - 2018-11-11, 22:38
RE: IPTV Recorder - by primaeval - 2018-11-11, 22:41
RE: IPTV Recorder - by primaeval - 2018-11-12, 10:54
RE: IPTV Recorder - by psbguy - 2018-11-12, 17:24
RE: IPTV Recorder - by primaeval - 2018-11-12, 17:55
RE: IPTV Recorder - by psbguy - 2018-11-12, 19:24
RE: IPTV Recorder - by primaeval - 2018-11-12, 19:45
RE: IPTV Recorder - by psbguy - 2018-11-12, 22:24
RE: IPTV Recorder - by primaeval - 2018-11-12, 22:42
RE: IPTV Recorder - by Boromick - 2018-11-12, 22:36
RE: IPTV Recorder - by primaeval - 2018-11-12, 22:48
RE: IPTV Recorder - by Boromick - 2018-11-16, 13:42
RE: IPTV Recorder - by primaeval - 2018-11-16, 14:35
RE: IPTV Recorder - by Boromick - 2018-11-16, 18:28
RE: IPTV Recorder - by primaeval - 2018-11-16, 21:03
RE: IPTV Recorder - by Boromick - 2018-11-16, 21:04
RE: IPTV Recorder - by Boromick - 2018-11-17, 18:20
RE: IPTV Recorder - by primaeval - 2018-11-17, 20:53
RE: IPTV Recorder - by Boromick - 2018-11-18, 12:00
RE: IPTV Recorder - by Boromick - 2018-11-12, 23:09
RE: IPTV Recorder - by primaeval - 2018-11-23, 16:52
RE: IPTV Recorder - by RuneS - 2018-11-28, 13:14
RE: IPTV Recorder - by primaeval - 2018-11-28, 13:22
RE: IPTV Recorder - by RuneS - 2018-11-28, 13:31
RE: IPTV Recorder - by primaeval - 2018-11-28, 13:38
RE: IPTV Recorder - by RuneS - 2018-11-28, 13:47
RE: IPTV Recorder - by javidial - 2018-11-28, 22:07
RE: IPTV Recorder - by primaeval - 2018-11-28, 22:17
RE: IPTV Recorder - by Big2hd - 2018-12-16, 23:05
RE: IPTV Recorder - by primaeval - 2018-12-16, 23:18
RE: IPTV Recorder - by Big2hd - 2018-12-17, 02:50
RE: IPTV Recorder - by primaeval - 2018-12-17, 10:12
RE: IPTV Recorder - by Big2hd - 2018-12-17, 18:19
RE: IPTV Recorder - by primaeval - 2018-12-17, 18:29
RE: IPTV Recorder - by Big2hd - 2018-12-17, 22:09
RE: IPTV Recorder - by mwkurt - 2018-12-26, 15:28
RE: IPTV Recorder - by primaeval - 2018-12-26, 15:42
RE: IPTV Recorder - by mwkurt - 2018-12-26, 18:02
RE: IPTV Recorder - by primaeval - 2018-12-26, 18:10
RE: IPTV Recorder - by pmcnamara - 2018-12-26, 16:30
RE: IPTV Recorder - by primaeval - 2018-12-26, 17:11
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 13:35
RE: IPTV Recorder - by primaeval - 2018-12-27, 13:39
RE: IPTV Recorder - by DarrenHill - 2018-12-26, 18:19
RE: IPTV Recorder - by mwkurt - 2018-12-26, 21:04
RE: IPTV Recorder - by primaeval - 2018-12-26, 21:11
RE: IPTV Recorder - by mwkurt - 2018-12-26, 21:27
RE: IPTV Recorder - by primaeval - 2018-12-27, 00:15
RE: IPTV Recorder - by mwkurt - 2018-12-27, 03:12
RE: IPTV Recorder - by mwkurt - 2018-12-27, 03:35
RE: IPTV Recorder - by primaeval - 2018-12-27, 10:25
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 13:25
RE: IPTV Recorder - by primaeval - 2018-12-27, 13:31
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 13:39
RE: IPTV Recorder - by mwkurt - 2018-12-27, 18:41
RE: IPTV Recorder - by primaeval - 2018-12-27, 19:05
RE: IPTV Recorder - by primaeval - 2018-12-27, 13:44
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 14:21
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 14:20
RE: IPTV Recorder - by pmcnamara - 2018-12-27, 17:28
RE: IPTV Recorder - by primaeval - 2018-12-27, 17:47
RE: IPTV Recorder - by floatingshed - 2019-01-05, 02:09
RE: IPTV Recorder - by primaeval - 2019-01-05, 10:39
RE: IPTV Recorder - by pirlone - 2019-01-05, 11:53
RE: IPTV Recorder - by primaeval - 2019-01-05, 12:15
RE: IPTV Recorder - by pirlone - 2019-01-05, 12:28
RE: IPTV Recorder - by primaeval - 2019-01-05, 12:32
RE: IPTV Recorder - by pirlone - 2019-01-05, 12:31
RE: IPTV Recorder - by pirlone - 2019-01-05, 16:13
RE: IPTV Recorder - by primaeval - 2019-01-05, 16:31
RE: IPTV Recorder - by pirlone - 2019-01-06, 14:03
RE: IPTV Recorder - by primaeval - 2019-01-06, 14:24
RE: IPTV Recorder - by primaeval - 2019-01-06, 16:26
RE: IPTV Recorder - by pirlone - 2019-01-06, 14:42
RE: IPTV Recorder - by pmcnamara - 2019-01-06, 15:16
RE: IPTV Recorder - by primaeval - 2019-01-06, 15:48
RE: IPTV Recorder - by pmcnamara - 2019-01-06, 16:22
RE: IPTV Recorder - by primaeval - 2019-01-06, 16:25
RE: IPTV Recorder - by pmcnamara - 2019-01-06, 17:30
RE: IPTV Recorder - by pmcnamara - 2019-01-06, 17:33
RE: IPTV Recorder - by primaeval - 2019-01-06, 17:53
RE: IPTV Recorder - by pmcnamara - 2019-01-07, 03:17
RE: IPTV Recorder - by pirlone - 2019-01-06, 16:59
RE: IPTV Recorder - by icthruu - 2019-01-07, 19:47
RE: IPTV Recorder - by primaeval - 2019-01-07, 20:24
RE: IPTV Recorder - by pmcnamara - 2019-01-08, 15:22
RE: IPTV Recorder - by primaeval - 2019-01-08, 17:44
IPTV Recorder - by ed_davidson01 - 2019-01-08, 16:15
RE: IPTV Recorder - by pmcnamara - 2019-01-08, 18:46
RE: IPTV Recorder - by maiers12 - 2019-01-11, 14:41
RE: IPTV Recorder - by primaeval - 2019-01-11, 14:53
RE: IPTV Recorder - by maiers12 - 2019-01-11, 16:30
RE: IPTV Recorder - by maiers12 - 2019-01-11, 19:18
RE: IPTV Recorder - by primaeval - 2019-01-12, 11:01
RE: IPTV Recorder - by DarrenHill - 2019-01-11, 15:28
RE: IPTV Recorder - by maiers12 - 2019-01-12, 11:27
RE: IPTV Recorder - by maiers12 - 2019-01-12, 11:28
RE: IPTV Recorder - by primaeval - 2019-01-12, 11:47
RE: IPTV Recorder - by maiers12 - 2019-01-12, 14:34
