There is a whole lot of bad in that log. The tuner drivers don't seem to be working correctly since a lot of the queries to them are failing. You might want to restart wmc and make sure it is working correctly (can view live-tv), or just reboot your server machine.
It also seems like your recording tv folder is not set as a network share, and it possibly entered more than once into the wmc registry? Not sure about that, but go into wmc and check the recording tv folder location and make sure there is only one entry (the one you expect). Then make sure the recorded tv folder is shared so that your client machines can access it.
After all that, post the log again if you still have problems.
Yes, much much better. I can't tell from the log though whether your client is on the same machine as the server, but I am guessing it is, right? And you still can't play recordings? If so, try turning this setting back to the default, i.e.:
<Debug_RequestAllRecordings>false</Debug_RequestAllRecordings>
Then save the config and RESTART swmc. Let me know what happens.
My client is on an amazon fire tv and my Server is windows 7 recordings still will only play after I restart the server It also says recording tv folder not found every time I start KODI
http://pastebin.com/raw.php?i=VuFBkppP
Your fire is not able to access your recorded tv folder, that's what these errors in your log mean:
2015/01/03 04:32:36.137 StreamStartError> client 'localhost' reports error opening stream, will close stream down
2015/01/03 04:32:36.137 StreamStartError> client 'localhost' path to stream file: 'smb://Aaron:******@SERVER/Recorded TV/Beyond Scared Straight_AETVHD_2014_12_18_21_01_00.wtv'
My guess is, this is do to credentials. Make sure the credentials you entered into serverwmc's folder tab are correct.
Well from what I could tell I had the correct password under the folders tab in ServerWMC. I reentered it and it worked. Then to test to see if that was the issue i entered the wrong password and it still worked. from what I can tell whatever password I enter has no effect of wether it works or not
http://pastebin.com/raw.php?i=k0xDaqrF
Can you turn credentials off and it still works?
Your system seems to be back in the same state it was in on your first log. Try doing whatever you did then to fix it.
So I found out I had some networking issues which was the cause of the Front-end not loading at all. After it was fixed I tried recording something with the correct password. Then I opened Kodi and it said recording folder not found. I tried changing the password to a wrong one restarted Server WMC and opened up Kodi it said recording folder not found. Then I tried disabling credential all together closed and reopened ServerWMC and Kodi it still said recording folder not found. So then I tried enabling credentials with the wrong password and restarting my Front-end everything seemed to work. Then I recorded something and reopened Kodi recording folder not found. Honestly I don't see why it would even be a permissions issue because everyone has full control of the folder. Sorry for the long winded post
http://pastebin.com/raw.php?i=inYqtre9
Do you have any strange characters in your username or password or anything like that? Perhaps that is tripping things up
Try creating a new windows user on your ServerPC called say "xbmc" with password "xbmc". The "everyone" permission on your share should mean that user can access it. Then specify xbmc/xbmc in the credentials in ServerWMC
also this client machine - is DNS all good for it? Can it ping "SERVER" and get the correct IP address? What have you set in the pvr.wmc addon settings on the client side, for the hostname/port of the ServerWMC machine? Are you using "SERVER" or have you specified the IP address? If you have to use IP address then you also need to put the IP address in ServerWMC side rather than the hostname "SERVER" since the client may not be able to resolve that path
It seems now any recording record with user xbmc won't play until I switch ServerWMC over to Aaron but what was recorded with user Aaron plays fine with user xbmc
http://pastebin.com/raw.php?i=Ev4CWBWf
