2020-03-23, 02:15
(2020-03-22, 23:09)banderson1311 Wrote: I tried the test Leia build and it fixed audio delay issues for most of my video files. However, I was still seeing about 200-250 ms audio delay for Dolby Digital Plus (eac3) files. In the end I had to revert back to the standard 18.6 so everything would have the same delay. Has anyone else run into issues specifically with eac3?
The only files I've noticed issues with since Fritsch's fix is episodes of Curb Your Enthusiasm which, now that you mention it, do in fact use DD+. And yes I still have to manually delay those 250ms.
But a large percentage of my movies also use DD+, and I've never had sync issues with any of those (I just verified this to be sure). Just with stereo files -- now fixed by fritsch -- and these Curb eps.
Mediainfo from MPC-HC for Curb, which requires 250ms offset:
Quote:2
Format : E-AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_EAC3
Duration : 45mn 8s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 11ms
Stream size : 82.7 MiB (5%)
Default : Yes
Forced : No
And from a movie I just watched that was perfectly in sync:
Quote:ID : 4
Format : E-AC-3
Codec ID : A_EAC3
Duration : 2h 4mn
Bit rate : 640 Kbps
Stream size : 569 MiB (7%)
Language : English
Default : No
Forced : No