RE: IPTV Recorder - by primaeval - 2019-01-12, 15:06
RE: IPTV Recorder - by maiers12 - 2019-01-12, 15:17
RE: IPTV Recorder - by primaeval - 2019-01-12, 15:26
RE: IPTV Recorder - by maiers12 - 2019-01-12, 16:23
RE: IPTV Recorder - by primaeval - 2019-01-12, 11:32
RE: IPTV Recorder - by Elluminatus - 2019-01-12, 14:37
RE: IPTV Recorder - by primaeval - 2019-01-12, 15:00
RE: IPTV Recorder - by primaeval - 2019-01-12, 16:35
RE: IPTV Recorder - by maiers12 - 2019-01-12, 16:48
RE: IPTV Recorder - by primaeval - 2019-01-12, 17:05
RE: IPTV Recorder - by maiers12 - 2019-01-12, 18:03
RE: IPTV Recorder - by primaeval - 2019-01-12, 18:34
RE: IPTV Recorder - by maiers12 - 2019-01-12, 19:02
RE: IPTV Recorder - by primaeval - 2019-01-12, 19:15
RE: IPTV Recorder - by maiers12 - 2019-01-13, 15:36
RE: IPTV Recorder - by DarrenHill - 2019-01-12, 19:14
RE: IPTV Recorder - by primaeval - 2019-01-12, 19:16
RE: IPTV Recorder - by Elluminatus - 2019-01-13, 01:26
RE: IPTV Recorder - by primaeval - 2019-01-13, 10:09
RE: IPTV Recorder - by Elluminatus - 2019-01-13, 16:05
RE: IPTV Recorder - by primaeval - 2019-01-13, 16:43
RE: IPTV Recorder - by maiers12 - 2019-01-13, 21:53
RE: IPTV Recorder - by primaeval - 2019-01-13, 22:00
RE: IPTV Recorder - by martybob - 2019-01-16, 08:35
RE: IPTV Recorder - by primaeval - 2019-01-16, 10:30
RE: IPTV Recorder - by martybob - 2019-01-16, 17:00
RE: IPTV Recorder - by maiers12 - 2019-01-22, 09:53
RE: IPTV Recorder - by primaeval - 2019-01-22, 11:26
RE: IPTV Recorder - by maiers12 - 2019-01-22, 13:55
RE: IPTV Recorder - by primaeval - 2019-01-22, 14:20
RE: IPTV Recorder - by maiers12 - 2019-01-22, 15:11
RE: IPTV Recorder - by dzejms - 2019-01-23, 12:35
RE: IPTV Recorder - by primaeval - 2019-01-23, 13:01
RE: IPTV Recorder - by dzejms - 2019-01-23, 13:46
RE: IPTV Recorder - by primaeval - 2019-01-23, 13:57
RE: IPTV Recorder - by dzejms - 2019-01-23, 13:56
RE: IPTV Recorder - by dzejms - 2019-01-23, 14:04
RE: IPTV Recorder - by primaeval - 2019-01-23, 14:10
RE: IPTV Recorder - by dzejms - 2019-01-23, 14:14
RE: IPTV Recorder - by primaeval - 2019-01-23, 14:37
RE: IPTV Recorder - by dzejms - 2019-01-23, 14:45
RE: IPTV Recorder - by dzejms - 2019-01-23, 17:05
RE: IPTV Recorder - by primaeval - 2019-01-23, 17:31
RE: IPTV Recorder - by maiers12 - 2019-01-27, 17:46
RE: IPTV Recorder - by primaeval - 2019-01-27, 18:20
RE: IPTV Recorder - by maiers12 - 2019-01-27, 19:17
RE: IPTV Recorder - by Nath_Explosion - 2019-01-27, 22:58
RE: IPTV Recorder - by primaeval - 2019-01-28, 11:07
IPTV Recorder - by ed_davidson01 - 2019-01-27, 23:38
RE: IPTV Recorder - by Nath_Explosion - 2019-01-27, 23:48
RE: IPTV Recorder - by Nath_Explosion - 2019-01-28, 13:55
RE: IPTV Recorder - by primaeval - 2019-01-28, 14:17
RE: IPTV Recorder - by Nath_Explosion - 2019-01-29, 12:03
RE: IPTV Recorder - by maiers12 - 2019-02-05, 13:56
RE: IPTV Recorder - by primaeval - 2019-02-05, 14:19
RE: IPTV Recorder - by maiers12 - 2019-02-05, 14:59
RE: IPTV Recorder - by primaeval - 2019-02-05, 16:23
RE: IPTV Recorder - by km4lin - 2019-02-07, 17:12
RE: IPTV Recorder - by primaeval - 2019-02-07, 17:28
RE: IPTV Recorder - by km4lin - 2019-02-07, 17:34
RE: IPTV Recorder - by primaeval - 2019-02-07, 17:55
RE: IPTV Recorder - by joerock - 2019-02-07, 21:37
RE: IPTV Recorder - by primaeval - 2019-02-07, 21:54
RE: IPTV Recorder - by joerock - 2019-02-07, 22:33
RE: IPTV Recorder - by primaeval - 2019-02-07, 22:46
RE: IPTV Recorder - by joerock - 2019-02-07, 22:40
RE: IPTV Recorder - by Laser78 - 2019-02-13, 00:16
RE: IPTV Recorder - by primaeval - 2019-02-13, 11:29
RE: IPTV Recorder - by Laser78 - 2019-02-13, 11:39
RE: IPTV Recorder - by primaeval - 2019-02-13, 11:45
IPTV Recorder - by Laser78 - 2019-02-13, 11:48
RE: IPTV Recorder - by Laser78 - 2019-02-13, 13:20
RE: IPTV Recorder - by primaeval - 2019-02-13, 13:23
RE: IPTV Recorder - by primaeval - 2019-02-13, 14:09
RE: IPTV Recorder - by Laser78 - 2019-02-13, 23:40
RE: IPTV Recorder - by Laser78 - 2019-02-14, 00:16
RE: IPTV Recorder - by primaeval - 2019-02-14, 00:28
RE: IPTV Recorder - by Laser78 - 2019-02-14, 00:30
RE: IPTV Recorder - by hsh24 - 2019-02-14, 02:55
RE: IPTV Recorder - by primaeval - 2019-02-14, 10:30
RE: IPTV Recorder - by hsh24 - 2019-02-15, 22:50
RE: IPTV Recorder - by primaeval - 2019-02-15, 23:00
RE: IPTV Recorder - by hsh24 - 2019-02-15, 23:14
RE: IPTV Recorder - by invincible - 2019-02-14, 19:26
RE: IPTV Recorder - by primaeval - 2019-02-14, 20:00
RE: IPTV Recorder - by primaeval - 2019-02-14, 20:55
RE: IPTV Recorder - by invincible - 2019-02-14, 21:05
RE: IPTV Recorder - by primaeval - 2019-02-14, 21:10
RE: IPTV Recorder - by invincible - 2019-02-14, 22:22
IPTV Recorder - by ed_davidson01 - 2019-02-15, 00:00
RE: IPTV Recorder - by maiers12 - 2019-02-16, 19:20
RE: IPTV Recorder - by primaeval - 2019-02-16, 21:18
RE: IPTV Recorder - by xpax - 2019-02-17, 15:31
RE: IPTV Recorder - by primaeval - 2019-02-17, 16:57
RE: IPTV Recorder - by kt666 - 2019-02-17, 22:01
RE: IPTV Recorder - by primaeval - 2019-02-17, 22:31
RE: IPTV Recorder - by kt666 - 2019-02-17, 23:20
RE: IPTV Recorder - by primaeval - 2019-02-17, 23:30
