2020-05-08, 20:05
(2020-05-08, 06:26)Picard Wrote:(2020-05-08, 06:02)mardukL Wrote:It seems to be installed properly, when i hit the mic symbol, doesn't start up, i've tried uninstalling and reinstall, still no luck, what version are you using?(2020-05-08, 05:50)Picard Wrote: Love this skin, good work, even though it's a work in progress, is there a trick to getting CU LRC Lyrics to work?
i dont think its problematic.
if you toggled auto-show lyrics off via addon settings you should be able to show it when click on the microphone icon on the left side of osd.
got no issues with it on android/win os running kodi leia 18.6 .
Sometimes it takes a bit to load/get lyrics, but you should be notified when the scripts start.
May there is an error in the lookups.
Did you also get issues with estuary skin?
