2020-10-08, 00:29
(2020-10-07, 10:05)xalex75 Wrote: Hi.
I own a 4K Fire TV Stick since its launch.
I thinks it's almost perfect, fast, reliable, etc. etc., but when I need to use Kodi, I always have to use another device because Fire TV does not support DTS passthrough.
I bought a MI TV Stick, Kodi works perfectly and DTS plays quite well, but the stick is really to much bugged, and slow.
I tried to install kodi-20201001-5c717b66-fritschfiretv-armeabi-v7a.apk, but I noticed that DTS options are still not available in Kodi.
Is there a way to make it work, or should I forget having DTS on Fire Stick 4K?
My audio system does not have HDMI, the firestick is connected to a splitter, which takes audio to receiver via optical cable.
This way Mi TV Stick has no problems and Kodi shows DTS options, but with Fire TV 4K it doesn't.
If you have the Firetv 4K's own setting _not_ set to Dolby Digital+ then all PT will be disabled in kodi. Check that setting in the FireTV settings, please, if it's set to Stereo only, no PT in kodi.
DTS, DTS-HD-HR, AC3 and DD+ will work with Firetv 4k just fine. And also 5.1 / 7.1 LPCM