RE: IPTV Recorder - by primaeval - 2019-02-18, 12:01
RE: IPTV Recorder - by Bland - 2021-04-10, 09:13
RE: IPTV Recorder - by km4lin - 2019-02-18, 12:22
RE: IPTV Recorder - by primaeval - 2019-02-18, 12:26
RE: IPTV Recorder - by invincible - 2019-02-18, 13:19
RE: IPTV Recorder - by primaeval - 2019-02-18, 13:32
RE: IPTV Recorder - by primaeval - 2019-02-18, 14:53
RE: IPTV Recorder - by pirlone - 2019-02-18, 19:58
RE: IPTV Recorder - by pirlone - 2019-02-18, 20:08
RE: IPTV Recorder - by Timoty - 2019-02-18, 23:13
RE: IPTV Recorder - by primaeval - 2019-02-18, 23:53
RE: IPTV Recorder - by 1deep - 2020-08-06, 04:08
RE: IPTV Recorder - by primaeval - 2019-02-19, 00:03
RE: IPTV Recorder - by Timoty - 2019-02-19, 00:42
RE: IPTV Recorder - by ed_davidson - 2019-02-19, 05:15
RE: IPTV Recorder - by primaeval - 2019-02-19, 09:37
RE: IPTV Recorder - by maiers12 - 2019-02-19, 17:27
RE: IPTV Recorder - by primaeval - 2019-02-19, 17:56
RE: IPTV Recorder - by maiers12 - 2019-02-19, 19:57
RE: IPTV Recorder - by maiers12 - 2019-02-21, 09:00
RE: IPTV Recorder - by primaeval - 2019-02-21, 10:25
RE: IPTV Recorder - by primaeval - 2019-02-21, 11:05
RE: IPTV Recorder - by maiers12 - 2019-02-21, 12:11
RE: IPTV Recorder - by primaeval - 2019-02-21, 12:15
RE: IPTV Recorder - by maiers12 - 2019-02-21, 13:01
RE: IPTV Recorder - by primaeval - 2019-02-21, 13:07
RE: IPTV Recorder - by maiers12 - 2019-02-21, 14:36
RE: IPTV Recorder - by primaeval - 2019-02-21, 14:59
RE: IPTV Recorder - by maiers12 - 2019-02-21, 15:00
RE: IPTV Recorder - by primaeval - 2019-02-21, 15:12
RE: IPTV Recorder - by maiers12 - 2019-02-21, 15:38
RE: IPTV Recorder - by primaeval - 2019-02-21, 15:42
RE: IPTV Recorder - by maiers12 - 2019-02-21, 16:18
RE: IPTV Recorder - by primaeval - 2019-02-21, 17:10
RE: IPTV Recorder - by invincible - 2019-02-19, 22:15
RE: IPTV Recorder - by primaeval - 2019-02-19, 22:26
RE: IPTV Recorder - by invincible - 2019-02-19, 22:31
RE: IPTV Recorder - by trutolo - 2019-02-20, 17:56
RE: IPTV Recorder - by primaeval - 2019-02-20, 18:01
RE: IPTV Recorder - by primaeval - 2019-02-21, 12:18
RE: IPTV Recorder - by trutolo - 2019-02-21, 13:42
RE: IPTV Recorder - by primaeval - 2019-02-21, 14:53
RE: IPTV Recorder - by primaeval - 2019-02-21, 20:16
RE: IPTV Recorder - by primaeval - 2019-02-21, 21:31
RE: IPTV Recorder - by mcxpert - 2019-02-21, 14:25
RE: IPTV Recorder - by primaeval - 2019-02-21, 17:14
RE: IPTV Recorder - by mcxpert - 2019-02-22, 10:14
RE: IPTV Recorder - by primaeval - 2019-02-22, 11:01
RE: IPTV Recorder - by mcxpert - 2019-02-22, 21:56
RE: IPTV Recorder - by primaeval - 2019-02-22, 22:03
RE: IPTV Recorder - by Spiderfish - 2019-02-22, 13:03
RE: IPTV Recorder - by primaeval - 2019-02-22, 13:27
RE: IPTV Recorder - by Spiderfish - 2019-02-22, 13:59
RE: IPTV Recorder - by primaeval - 2019-02-22, 14:01
RE: IPTV Recorder - by Spiderfish - 2019-02-22, 14:15
RE: IPTV Recorder - by mcxpert - 2019-02-22, 22:02
RE: IPTV Recorder - by mcxpert - 2019-02-22, 22:31
RE: IPTV Recorder - by mcxpert - 2019-02-22, 23:07
RE: IPTV Recorder - by primaeval - 2019-02-22, 23:21
RE: IPTV Recorder - by Laser78 - 2019-02-22, 23:56
RE: IPTV Recorder - by Laser78 - 2019-02-22, 23:59
RE: IPTV Recorder - by Laser78 - 2019-02-23, 01:55
RE: IPTV Recorder - by DarrenHill - 2019-02-23, 10:18
RE: IPTV Recorder - by Laser78 - 2019-02-23, 10:23
RE: IPTV Recorder - by primaeval - 2019-02-23, 11:23
RE: IPTV Recorder - by mcxpert - 2019-02-23, 15:21
RE: IPTV Recorder - by primaeval - 2019-02-23, 15:28
RE: IPTV Recorder - by mcxpert - 2019-02-24, 20:39
RE: IPTV Recorder - by primaeval - 2019-02-24, 20:53
RE: IPTV Recorder - by Laser78 - 2019-02-24, 10:16
RE: IPTV Recorder - by primaeval - 2019-02-24, 10:24
RE: IPTV Recorder - by Laser78 - 2019-02-24, 10:27
RE: IPTV Recorder - by primaeval - 2019-02-24, 10:31
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 14:28
RE: IPTV Recorder - by primaeval - 2019-02-23, 14:59
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 15:37
RE: IPTV Recorder - by primaeval - 2019-02-23, 15:40
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 15:41
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 15:45
RE: IPTV Recorder - by primaeval - 2019-02-23, 15:51
RE: IPTV Recorder - by 1deep - 2019-02-23, 22:54
RE: IPTV Recorder - by primaeval - 2019-02-24, 09:43
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 17:39
RE: IPTV Recorder - by primaeval - 2019-02-23, 18:02
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 18:14
RE: IPTV Recorder - by primaeval - 2019-02-23, 18:20
RE: IPTV Recorder - by Spiderfish - 2019-02-23, 18:24
RE: IPTV Recorder - by Laser78 - 2019-02-24, 10:34
RE: IPTV Recorder - by Laser78 - 2019-02-24, 10:42
RE: IPTV Recorder - by primaeval - 2019-02-24, 11:32
RE: IPTV Recorder - by mcxpert - 2019-02-24, 21:24
RE: IPTV Recorder - by primaeval - 2019-02-24, 22:23
RE: IPTV Recorder - by beatmasterrs - 2019-02-24, 22:43
RE: IPTV Recorder - by primaeval - 2019-02-24, 23:01
RE: IPTV Recorder - by beatmasterrs - 2019-02-24, 23:30
RE: IPTV Recorder - by primaeval - 2019-02-25, 09:54
RE: IPTV Recorder - by beatmasterrs - 2019-02-25, 10:10
RE: IPTV Recorder - by Laser78 - 2019-02-24, 22:47
