2012-01-05, 16:59
(example 1)
If I chose music, music library, (select an artist) the songs appear.
There are three tabs across the top of the screen..
'home'/music-library/songs
they are not active tabs however so to get back to music-libray involves
clicking to the root of the artist songls as selected,
then repeating the " .. " click, then
scrolling to the top of the list of artists, then (!),
finally we are back at the *root* version of 'music - library'
Or,
(example 2)
clicking on the 'home' tab, then
Music/library
This however brings you right back to the recently selected artist, album and selection of songs.
This is useful, but I would like to just get to the *root* of the music-library.
The tabs across the top of the screen I feel should be as they show, you click on "a/n other" tab and it brings you to the *root* version of whatever that option is, allowing the 'home' version to shortcut you back to where you were before via the main screen bar (example 2)
PS, I only use 'confluence' skin!
Or,
(example 2)
Music/library
