2019-09-07, 12:16
Running Kodi on a 3b+ Raspberry pie. PVR Simple client running fine loads xmltv file.
However the IPTV Recorder only loads 5% of the xmltv file then reports 100% loaded. I can still set recordings via the PVR EPG with no problems but only with 5% of the IPTV Recorder EPG. Any one seen this is there an obvious error as both the PVR and IPTV recorder are using the same xmltv file. IPTV is pointed to the PVR xmltv currently. When I point IPTV recorder to the url holding the xmltv file the same happens what could be in the file that PVR accepts but IPTV recorder doesn't completely load?
Steve
Steve