RE: IPTV Recorder - by primaeval - 2019-02-24, 23:05
RE: IPTV Recorder - by Laser78 - 2019-02-24, 23:10
RE: IPTV Recorder - by primaeval - 2019-02-24, 23:25
RE: IPTV Recorder - by Laser78 - 2019-02-25, 22:29
RE: IPTV Recorder - by samueljones - 2019-02-26, 02:39
RE: IPTV Recorder - by primaeval - 2019-02-26, 09:21
IPTV Recorder - by ed_davidson01 - 2019-02-26, 05:59
IPTV Recorder - by ed_davidson01 - 2019-02-26, 06:01
RE: IPTV Recorder - by mcxpert - 2019-02-26, 09:21
RE: IPTV Recorder - by Laser78 - 2019-02-26, 09:26
RE: IPTV Recorder - by samueljones - 2019-02-26, 14:55
RE: IPTV Recorder - by mcxpert - 2019-02-26, 21:51
RE: IPTV Recorder - by primaeval - 2019-02-26, 22:00
RE: IPTV Recorder - by mcxpert - 2019-02-27, 10:02
RE: IPTV Recorder - by primaeval - 2019-02-27, 11:11
RE: IPTV Recorder - by mcxpert - 2019-02-27, 22:20
RE: IPTV Recorder - by Foxxyfox - 2019-02-27, 12:42
RE: IPTV Recorder - by primaeval - 2019-02-27, 13:30
RE: IPTV Recorder - by Foxxyfox - 2019-02-27, 18:22
RE: IPTV Recorder - by primaeval - 2019-02-27, 18:30
RE: IPTV Recorder - by giaur - 2019-03-01, 00:06
RE: IPTV Recorder - by dzejms - 2019-03-01, 01:00
RE: IPTV Recorder - by primaeval - 2019-03-01, 09:10
IPTV Recorder - by ed_davidson01 - 2019-03-01, 01:07
RE: IPTV Recorder - by giaur - 2019-03-01, 02:09
RE: IPTV Recorder - by Hoggens - 2019-03-01, 08:52
RE: IPTV Recorder - by primaeval - 2019-03-01, 09:42
RE: IPTV Recorder - by mcxpert - 2019-03-01, 15:13
RE: IPTV Recorder - by primaeval - 2019-03-01, 15:33
RE: IPTV Recorder - by Hoggens - 2019-03-02, 13:23
RE: IPTV Recorder - by Nathcloud9 - 2019-03-02, 20:35
RE: IPTV Recorder - by primaeval - 2019-03-02, 21:38
RE: IPTV Recorder - by Laser78 - 2019-03-04, 17:37
RE: IPTV Recorder - by primaeval - 2019-03-04, 18:17
RE: IPTV Recorder - by Laser78 - 2019-03-04, 18:43
RE: IPTV Recorder - by primaeval - 2019-03-04, 19:28
RE: IPTV Recorder - by Laser78 - 2019-03-04, 20:36
IPTV Recorder - by Laser78 - 2019-03-04, 23:25
RE: IPTV Recorder - by primaeval - 2019-03-05, 09:28
RE: IPTV Recorder - by CpTHOOK - 2019-03-05, 00:29
RE: IPTV Recorder - by primaeval - 2019-03-05, 09:33
RE: IPTV Recorder - by CpTHOOK - 2019-03-06, 05:24
RE: IPTV Recorder - by primaeval - 2019-03-06, 09:20
RE: IPTV Recorder - by CpTHOOK - 2019-03-07, 05:35
RE: IPTV Recorder - by primaeval - 2019-03-07, 09:46
RE: IPTV Recorder - by CpTHOOK - 2019-03-08, 00:06
RE: IPTV Recorder - by primaeval - 2019-03-08, 09:26
RE: IPTV Recorder - by CpTHOOK - 2019-03-08, 17:51
RE: IPTV Recorder - by primaeval - 2019-03-08, 18:03
RE: IPTV Recorder - by Laser78 - 2019-03-05, 10:04
RE: IPTV Recorder - by primaeval - 2019-03-05, 10:10
RE: IPTV Recorder - by Laser78 - 2019-03-06, 00:37
RE: IPTV Recorder - by primaeval - 2019-03-06, 09:21
RE: IPTV Recorder - by dzejms - 2019-03-06, 12:42
RE: IPTV Recorder - by primaeval - 2019-03-06, 12:52
RE: IPTV Recorder - by dzejms - 2019-03-06, 13:05
RE: IPTV Recorder - by primaeval - 2019-03-06, 13:34
RE: IPTV Recorder - by dzejms - 2019-03-06, 13:56
RE: IPTV Recorder - by primaeval - 2019-03-06, 14:06
IPTV Recorder - by ed_davidson01 - 2019-03-08, 22:52
RE: IPTV Recorder - by CpTHOOK - 2019-03-09, 18:55
RE: IPTV Recorder - by primaeval - 2019-03-09, 19:21
RE: IPTV Recorder - by CpTHOOK - 2019-03-09, 20:04
RE: IPTV Recorder - by primaeval - 2019-03-09, 20:14
RE: IPTV Recorder - by CpTHOOK - 2019-03-09, 20:27
RE: IPTV Recorder - by primaeval - 2019-03-09, 20:54
RE: IPTV Recorder - by Laser78 - 2019-03-10, 01:04
RE: IPTV Recorder - by primaeval - 2019-03-10, 09:03
RE: IPTV Recorder - by Laser78 - 2019-03-10, 09:49
RE: IPTV Recorder - by primaeval - 2019-03-10, 10:55
RE: IPTV Recorder - by Laser78 - 2019-03-10, 12:14
RE: IPTV Recorder - by Spiderfish - 2019-03-10, 19:57
RE: IPTV Recorder - by primaeval - 2019-03-10, 20:29
RE: IPTV Recorder - by mcxpert - 2019-03-10, 20:32
RE: IPTV Recorder - by mcxpert - 2019-03-12, 09:28
IPTV Recorder - by ed_davidson01 - 2019-03-12, 16:24
RE: IPTV Recorder - by mcxpert - 2019-03-12, 17:48
RE: IPTV Recorder - by primaeval - 2019-03-13, 22:06
RE: IPTV Recorder - by Minefield247 - 2019-03-14, 14:08
RE: IPTV Recorder - by primaeval - 2019-03-14, 15:24
IPTV Recorder - by ed_davidson01 - 2019-03-14, 15:52
RE: IPTV Recorder - by primaeval - 2019-03-14, 16:08
RE: IPTV Recorder - by Minefield247 - 2019-03-14, 16:11
RE: IPTV Recorder - by primaeval - 2019-03-14, 16:16
RE: IPTV Recorder - by primaeval - 2019-03-14, 16:52
RE: IPTV Recorder - by Gordon Bleu - 2019-03-14, 17:00
RE: IPTV Recorder - by primaeval - 2019-03-14, 17:22
IPTV Recorder - by ed_davidson01 - 2019-03-14, 17:04
RE: IPTV Recorder - by primaeval - 2019-03-14, 17:11
RE: IPTV Recorder - by primaeval - 2019-03-15, 16:25
RE: IPTV Recorder - by Gordon Bleu - 2019-03-15, 10:05
RE: IPTV Recorder - by primaeval - 2019-03-15, 14:46
IPTV Recorder - by ed_davidson01 - 2019-03-15, 16:27
IPTV Recorder - by ed_davidson01 - 2019-03-15, 16:29
RE: IPTV Recorder - by primaeval - 2019-03-15, 17:49
IPTV Recorder - by ed_davidson01 - 2019-03-15, 17:56
IPTV Recorder - by ed_davidson01 - 2019-03-16, 21:52
RE: IPTV Recorder - by primaeval - 2019-03-16, 22:47
IPTV Recorder - by ed_davidson01 - 2019-03-17, 02:44
