2018-12-16, 19:01
(2018-12-15, 14:20)noggin Wrote:A further update.(2018-12-14, 20:40)xpr982539 Wrote:(2018-12-14, 16:40)noggin Wrote: I know my Sony TV does HLG via it's internal iPlayer app, and I know I can manually select it in Picture Settings.Great investigative work there noggin.
I've just upgraded my HD Fury Vertex to the latest firmware as I think I was missing a DV update. (DV HDR was not being flagged as DV or HDR on the previous firmware, I now get DV flagged in the first line - but I guess no metadata as this is Dolby specific/proprietary, unlike HDR10 metadata which is open)
Unfortunately I am unable to force settings via my picture settings :-(
HLG seems to be an issue with my TV, although it does flip to it on iPlayer for Dynasties when going direct. But not through Kodi or iPlayer on the Fire Stick. I reckon you're right that there's is a gamut switching/flagging issue present on the Amazon Fire TV Stick 4K app.
For now I'll do a bit more research on which way to go for the main viewing room. I actually got the Firestick just for the bedroom 1080p panel, but couldn't resist giving it a good workout in 4K mode in the living room just in case it would save me £80 over a more capable unit! Guess not.
BTW, have you guys had success in adding other skins to Kodi RC2 on the Firestick? Mine doesn't seem to respond when I select the "Get more" option.
EDIT - nevermind about the skin. Once I plugged it back in downstairs it accepted the Skin update. Must have been when I was running 17.6 on the FireStick that it wouldn't add other skins.
Well - I've done a bit more digging now...
I downloaded the EDID data from my Sony TV (directly via an HDMI connected to the Sony TV) and from my Sony TV + Denon AVR combo.
In both cases the EDID block contained data in Static HDR Metadata fields confirming both ST.2084 (aka PQ/HDR10) and HLG support. The EDID also confirmed both RGB and YCbCr Rec 2020 support.
So why do both the Amazon Fire TV Stick 4K and Roku not output video with an HLG info frame flag (i.e. flag their outputs in HLG) can why does the Amazon Fire TV stick not flag Rec 2020 ? The TV EDID says it supports HLG and Rec 2020.
I wonder if there is something more that some devices look for to flag HLG and/or Rec 2020 support in an EDID block? Clearly something isn't right? (When I force HLG support to be reported by my HD Fury Vertex adding it to the TV's EDID both devices output HLG flagged video - though the FireTV Stick 4K still flags Rec 2020. The HD Fury Vertex also doesn't think HLG support is flagged in my TV's EDID I think, hence offering me the option of adding it)
EDID and HDMI Infoframes ARE confusing as extensions get added I guess...
What's encouraging is that the Sony TV does seem to report HLG compatibility.
(For info I exported the EDID from my HD Fury Vertex, and read it in two versions of Advantiv EEdit which is a free download)
My HD Fury Vertex was causing issues itself. It defaults to Force HDR10 only in Automix mode, and by default blocks HLG EDID from a display reaching a source. Disabling the forced HDR10 support means both my Roku and ATV Fire TV Stick 4K output HLG to my TV.
The iPlayer app on the Amazon Fire TV Stick 4K still outputs 59.94Hz only and Rec 709 flagged video (rather than 2020)... (The Roku iPlayer outputs Rec 2020 and 50Hz)
