16:14:13 T:2695883632 ERROR: Error Contents: 'utf8' codec can't decode byte 0xf2 in position 967: invalid continuation byte
16:14:13 T:2695883632 ERROR: Traceback (most recent call last):
File "/home/m4x1m/.xbmc/addons/script.randomitems/RandomItems.py", line 379, in <module>
Main()
File "/home/m4x1m/.xbmc/addons/script.randomitems/RandomItems.py", line 74, in __init__
self._fetch_episode_info()
File "/home/m4x1m/.xbmc/addons/script.randomitems/RandomItems.py", line 132, in _fetch_episode_info
json_response = simplejson.loads(json_query)
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/__init__.py", line 413, in loads
return _default_decoder.decode(s)
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 402, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 418, in raw_decode
obj, end = self.scan_once(s, idx)
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/scanner.py", line 71, in scan_once
return _scan_once(string, idx)
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/scanner.py", line 42, in _scan_once
_scan_once, object_hook, object_pairs_hook, memo)
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 230, in JSONObject
value, end = scan_once(s, end)
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/scanner.py", line 44, in _scan_once
return parse_array((string, idx + 1), _scan_once)
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 284, in JSONArray
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/scanner.py", line 39, in _scan_once
return parse_string(string, idx + 1, encoding, strict)
File "/home/m4x1m/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 121, in py_scanstring
content = unicode(content, encoding)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xf2 in position 967: invalid continuation byte
Similar error in script.globalsearch when searching in TV Shows ...