RE: IPTV Recorder - by encol - 2019-03-17, 12:11
RE: IPTV Recorder - by primaeval - 2019-03-17, 12:18
RE: IPTV Recorder - by encol - 2019-03-17, 12:24
RE: IPTV Recorder - by primaeval - 2019-03-17, 12:59
RE: IPTV Recorder - by encol - 2019-03-17, 13:06
RE: IPTV Recorder - by encol - 2019-03-17, 13:24
RE: IPTV Recorder - by primaeval - 2019-03-17, 14:06
RE: IPTV Recorder - by primaeval - 2019-03-17, 17:17
IPTV Recorder - by ed_davidson01 - 2019-03-17, 15:10
RE: IPTV Recorder - by encol - 2019-03-17, 15:26
RE: IPTV Recorder - by encol - 2019-03-17, 15:29
IPTV Recorder - by ed_davidson01 - 2019-03-17, 16:42
RE: IPTV Recorder - by encol - 2019-03-17, 18:56
RE: IPTV Recorder - by primaeval - 2019-03-17, 19:52
RE: IPTV Recorder - by encol - 2019-03-17, 21:44
RE: IPTV Recorder - by primaeval - 2019-03-17, 22:12
RE: IPTV Recorder - by encol - 2019-03-17, 22:26
RE: IPTV Recorder - by primaeval - 2019-03-17, 22:34
RE: IPTV Recorder - by encol - 2019-03-17, 22:38
RE: IPTV Recorder - by primaeval - 2019-03-17, 23:09
RE: IPTV Recorder - by encol - 2019-03-17, 23:55
RE: IPTV Recorder - by primaeval - 2019-03-18, 10:02
RE: IPTV Recorder - by encol - 2019-03-18, 11:14
RE: IPTV Recorder - by primaeval - 2019-03-18, 11:48
RE: IPTV Recorder - by encol - 2019-03-18, 12:12
RE: IPTV Recorder - by primaeval - 2019-03-18, 12:26
IPTV Recorder - by ed_davidson01 - 2019-03-18, 15:23
RE: IPTV Recorder - by primaeval - 2019-03-18, 15:26
IPTV Recorder - by ed_davidson01 - 2019-03-18, 15:33
IPTV Recorder - by ed_davidson01 - 2019-03-18, 15:35
RE: IPTV Recorder - by encol - 2019-03-18, 15:59
RE: IPTV Recorder - by primaeval - 2019-03-18, 16:24
RE: IPTV Recorder - by encol - 2019-03-18, 16:25
RE: IPTV Recorder - by primaeval - 2019-03-18, 16:28
RE: IPTV Recorder - by primaeval - 2019-03-18, 16:30
RE: IPTV Recorder - by encol - 2019-03-21, 18:22
RE: IPTV Recorder - by primaeval - 2019-03-21, 18:31
RE: IPTV Recorder - by encol - 2019-03-21, 19:26
RE: IPTV Recorder - by primaeval - 2019-03-21, 19:49
RE: IPTV Recorder - by encol - 2019-03-21, 19:55
RE: IPTV Recorder - by primaeval - 2019-03-21, 20:00
RE: IPTV Recorder - by encol - 2019-03-25, 10:51
RE: IPTV Recorder - by primaeval - 2019-03-25, 11:18
RE: IPTV Recorder - by encol - 2019-03-25, 12:49
RE: IPTV Recorder - by encol - 2019-03-18, 17:57
IPTV Recorder - by ed_davidson01 - 2019-03-18, 20:12
RE: IPTV Recorder - by primaeval - 2019-03-18, 21:25
IPTV Recorder - by ed_davidson01 - 2019-03-18, 21:37
IPTV Recorder - by ed_davidson01 - 2019-03-18, 23:02
RE: IPTV Recorder - by invincible - 2019-03-19, 00:35
RE: IPTV Recorder - by primaeval - 2019-03-19, 08:48
RE: IPTV Recorder - by invincible - 2019-03-19, 22:17
RE: IPTV Recorder - by primaeval - 2019-03-19, 22:24
RE: IPTV Recorder - by samueljones - 2019-03-19, 16:38
RE: IPTV Recorder - by primaeval - 2019-03-19, 17:10
RE: IPTV Recorder - by invincible - 2019-03-19, 18:33
RE: IPTV Recorder - by primaeval - 2019-03-19, 18:37
RE: IPTV Recorder - by McDaz - 2019-03-19, 23:30
RE: IPTV Recorder - by primaeval - 2019-03-20, 08:45
RE: IPTV Recorder - by Abba2 - 2019-03-22, 18:25
RE: IPTV Recorder - by primaeval - 2019-03-22, 18:50
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 21:59
RE: IPTV Recorder - by primaeval - 2019-03-24, 22:15
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 22:28
RE: IPTV Recorder - by primaeval - 2019-03-24, 22:31
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:01
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:05
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:08
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:11
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:20
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:26
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:37
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:41
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:45
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:48
RE: IPTV Recorder - by primaeval - 2019-03-24, 23:54
RE: IPTV Recorder - by Nathcloud9 - 2019-03-24, 23:58
RE: IPTV Recorder - by primaeval - 2019-03-25, 00:02
RE: IPTV Recorder - by Nathcloud9 - 2019-03-25, 00:30
RE: IPTV Recorder - by invincible - 2019-03-25, 09:21
RE: IPTV Recorder - by darealwy - 2019-03-25, 20:03
RE: IPTV Recorder - by primaeval - 2019-03-25, 20:33
IPTV Recorder - by ed_davidson01 - 2019-03-30, 05:21
RE: IPTV Recorder - by primaeval - 2019-03-30, 08:44
RE: IPTV Recorder - by pirlone - 2019-03-31, 08:30
RE: IPTV Recorder - by primaeval - 2019-03-31, 08:41
RE: IPTV Recorder - by pirlone - 2019-03-31, 14:31
RE: IPTV Recorder - by primaeval - 2019-03-31, 15:27
RE: IPTV Recorder - by pirlone - 2019-03-31, 15:31
RE: IPTV Recorder - by primaeval - 2019-03-31, 15:40
RE: IPTV Recorder - by Ampsys - 2019-04-07, 01:33
RE: IPTV Recorder - by primaeval - 2019-04-07, 08:09
RE: IPTV Recorder - by Ampsys - 2019-04-07, 22:13
RE: IPTV Recorder - by Ampsys - 2019-04-07, 22:17
RE: IPTV Recorder - by Ampsys - 2019-04-07, 22:37
RE: IPTV Recorder - by primaeval - 2019-04-08, 09:04
RE: IPTV Recorder - by Ampsys - 2019-04-09, 01:51
RE: IPTV Recorder - by primaeval - 2019-04-09, 07:48
