I have done force refresh and have version 1.5.3 but keep getting error message:
Process Failed: OLD VERSION ALERT
You are at old version of add on
Steps: http://...
Can you please help!
Thanks Ajay it works perfectly. I have another question in Raspberry Pi SD card speed can affect the performance of Raspberry Pi.
(2013-06-22, 03:52)vk2006 Wrote: [ -> ]Thanks Ajay it works perfectly. I have another question in Raspberry Pi SD card speed can affect the performance of Raspberry Pi.
I am sorry I don't use it, so cannot comment on this point.
Hi Ajay:
I am getting this error ...
Failure: Unable to Connect
Please choose a different source if available in the add-on. Website used in the add-on is down, try to access the website through a browser and share the logs with the developer.
Do you know if the site will be coming back up soon? If the site is up, can you please help me fix this issue? Thanks so much in the advance, and you've done a great job with this add-on!! Thanks a million!
same here
I DONOT host website, so I donot know when it will be up again. There is nothing I need to fix, once website is up: addon will work.
It's simple!!
YuppTV streams went down for me. anyone else facing same problem> thanks
The site is up. R u updating?
(2013-06-27, 15:09)zit1343 Wrote: [ -> ]YuppTV streams went down for me. anyone else facing same problem> thanks
What??? Which yupptv stream. There were never yupptv streams on Filmi by nature
(2013-06-28, 02:00)adrk Wrote: [ -> ]The site is up. R u updating?
Done. The website URL is changed and pushed an update. To get an update, do force refresh on aj add ons repository.
(Google if don't know how to do force refresh).
(2013-06-28, 02:51)ajay Wrote: [ -> ] (2013-06-28, 02:00)adrk Wrote: [ -> ]The site is up. R u updating?
Its working. You really deserve a millions thanks for your hard working to keep this addon up.
Hi Aj, the download video option doesn't work any more in filmi addon.i do have simple video downloaded plugin installed in xbmc.can u check pls.it used to work before,download doesn't progress since few weeks.
Thanks Ajay for your contribution. I'll check out the repo status and let you know.
