2018 - Amazon Fire TV Stick 4K
(2019-01-11, 01:16)LukeHansford Wrote: These are the specs
https://www.sony.ie/electronics/televisi...ifications
1080p(30, 50, 60Hz), 1080/24p
Thats what my TV supports so does that mean it does support 24p?
What should kodi be set to?
Please try to understand the difference between:
1. Accepting a 24p signal (your tv and 99% can)
2. Displaying that signal correctly, as in. Showing each frame on the screen for the same amount of time resulting in smooth playback (many TVs cannot do this).
Likely your tv is converting the signal to 60fps by performing 3:2 pulldown (google that).
If the 24hz and 60hz setting results in identical looking playback, your TV cannot do #2 correctly.
If that is the case, you can experiment with the settings I spoke about in my previous post, or just set it to 60hz and forget about it.
Edit: I googled the model number again and found rtings review for X800D.
They say it can do judder free 24p..
Is this the same TV ? Jeez these model numbers are confusing.
2018 - Amazon Fire TV Stick 4K - by Hakuna99 - 2018-10-05, 09:57
RE: Amazon Fire TV Stick 2018 - by hdmkv - 2018-10-05, 14:36
RE: Amazon Fire TV Stick 2018 - by honcho - 2018-10-05, 17:37
RE: Amazon Fire TV Stick 2018 - by JekDuce - 2018-12-18, 12:16
RE: Amazon Fire TV Stick 2018 - by Hakuna99 - 2018-10-07, 09:50
RE: Amazon Fire TV Stick 2018 - by wrxtasy - 2018-10-07, 16:15
RE: Amazon Fire TV Stick 2018 - by hdmkv - 2018-10-08, 00:18
RE: Amazon Fire TV Stick 2018 - by aerogems - 2018-10-10, 22:31
RE: Amazon Fire TV Stick 2018 - by hdmkv - 2018-10-11, 00:23
RE: Amazon Fire TV Stick 2018 - by noggin - 2018-10-11, 11:55
RE: Amazon Fire TV Stick 2018 - by doug - 2018-10-08, 00:50
RE: Amazon Fire TV Stick 2018 - by aerogems - 2018-10-10, 22:46
RE: Amazon Fire TV Stick 2018 - by looun - 2018-10-11, 20:09
RE: Amazon Fire TV Stick 2018 - by honcho - 2018-10-12, 16:25
RE: Amazon Fire TV Stick 2018 - by aerogems - 2018-10-13, 00:50
RE: Amazon Fire TV Stick 2018 - by noggin - 2018-10-14, 11:07
RE: Amazon Fire TV Stick 2018 - by Vlaves - 2018-10-13, 09:55
RE: Amazon Fire TV Stick 2018 - by wrxtasy - 2018-10-31, 06:54
RE: Amazon Fire TV Stick 4K - 2018 - by Roen - 2018-11-01, 05:32
RE: Amazon Fire TV Stick 4K - 2018 - by Roen - 2018-11-01, 05:39
RE: Amazon Fire TV Stick 4K - 2018 - by Roen - 2018-11-02, 02:01
RE: Amazon Fire TV Stick 4K - 2018 - by hdmkv - 2018-11-03, 00:07
RE: Amazon Fire TV Stick 4K - 2018 - by hdmkv - 2018-11-13, 20:37
RE: Amazon Fire TV Stick 4K - 2018 - by hdmkv - 2018-11-13, 23:07
RE: Amazon Fire TV Stick 4K - 2018 - by hdmkv - 2018-11-16, 00:59
RE: Amazon Fire TV Stick 4K - 2018 - by hdmkv - 2018-11-16, 16:00
RE: Amazon Fire TV Stick 4K - 2018 - by hdmkv - 2018-11-16, 18:04
RE: Amazon Fire TV Stick 4K - 2018 - by hdmkv - 2018-11-18, 21:34
RE: 2018 - Amazon Fire TV Stick 4K - by arel - 2018-11-19, 11:57
RE: 2018 - Amazon Fire TV Stick 4K - by arel - 2018-11-19, 16:43
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-11-21, 02:02
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-11-21, 04:38
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-11-21, 16:22
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-11-22, 01:10
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-11-22, 19:30
RE: 2018 - Amazon Fire TV Stick 4K - by odoll - 2018-11-22, 13:15
RE: 2018 - Amazon Fire TV Stick 4K - by Breal - 2018-11-22, 14:35
RE: 2018 - Amazon Fire TV Stick 4K - by Breal - 2018-11-22, 16:32
RE: 2018 - Amazon Fire TV Stick 4K - by Breal - 2018-11-22, 17:34
RE: 2018 - Amazon Fire TV Stick 4K - by Sscr - 2018-11-23, 02:03
RE: 2018 - Amazon Fire TV Stick 4K - by Sscr - 2018-11-23, 17:53
RE: 2018 - Amazon Fire TV Stick 4K - by Sscr - 2018-11-23, 18:11
RE: 2018 - Amazon Fire TV Stick 4K - by Sscr - 2018-11-23, 22:10
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-11-24, 22:13
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-11-25, 02:42
RE: 2018 - Amazon Fire TV Stick 4K - by edent - 2018-11-25, 18:56
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-11-26, 01:44
RE: 2018 - Amazon Fire TV Stick 4K - by Jemus - 2018-11-30, 12:47
RE: 2018 - Amazon Fire TV Stick 4K - by Jemus - 2018-12-01, 15:55