RE: IPTV Recorder - by Ampsys - 2019-04-09, 16:11
RE: IPTV Recorder - by primaeval - 2019-04-09, 17:37
RE: IPTV Recorder - by Ampsys - 2019-04-09, 18:59
RE: IPTV Recorder - by primaeval - 2019-04-09, 19:08
RE: IPTV Recorder - by Ampsys - 2019-04-09, 19:33
RE: IPTV Recorder - by primaeval - 2019-04-09, 19:48
RE: IPTV Recorder - by DarrenHill - 2019-04-08, 09:23
RE: IPTV Recorder - by primaeval - 2019-04-08, 09:27
RE: IPTV Recorder - by lagman - 2019-04-08, 16:17
RE: IPTV Recorder - by lagman - 2019-04-08, 16:25
RE: IPTV Recorder - by primaeval - 2019-04-08, 16:39
RE: IPTV Recorder - by lagman - 2019-04-08, 19:01
RE: IPTV Recorder - by primaeval - 2019-04-08, 19:26
RE: IPTV Recorder - by Ampsys - 2019-04-09, 19:45
RE: IPTV Recorder - by lagman - 2019-04-09, 19:57
RE: IPTV Recorder - by primaeval - 2019-04-09, 20:12
RE: IPTV Recorder - by lagman - 2019-04-09, 23:03
RE: IPTV Recorder - by primaeval - 2019-04-10, 08:24
RE: IPTV Recorder - by lagman - 2019-04-10, 13:18
RE: IPTV Recorder - by primaeval - 2019-04-10, 13:30
RE: IPTV Recorder - by lagman - 2019-04-10, 16:14
RE: IPTV Recorder - by primaeval - 2019-04-10, 17:05
RE: IPTV Recorder - by lagman - 2019-04-10, 17:20
RE: IPTV Recorder - by primaeval - 2019-04-10, 17:33
RE: IPTV Recorder - by lagman - 2019-04-10, 18:02
RE: IPTV Recorder - by primaeval - 2019-04-10, 18:14
RE: IPTV Recorder - by lagman - 2019-04-10, 18:37
RE: IPTV Recorder - by primaeval - 2019-04-10, 18:53
RE: IPTV Recorder - by primaeval - 2019-04-12, 21:10
RE: IPTV Recorder - by lagman - 2019-04-15, 18:46
IPTV Recorder - by ed_davidson01 - 2019-04-11, 02:57
RE: IPTV Recorder - by lagman - 2019-04-12, 20:53
RE: IPTV Recorder - by DarrenHill - 2019-04-12, 22:29
IPTV Recorder - by ed_davidson01 - 2019-04-13, 05:35
RE: IPTV Recorder - by lagman - 2019-04-15, 02:31
RE: IPTV Recorder - by ed_davidson - 2019-04-15, 02:46
RE: IPTV Recorder - by lagman - 2019-04-15, 18:44
RE: IPTV Recorder - by kaner007 - 2019-04-19, 19:10
RE: IPTV Recorder - by primaeval - 2019-04-19, 19:41
RE: IPTV Recorder - by kaner007 - 2019-04-19, 20:37
RE: IPTV Recorder - by primaeval - 2019-04-19, 20:47
RE: IPTV Recorder - by kaner007 - 2019-04-19, 21:24
RE: IPTV Recorder - by primaeval - 2019-04-19, 21:27
RE: IPTV Recorder - by kaner007 - 2019-04-19, 22:05
RE: IPTV Recorder - by primaeval - 2019-04-20, 08:20
RE: IPTV Recorder - by kaner007 - 2019-04-20, 08:58
RE: IPTV Recorder - by primaeval - 2019-04-20, 09:21
RE: IPTV Recorder - by kaner007 - 2019-04-20, 10:06
RE: IPTV Recorder - by primaeval - 2019-04-20, 10:10
RE: IPTV Recorder - by kaner007 - 2019-04-20, 10:49
RE: IPTV Recorder - by primaeval - 2019-04-20, 11:02
RE: IPTV Recorder - by kaner007 - 2019-04-19, 22:30
RE: IPTV Recorder - by DarrenHill - 2019-04-20, 11:50
RE: IPTV Recorder - by primaeval - 2019-04-20, 12:02
RE: IPTV Recorder - by kaner007 - 2019-04-20, 12:27
RE: IPTV Recorder - by primaeval - 2019-04-20, 12:38
RE: IPTV Recorder - by kaner007 - 2019-04-20, 14:02
RE: IPTV Recorder - by primaeval - 2019-04-20, 14:11
RE: IPTV Recorder - by kaner007 - 2019-04-20, 14:19
RE: IPTV Recorder - by zloty777 - 2019-04-22, 14:13
RE: IPTV Recorder - by primaeval - 2019-04-22, 14:23
RE: IPTV Recorder - by zloty777 - 2019-04-22, 21:37
RE: IPTV Recorder - by primaeval - 2019-04-22, 21:55
RE: IPTV Recorder - by zloty777 - 2019-04-22, 22:12
RE: IPTV Recorder - by zloty777 - 2019-04-22, 22:14
RE: IPTV Recorder - by primaeval - 2019-04-22, 22:19
RE: IPTV Recorder - by zloty777 - 2019-04-22, 23:10
RE: IPTV Recorder - by primaeval - 2019-04-23, 08:56
RE: IPTV Recorder - by zloty777 - 2019-04-23, 14:18
RE: IPTV Recorder - by zloty777 - 2019-04-23, 15:50
RE: IPTV Recorder - by primaeval - 2019-04-23, 16:01
RE: IPTV Recorder - by zloty777 - 2019-04-22, 21:39
RE: IPTV Recorder - by Atamans - 2019-04-26, 14:43
RE: IPTV Recorder - by primaeval - 2019-04-26, 14:51
RE: IPTV Recorder - by Atamans - 2019-04-26, 15:00
RE: IPTV Recorder - by primaeval - 2019-04-26, 15:03
RE: IPTV Recorder - by Atamans - 2019-04-26, 15:07
RE: IPTV Recorder - by primaeval - 2019-04-26, 15:14
RE: IPTV Recorder - by Atamans - 2019-04-26, 15:33
RE: IPTV Recorder - by primaeval - 2019-04-26, 15:38
RE: IPTV Recorder - by Atamans - 2019-04-26, 16:11
RE: IPTV Recorder - by primaeval - 2019-04-26, 16:20
RE: IPTV Recorder - by Atamans - 2019-04-26, 16:26
RE: IPTV Recorder - by primaeval - 2019-04-26, 16:31
RE: IPTV Recorder - by Atamans - 2019-04-26, 16:41
RE: IPTV Recorder - by primaeval - 2019-04-26, 16:45
RE: IPTV Recorder - by Atamans - 2019-04-26, 17:17
RE: IPTV Recorder - by Radikaal - 2019-04-26, 17:52
RE: IPTV Recorder - by primaeval - 2019-04-26, 18:04
RE: IPTV Recorder - by Radikaal - 2019-04-27, 23:34
RE: IPTV Recorder - by primaeval - 2019-04-28, 09:25
RE: IPTV Recorder - by Atamans - 2019-04-27, 04:43
IPTV Recorder - by Abba2 - 2019-04-28, 22:07
RE: IPTV Recorder - by primaeval - 2019-04-28, 22:16
RE: IPTV Recorder - by Abba2 - 2019-04-28, 22:52
RE: IPTV Recorder - by Abba2 - 2019-04-28, 23:02
RE: IPTV Recorder - by primaeval - 2019-04-29, 08:56
RE: IPTV Recorder - by Abba2 - 2019-04-29, 13:02
RE: IPTV Recorder - by primaeval - 2019-04-29, 13:18
RE: IPTV Recorder - by Radikaal - 2019-04-29, 19:03
