2011-05-18, 13:31
2011-05-20, 09:37
http://www.mediafire.com/file/hbiess50rh0o53q/Logos.zip
@ Simzer0,
Some of the Colored logos I have tried to create of my own. I am not a pro though, hopefully, with some adjustments, they will be usable
@ Simzer0,
2011-05-23, 12:40
I take your flags and look is very good but only so much big, if you want i work on it and post the link on first post.
2011-11-11, 22:41
2011-11-12, 23:34
2011-11-13, 13:02
Hi, I thought I'dd add some more studio logos here, there is a mix of Movie and TV network logos of varying dimensions. I havent had time to make them uniform so i thought i'd post them here. There are 1,111 icons in total in the zip file:
1,111 Studio and TV Network icons.zip
2022-09-24, 18:35
Hello,
I just bought a new htpc and had a lot of trouble reinstalling Kodi on it.
I put you the link of the topic created in relation to this.
https://forum.kodi.tv/showthread.php?tid...pid3112076
I think I finally found the problem and I would like to be guided if possible because I was sent here for this problem.
Can you tell me what you think? Thank you very much in advance.