RE: 2018 - Amazon Fire TV Stick 4K - by T3Sm0 - 2018-12-05, 23:03
RE: 2018 - Amazon Fire TV Stick 4K - by T3Sm0 - 2018-12-06, 23:18
RE: 2018 - Amazon Fire TV Stick 4K - by JiSiN - 2018-12-07, 16:47
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-12-07, 23:51
RE: 2018 - Amazon Fire TV Stick 4K - by JiSiN - 2018-12-09, 04:26
2018 - Amazon Fire TV Stick 4K - by sh33p - 2018-12-12, 20:24
RE: 2018 - Amazon Fire TV Stick 4K - by Livin - 2018-12-19, 22:07
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-12-28, 01:35
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2018-12-28, 03:55
RE: 2018 - Amazon Fire TV Stick 4K - by boood - 2018-12-31, 18:49
RE: 2018 - Amazon Fire TV Stick 4K - by jermo - 2019-01-02, 20:17
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-06, 18:23
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-07, 00:51
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-08, 03:15
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2019-01-07, 19:33
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2019-01-11, 23:56
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-08, 15:00
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-09, 03:31
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-12-02, 20:53
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-09, 20:19
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-09, 22:03
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-10, 04:37
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-10, 19:47
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-10, 21:22
RE: 2018 - Amazon Fire TV Stick 4K - by feathers - 2019-01-12, 01:21
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-01-11, 16:01
RE: 2018 - Amazon Fire TV Stick 4K - by tatir - 2019-01-19, 20:42
RE: 2018 - Amazon Fire TV Stick 4K - by tiasg - 2019-01-20, 23:03
RE: 2018 - Amazon Fire TV Stick 4K - by boood - 2019-01-23, 17:35
RE: 2018 - Amazon Fire TV Stick 4K - by boood - 2019-01-23, 18:31
RE: 2018 - Amazon Fire TV Stick 4K - by boood - 2019-01-23, 18:27
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2019-02-09, 19:55
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-02-13, 16:10
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-02-14, 14:39
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-02-16, 09:14
RE: 2018 - Amazon Fire TV Stick 4K - by boood - 2019-02-22, 21:57
RE: 2018 - Amazon Fire TV Stick 4K - by boood - 2019-02-23, 12:32
RE: 2018 - Amazon Fire TV Stick 4K - by Avds - 2019-02-25, 22:17
RE: 2018 - Amazon Fire TV Stick 4K - by Avds - 2019-03-02, 11:16
RE: 2018 - Amazon Fire TV Stick 4K - by Ukrop - 2019-09-08, 13:03
RE: 2018 - Amazon Fire TV Stick 4K - by boood - 2019-04-04, 10:19
RE: 2018 - Amazon Fire TV Stick 4K - by Avds - 2019-04-07, 22:43
RE: 2018 - Amazon Fire TV Stick 4K - by Avds - 2019-04-07, 23:16
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-04-20, 10:43
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-04-28, 13:34
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-04-30, 10:49
RE: 2018 - Amazon Fire TV Stick 4K - by Ukrop - 2019-09-08, 13:01
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-06-21, 17:23
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-07-30, 11:21
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2019-06-25, 03:01
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-06-26, 10:37
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-06-30, 16:04
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-07-01, 18:44
RE: 2018 - Amazon Fire TV Stick 4K - by ontap - 2019-07-15, 20:18
RE: 2018 - Amazon Fire TV Stick 4K - by co5mo - 2019-07-27, 15:59
RE: 2018 - Amazon Fire TV Stick 4K - by bivab - 2019-08-23, 09:43
RE: 2018 - Amazon Fire TV Stick 4K - by vlix - 2019-08-24, 09:12
2018 - Amazon Fire TV Stick 4K - by grabber - 2019-08-24, 15:27
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-09-08, 19:43
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-09-09, 02:10
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-09-10, 23:06
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-09-12, 16:07
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-09-12, 17:46