RE: IPTV Recorder - by primaeval - 2019-04-29, 19:09
RE: IPTV Recorder - by Abba2 - 2019-04-29, 23:59
RE: IPTV Recorder - by primaeval - 2019-04-30, 08:35
RE: IPTV Recorder - by Abba2 - 2019-04-30, 10:08
RE: IPTV Recorder - by primaeval - 2019-04-30, 10:32
RE: IPTV Recorder - by Abba2 - 2019-04-30, 13:01
RE: IPTV Recorder - by Abba2 - 2019-04-30, 13:03
RE: IPTV Recorder - by primaeval - 2019-04-30, 13:20
RE: IPTV Recorder - by luna128 - 2019-05-01, 00:52
RE: IPTV Recorder - by primaeval - 2019-05-01, 08:14
RE: IPTV Recorder - by luna128 - 2019-05-01, 20:48
RE: IPTV Recorder - by primaeval - 2019-05-01, 20:54
RE: IPTV Recorder - by luna128 - 2019-05-02, 00:07
RE: IPTV Recorder - by primaeval - 2019-05-02, 08:44
RE: IPTV Recorder - by luna128 - 2019-05-03, 01:45
RE: IPTV Recorder - by primaeval - 2019-05-03, 08:25
RE: IPTV Recorder - by erikprimo - 2019-05-02, 14:57
RE: IPTV Recorder - by primaeval - 2019-05-02, 15:05
RE: IPTV Recorder - by erikprimo - 2019-05-02, 15:57
RE: IPTV Recorder - by primaeval - 2019-05-02, 16:15
RE: IPTV Recorder - by erikprimo - 2019-05-02, 17:50
RE: IPTV Recorder - by primaeval - 2019-05-02, 19:06
IPTV Recorder - by ed_davidson01 - 2019-05-03, 03:59
RE: IPTV Recorder - by luna128 - 2019-05-03, 04:39
IPTV Recorder - by ed_davidson01 - 2019-05-03, 14:54
RE: IPTV Recorder - by samueljones - 2019-05-04, 18:22
RE: IPTV Recorder - by primaeval - 2019-05-04, 18:36
RE: IPTV Recorder - by samueljones - 2019-05-04, 19:53
RE: IPTV Recorder - by primaeval - 2019-05-04, 19:57
RE: IPTV Recorder - by samueljones - 2019-05-04, 20:02
RE: IPTV Recorder - by primaeval - 2019-05-04, 20:03
RE: IPTV Recorder - by samueljones - 2019-05-04, 20:07
RE: IPTV Recorder - by primaeval - 2019-05-04, 20:14
RE: IPTV Recorder - by samueljones - 2019-05-04, 20:18
RE: IPTV Recorder - by Abba2 - 2019-05-04, 22:45
RE: IPTV Recorder - by primaeval - 2019-05-05, 07:34
RE: IPTV Recorder - by rossi29 - 2019-05-05, 09:51
RE: IPTV Recorder - by primaeval - 2019-05-05, 09:56
RE: IPTV Recorder - by rossi29 - 2019-05-05, 13:28
RE: IPTV Recorder - by primaeval - 2019-05-05, 13:32
RE: IPTV Recorder - by Abba2 - 2019-05-05, 09:57
RE: IPTV Recorder - by primaeval - 2019-05-05, 09:58
RE: IPTV Recorder - by Abba2 - 2019-05-05, 13:19
RE: IPTV Recorder - by primaeval - 2019-05-05, 13:27
IPTV Recorder - by Abba2 - 2019-05-09, 02:06
RE: IPTV Recorder - by primaeval - 2019-05-09, 08:17
RE: IPTV Recorder - by Atamans - 2019-05-10, 10:03
RE: IPTV Recorder - by ramia - 2019-05-14, 02:53
RE: IPTV Recorder - by berkhornet - 2019-05-14, 15:41
RE: IPTV Recorder - by Atamans - 2019-05-14, 21:48
RE: IPTV Recorder - by berkhornet - 2019-05-15, 09:40
RE: IPTV Recorder - by Atamans - 2019-05-15, 11:15
IPTV Recorder - by berkhornet - 2019-05-15, 15:09
RE: IPTV Recorder - by fabd - 2019-05-16, 21:36
RE: IPTV Recorder - by seveneleven - 2019-05-22, 23:07
RE: IPTV Recorder - by Laser78 - 2019-05-26, 20:05
RE: IPTV Recorder - by giaur - 2019-05-29, 19:08
RE: IPTV Recorder - by mixpc - 2019-06-14, 14:25
RE: IPTV Recorder - by jhr1948 - 2019-06-14, 20:05
RE: IPTV Recorder - by ray2301 - 2019-11-11, 03:55
RE: IPTV Recorder - by Elluminatus - 2019-07-09, 10:36
RE: IPTV Recorder - by DarrenHill - 2019-07-09, 10:55
IPTV Recorder - by ZeroZorro - 2019-07-09, 11:57
RE: IPTV Recorder - by bartek35355 - 2019-07-24, 16:24
RE: IPTV Recorder - by VaderP - 2019-08-09, 00:18
RE: IPTV Recorder - by seveneleven - 2019-08-13, 00:26
RE: IPTV Recorder - by jarlaxx - 2019-09-01, 23:52
RE: IPTV Recorder - by jarlaxx - 2019-09-02, 04:54
RE: IPTV Recorder - by ramia - 2019-09-05, 08:31
RE: IPTV Recorder - by Arber - 2019-09-05, 11:16
RE: IPTV Recorder - by ramia - 2019-09-05, 16:52
RE: IPTV Recorder - by Arber - 2019-09-07, 10:14
RE: IPTV Recorder - by ramia - 2019-09-07, 19:15
RE: IPTV Recorder - by Nappis - 2019-09-07, 08:35
RE: IPTV Recorder - by Foxxyfox - 2019-09-07, 12:16
RE: IPTV Recorder - by DarrenHill - 2019-09-07, 20:37
RE: IPTV Recorder - by ramia - 2019-09-08, 02:08
RE: IPTV Recorder - by DarrenHill - 2019-09-08, 10:28
RE: IPTV Recorder - by ramia - 2019-09-08, 15:15
RE: IPTV Recorder - by DarrenHill - 2019-09-08, 15:27
RE: IPTV Recorder - by chezpaul - 2019-09-12, 23:01
RE: IPTV Recorder - by conFigureThat - 2019-10-13, 16:45
RE: IPTV Recorder - by conFigureThat - 2019-11-13, 08:19
RE: IPTV Recorder - by ryadre - 2019-11-09, 06:32
RE: IPTV Recorder - by mwkurt - 2019-11-10, 00:51
RE: IPTV Recorder - by Gtmnyc - 2019-11-10, 06:30
RE: IPTV Recorder - by mwkurt - 2019-11-18, 17:45
RE: IPTV Recorder - by snoopyjoe - 2019-11-20, 23:13
RE: IPTV Recorder - by conFigureThat - 2019-12-19, 21:33
RE: IPTV Recorder - by PeterWeb - 2019-12-19, 23:23
RE: IPTV Recorder - by thestupidbloke - 2019-12-28, 17:13
RE: IPTV Recorder - by powermarcel10 - 2019-12-28, 17:53
RE: IPTV Recorder - by thestupidbloke - 2019-12-28, 23:18
RE: IPTV Recorder - by powermarcel10 - 2020-01-02, 15:20
RE: IPTV Recorder - by Matt Sculley - 2019-12-29, 06:08
RE: IPTV Recorder - by thestupidbloke - 2019-12-30, 01:12
RE: IPTV Recorder - by Matt Sculley - 2019-12-30, 03:26
RE: IPTV Recorder - by thestupidbloke - 2019-12-30, 04:51
RE: IPTV Recorder - by damagom - 2020-01-01, 13:06
