Can I change the menu panel to something like this:
Home | TV | TV Shows | Movies | Videos | Music | Music Videos | Pictures |
If I can't do it natively, is there a mod that I can use?
Running 16.1 Jarvis but can upgrade to 17 Krypton, if that's what's required.
thanks
Anybody?
I downloaded Krypton and used the Estuary Mod add panels to the menu - is there a reason it's not possible with this skin?
Will it be added in the future?
This is the only skin I really like, has a professional, polished look about it, so hopefully I'll be able to do this.
thanks
We don't support these kind of customisations e.g. re-ordering or renaming of the main categories.
(2016-09-28, 22:39)xhaggi Wrote: [ -> ]We don't support these kind of customisations e.g. re-ordering or renaming of the main categories.
Absolutely this. phil65 and I designed Estuary with full customisation in mind. Xperience1080 offers limited customisation where xhaggi and I think it's required.
Thanks for your replies.
When you say this customization is not supported, do you mean it's just not officially supported and that this could be done by a user editing files themselves?
(2016-10-01, 21:56)TarPaulin Wrote: [ -> ]Thanks for your replies.
It could be done, but it's certainly not a simple matter... depending on what you want to change. I would also not advise you to change files as they will be overwritten when updates are issued.