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-09-13, 10:06
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-09-13, 13:19
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-09-13, 14:07
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-09-13, 15:02
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-09-13, 15:27
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-09-13, 17:02
RE: 2018 - Amazon Fire TV Stick 4K - by ikudo - 2019-09-22, 11:55
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-10-30, 18:51
RE: 2018 - Amazon Fire TV Stick 4K - by movd - 2019-11-30, 19:52
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2019-12-02, 02:22
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-12-07, 12:48
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-12-07, 13:31
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-12-07, 13:44
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-12-07, 18:34
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2019-12-09, 00:52
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-12-18, 12:09
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2019-12-18, 23:38
RE: 2018 - Amazon Fire TV Stick 4K - by Nuke - 2020-01-06, 22:52
RE: 2018 - Amazon Fire TV Stick 4K - by Xc311 - 2020-01-12, 20:52
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2020-02-12, 00:41
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-02-12, 13:59
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2020-02-12, 19:09
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-02-12, 20:37
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-03-07, 20:34
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-03-08, 19:44
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-03-08, 20:54
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-03-09, 11:57
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-03-09, 13:27
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2020-03-15, 03:57
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-03-15, 20:05
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-04-01, 17:22
RE: 2018 - Amazon Fire TV Stick 4K - by Avds - 2020-04-06, 15:58
RE: 2018 - Amazon Fire TV Stick 4K - by Avds - 2020-04-06, 19:21
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-04-14, 11:04
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-04-26, 23:53
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-04-29, 00:51
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-04-30, 07:47
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-05-02, 00:18
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-05-02, 06:48
RE: 2018 - Amazon Fire TV Stick 4K - by Avds - 2020-05-26, 20:50
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-05-29, 14:28
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-06-01, 00:33
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-06-01, 15:17
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-06-05, 22:26
RE: 2018 - Amazon Fire TV Stick 4K - by A600 - 2020-06-06, 19:59
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-06-06, 20:56
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-06-07, 14:25
RE: 2018 - Amazon Fire TV Stick 4K - by ep0ch - 2020-06-20, 15:39
RE: 2018 - Amazon Fire TV Stick 4K - by ep0ch - 2020-06-22, 17:53
RE: 2018 - Amazon Fire TV Stick 4K - by ep0ch - 2020-06-22, 21:14
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-07-29, 01:51
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-08-01, 19:42
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-08-05, 01:00
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-08-09, 18:06
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-08-11, 17:14
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-08-15, 21:51
RE: 2018 - Amazon Fire TV Stick 4K - by Zass - 2020-08-18, 05:47
RE: 2018 - Amazon Fire TV Stick 4K - by Zass - 2020-08-18, 07:02
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-18, 16:29
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-19, 06:59
2018 - Amazon Fire TV Stick 4K - by f1vefour - 2020-08-18, 21:18
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-19, 11:52
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-19, 16:40
