Just a question. I'm using Aeon MQ 2 and in the /media/ folder of the skin there's only one file called "textures.xbt".
If I copy all the pics to that folder, Aeon won't use them and if I delete the "textures.xbt" Aeon looks like crap (all the backgrounds are gone etc.)
So what am I missing?
Aeon mq2 use one single files for all texture of the skin i presume, is not possible to modify the studios logo.
I don't know if is possible to open this files sry.
Choque, you need to ask Marcos about adding studio flags. Textures.xbt already have the required white flags, the skin uses them by default. If you want to try the colored logos, you should try Aeon, or any other skin of your choice provided that skin doesn't use textures.xbt
Simzer0, awesome work and thanks for posting; these flags look phenomenal!
A question, if you don't mind: I actually have a number of high-res studio logo images as well which I'd be happy to make flags out of and help contribute - any tips on how to go about creating these (in regards to resizing, transparencies, etc)? I know my way around photoshop, but I'm no expert, I'm afraid
Choque Wrote:Just a question. I'm using Aeon MQ 2 and in the /media/ folder of the skin there's only one file called "textures.xbt".
Assuming you're using 2.8.1, check out the link in this post:
http://forum.xbmc.org/showpost.php?p=787...count=3997
In short, delete textures.xbt, replace the media folder with the uncompressed version linked above, and you can change around flags as you like.
Have you also downloaded the uncompressed textures from
http://mod-skin.googlecode.com/files/media-2.8.1.zip?
EDIT:Sorry for double post...this morning I can not open my eyes so far :-)
mm
cnm25 Wrote:Simzer0, awesome work and thanks for posting; these flags look phenomenal!
Thx cnm25,
if this logos is missing in this collections or your images is much better, send me and i work on it to add
Shinu Wrote:i hope it's ok by u Simzer0, but i made a black & white version of ur collection, for use with skins that don't use colored flags.
http://www.megaupload.com/?d=QY2URA6N
No problem mate, im on work now to add some logos lost.
Hi a German Guy doesnt understud where i must put the studio logos. I have download this-->
http://mod-skin.googlecode.com/files/media-2.8.1.zip--- and but it in this Folder.
C:\Dokumente und Einstellungen\name\Anwendungsdaten\XBMC\addons\skin.aeonmq.2
but it doesnt works.Where is the mistake?
Sorry for bad english
I add some new logos and correct old on fist page.
Awesome work! I requested this a while back, nice to see someone else wanted it too.
Sample images:
The colored logos are way better in looks than those white ones. If studio logos become a separate addon in the future, they should be colored ones.
Please change the following:
Fox TV:
USA-HD:
USA:
ABC:
@ Simzer0, I have made a few colored studio logos by myself. I want to add to the collection of yours after you approve the quality of my work. How can I do that?
