My plasma have Auto full or normal settings (panny vt60)
I will try without avr
thank you
jteeuw
Junior Member
I trying to compile kodi from git but get the following error:
checking for EGL... no
configure: error: Could not find a required library. Please see the README for your platform.
fritsch
Team-Kodi Developer
2015-09-21, 15:31
(This post was last modified: 2015-09-21, 15:31 by fritsch.)
You need mesa 11.0 or wsnipex 10.6.6 patched version. For building though:
libegl1-mesa-dev
is enough. Same is needed for your libva ...
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
Hey fritsch. Just started using your latest Isengard build. Its really great. I dont know if its just code optimization or something else but it feels very very snappy compared to other Isengard builds and of course Jarvis builds. This is perfect! Thank you so very much!
I have installed the latest Jarvis OE build on MY SandyBridge NUC . My TV can be on limited or full range, Kodi can be set accordingly, but how do I check the Gpu setting?
Or is that not needed anymore since the autostart.sh isn't needed anymore?
I want to be sure I have good settings in case I need to post a debug log.
My XBMC / Kodi history.
XBMC for XBOX -> XBMC for Windows -> XBMC for Android -> Kodi for Android - > Kodi v16 OE (Amlogic) -> Kodi v17 LE (NUC 2x) -> Kodi v18.5 LE (NUC 2x)
Full range on the gpu works out of the box since 150920. Set kodi and TV to limited, for example, and if everything looks normal, the default hack works.
Thanks for the quick reply, although all seems fine indeed. I was wondering how the default setting handles 2 hdmi ports in the NUC.
download avshd 709 test (mp4 format) and run basic settings test(you find explanation in this thread)
don't follow what i wrote in my last post cause my auto range settings was corrupted
Now with limited i have black level correct and white clipping test 230-241
I guess, if everything looks normal on the Hdmi port your using, the hack (hdmi1) applies to that port. One of the ports should give you black crush, wrong picture, with kodi and TV set to limited.
You can also confirm hack with xrandr --verbose
