2012-03-20, 17:26
2012-03-20, 21:43
Isn´t this possible already?
I guess you can select icon apcks in the skin settings?
geht das nicht bereits?
Meines wissens lässt sich in den Einstellungen doch ein icon pack auswählen?
2012-03-20, 22:15
Yep, it's possible since MQ 2.6...
Hah, schwurz it is you...dind't check...
So I suppose that the issue is solved due to our German HowTo...