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-19, 14:11
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-19, 16:53
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-21, 11:56
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-21, 13:48
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-21, 19:35
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-22, 12:39
RE: 2018 - Amazon Fire TV Stick 4K - by bunts - 2020-08-22, 16:17
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-23, 07:28
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-23, 10:14
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-23, 13:45
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-24, 08:56
RE: 2018 - Amazon Fire TV Stick 4K - by gb160 - 2020-08-25, 17:23
Unable to get DTS passthrough - by antlane - 2020-08-26, 14:33
RE: 2018 - Amazon Fire TV Stick 4K - by Maito - 2021-04-03, 16:01
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-09-16, 16:21
RE: 2018 - Amazon Fire TV Stick 4K - by DB42 - 2020-09-17, 02:53
RE: 2018 - Amazon Fire TV Stick 4K - by grey - 2020-10-28, 12:40
RE: 2018 - Amazon Fire TV Stick 4K - by grey - 2020-10-28, 14:30
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-10-29, 21:11
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-11-07, 20:46
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2020-11-01, 02:29
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2020-11-01, 07:23
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2020-11-01, 14:20
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-11-08, 10:47
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-11-18, 21:18
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-11-27, 02:19
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2020-12-01, 04:18
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2020-12-01, 23:21
RE: 2018 - Amazon Fire TV Stick 4K - by d0zer - 2020-12-13, 15:24
RE: 2018 - Amazon Fire TV Stick 4K - by d0zer - 2020-12-14, 20:51
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-12-25, 07:49
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-12-14, 23:36
RE: 2018 - Amazon Fire TV Stick 4K - by FXB78 - 2020-12-16, 00:58
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2020-12-17, 00:16
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2020-12-24, 10:32
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-12-25, 23:17
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-12-27, 21:16
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-12-27, 22:54
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-12-27, 22:25
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-12-27, 22:13
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-12-27, 22:30
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2020-12-29, 19:13
RE: 2018 - Amazon Fire TV Stick 4K - by alea - 2021-01-03, 15:51
RE: 2018 - Amazon Fire TV Stick 4K - by alea - 2021-01-03, 21:00
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2021-01-04, 23:55
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2021-01-05, 16:58
RE: 2018 - Amazon Fire TV Stick 4K - by Drgit - 2021-01-23, 14:10
RE: 2018 - Amazon Fire TV Stick 4K - by Drgit - 2021-01-23, 15:33
RE: 2018 - Amazon Fire TV Stick 4K - by Drgit - 2021-01-23, 15:52
RE: 2018 - Amazon Fire TV Stick 4K - by Drgit - 2021-01-27, 13:44
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2021-02-12, 03:28
RE: 2018 - Amazon Fire TV Stick 4K - by qubed - 2021-02-06, 23:43
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2021-02-09, 18:48
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2021-02-11, 18:24
RE: 2018 - Amazon Fire TV Stick 4K - by hdmkv - 2021-02-17, 02:30
RE: 2018 - Amazon Fire TV Stick 4K - by PatK - 2021-02-18, 20:45
RE: 2018 - Amazon Fire TV Stick 4K - by PatK - 2021-02-19, 00:12
RE: 2018 - Amazon Fire TV Stick 4K - by Wagg - 2021-02-19, 21:50
RE: 2018 - Amazon Fire TV Stick 4K - by himey - 2021-02-22, 23:09
RE: 2018 - Amazon Fire TV Stick 4K - by meccs - 2021-02-24, 23:56
RE: 2018 - Amazon Fire TV Stick 4K - by meccs - 2021-02-26, 10:29
Force refresh rate? - by boboc - 2021-03-31, 00:45
2018 - Amazon Fire TV Stick 4K3