RE: IPTV Recorder - by dzejms - 2020-01-03, 20:51
RE: IPTV Recorder - by fcalcav - 2020-01-04, 22:40
RE: IPTV Recorder - by Erario - 2020-01-13, 09:20
RE: IPTV Recorder - by dzejms - 2020-01-13, 18:18
RE: IPTV Recorder - by Erario - 2020-01-13, 20:32
RE: IPTV Recorder - by pdario - 2020-01-16, 11:14
RE: IPTV Recorder - by pdario - 2020-02-12, 09:14
RE: IPTV Recorder - by thestupidbloke - 2020-02-12, 09:54
RE: IPTV Recorder - by dzejms - 2020-01-19, 14:37
RE: IPTV Recorder - by taker-` - 2020-01-27, 11:21
RE: IPTV Recorder - by thestupidbloke - 2020-02-06, 02:40
RE: IPTV Recorder - by taker-` - 2020-02-23, 22:11
RE: IPTV Recorder - by wrxtasy - 2020-05-20, 09:15
RE: IPTV Recorder - by wwwnolifer - 2020-01-31, 06:13
RE: IPTV Recorder - by lefty007 - 2020-02-02, 14:17
RE: IPTV Recorder - by wwwnolifer - 2020-02-05, 23:56
RE: IPTV Recorder - by SatanKlaus - 2020-02-10, 19:51
RE: IPTV Recorder - by thestupidbloke - 2020-02-11, 05:30
RE: IPTV Recorder - by coolbooy - 2020-02-13, 22:41
RE: IPTV Recorder - by taker-` - 2020-02-24, 08:51
RE: IPTV Recorder - by smurfinator - 2020-02-27, 04:46
RE: IPTV Recorder - by Publish3r - 2020-03-02, 14:39
RE: IPTV Recorder - by GriffeyJuni0r - 2020-03-08, 20:38
RE: IPTV Recorder - by smurfinator - 2020-03-16, 05:11
RE: IPTV Recorder - by _MarSs_ - 2020-03-19, 23:01
RE: IPTV Recorder - by ThePsy - 2020-03-28, 12:23
RE: IPTV Recorder - by ottobrerosso - 2020-03-30, 16:57
RE: IPTV Recorder - by Lorenzo101 - 2020-04-02, 17:11
RE: IPTV Recorder - by ottobrerosso - 2020-04-02, 17:34
RE: IPTV Recorder - by _MarSs_ - 2020-04-02, 22:31
RE: IPTV Recorder - by ThePsy - 2020-04-04, 07:46
RE: IPTV Recorder - by _MarSs_ - 2020-04-02, 22:18
RE: IPTV Recorder - by Lorenzo101 - 2020-04-02, 19:11
RE: IPTV Recorder - by Lorenzo101 - 2020-04-03, 12:30
RE: IPTV Recorder - by Lorenzo101 - 2020-04-06, 13:46
RE: IPTV Recorder - by ArcticBeast - 2020-04-06, 16:19
RE: IPTV Recorder - by techjohnny - 2020-04-10, 21:58
RE: IPTV Recorder - by samueljones - 2020-04-11, 21:17
RE: IPTV Recorder - by GTownClown - 2020-04-22, 08:18
RE: IPTV Recorder - by ArcticBeast - 2020-04-22, 13:33
RE: IPTV Recorder - by Jezze - 2020-04-26, 15:08
RE: IPTV Recorder - by samueljones - 2020-04-27, 00:33
RE: IPTV Recorder - by Jezze - 2020-04-27, 11:37
RE: IPTV Recorder - by samueljones - 2020-04-28, 20:27
RE: IPTV Recorder - by Jezze - 2020-05-02, 12:40
RE: IPTV Recorder - by ArcticBeast - 2020-05-03, 05:34
RE: IPTV Recorder - by kibtu - 2020-05-07, 10:33
RE: IPTV Recorder - by Laser78 - 2021-07-08, 16:31
RE: IPTV Recorder - by ArcticBeast - 2020-05-11, 19:56
RE: IPTV Recorder - by bojanodhrom - 2020-05-19, 23:10
RE: IPTV Recorder - by maslokm - 2020-05-13, 12:17
RE: IPTV Recorder - by roisiano - 2020-05-18, 22:39
RE: IPTV Recorder - by roisiano - 2020-05-19, 17:01
RE: IPTV Recorder - by bojanodhrom - 2020-05-20, 00:21
RE: IPTV Recorder - by Mildly_Interested - 2020-05-20, 18:41
RE: IPTV Recorder - by loginid - 2020-06-06, 03:35
RE: IPTV Recorder - by anjaklama - 2020-06-08, 00:57
RE: IPTV Recorder - by Zombi - 2020-06-08, 10:33
RE: IPTV Recorder - by anjaklama - 2020-06-08, 20:11
RE: IPTV Recorder - by berkhornet - 2020-06-11, 12:36
RE: IPTV Recorder - by Pete (NZ) - 2020-06-18, 02:21
RE: IPTV Recorder - by maslokm - 2020-06-20, 11:31
RE: IPTV Recorder - by Zombi - 2020-06-20, 11:40
RE: IPTV Recorder - by helio58 - 2020-09-09, 11:14
RE: IPTV Recorder - by Razer410 - 2020-08-04, 16:09
RE: IPTV Recorder - by helio58 - 2020-09-09, 11:16
RE: IPTV Recorder - by dustbro - 2020-09-21, 02:21
RE: IPTV Recorder - by 1deep - 2020-09-26, 20:47
RE: IPTV Recorder - by wheemer - 2020-09-27, 15:33
RE: IPTV Recorder - by jaggdd - 2020-09-23, 09:28
RE: IPTV Recorder - by 1deep - 2020-09-24, 10:49
RE: IPTV Recorder - by ArcticBeast - 2020-10-15, 23:04
RE: IPTV Recorder - by Rvhalewyn - 2020-11-15, 15:14
RE: IPTV Recorder - by 1deep - 2020-11-16, 02:17
RE: IPTV Recorder - by Rvhalewyn - 2020-11-16, 12:52
RE: IPTV Recorder - by Dragoun - 2020-12-17, 22:33
RE: IPTV Recorder - by Publish3r - 2021-01-18, 23:37
RE: IPTV Recorder - by dinjo - 2021-01-20, 06:56
RE: IPTV Recorder - by mpetit480 - 2021-01-20, 14:58
RE: IPTV Recorder - by M89SE - 2021-04-15, 07:53
RE: IPTV Recorder - by Kentsoon - 2021-03-21, 14:14
RE: IPTV Recorder - by dzejms - 2021-03-21, 14:21
RE: IPTV Recorder - by Kentsoon - 2021-03-21, 17:27
RE: IPTV Recorder - by Obsidian1 - 2021-03-24, 17:14
RE: IPTV Recorder - by jjojjo - 2021-04-15, 11:22
RE: IPTV Recorder - by M89SE - 2021-04-15, 15:29
RE: IPTV Recorder - by Publish3r - 2021-04-15, 16:52
RE: IPTV Recorder - by jjojjo - 2021-04-19, 16:12
RE: IPTV Recorder - by MrPatate - 2021-04-27, 16:38
RE: IPTV Recorder - by RKCRLR - 2021-05-04, 02:56
RE: IPTV Recorder - by RKCRLR - 2021-05-04, 19:51
RE: IPTV Recorder - by RKCRLR - 2021-05-04, 21:42
RE: IPTV Recorder - by MrPatate - 2021-05-10, 16:43
RE: IPTV Recorder - by Bua12120 - 2021-07-01, 13:28
RE: IPTV Recorder - by BreizhReloaded - 2021-07-05, 22:45
RE: IPTV Recorder - by michaelosh - 2021-07-05, 23:49
RE: IPTV Recorder - by Laser78 - 2021-07-08, 16:32
RE: IPTV Recorder - by michaelosh - 2021-07-12, 15:12
IPTV Recorder4
