Hello.
On latest nightly Build and 4.3:
When hardware acceleration Tool is enabled, I only have sound and Grey screen?
When I disable hardware acceleration tools, All works :confused2:
The same issue for my freind on his atv2
Regards Oluf
Ned Scott Wrote:Not sure what you are even trying to do, let alone what the issue could be.
Do this: HOW-TO post about a XBMC for iOS problem (AKA YOU MUST POST XBMC.LOG SO WE CAN HELP)
Hello Ned.
Always a quickly answer
but try to read my thread carefully... Here needs no logs and so on. Its Ok in most of the threads. But in my case, I gave an information about a generel problem included solution maybe. Thanks for understanding
Oluf
oluf Wrote:Hello Ned.
Always a quickly answer but try to read my thread carefully... Here needs no logs and so on. Its Ok in most of the threads. But in my case, I gave an information about a generel problem included solution maybe. Thanks for understanding
Oluf
no logs = no help
Ned Scott Wrote:no logs = no help
He doesn't seem to want help. He only wanted to inform us that switching of VTB fixes his problem.
I got that part, but disabling HW decoding is far from an ideal solution. But whatever floats his boat.
So just to clarify, when using some addon that lets you watch danish live tv if all you can see is a grey screen, turn off hardware acceleration and you'll get the video image.
Is that what the message is?
Ned and Memphiz.
I just got my Macbook from repair. Now I am able to send the needed log.
Problem: When I switch on the hardware acc Tool, I only get a grey screen on the addon: Danish Live TV. It is OK when it is OFF, but not very good
because one of the programs is in HD ...
XBMC works nicely with the platform:
Mac OS X (11.0.0 AppleTV2,1). Built on Sep 26 2011 (Git:20110926-6c08a58)
I always get a script error in the start "script error: service.py".
http://pastebin.com/PMc672KC
Please excuse my late respons, but it is difficult to make my log with an iPhone.
Will you look at it, at give me a comment
Best regards Oluf
VTB does not seem to like the h264 that comes from Danish Live TV
davilla Wrote:VTB does not seem to like the h264 that comes from Danish Live TV
Hello davilla.
Is the script error from that mistake :confused2:
Oluf
To be precise. The hardware acceleration chip just pukes on the stream. Only one person in the world might be able to figure this out... maybe 2... but i for myself wouldn't put much hope in it ...
Memphiz Wrote:To be precise. The hardware acceleration chip just pukes on the stream. Only one person in the world might be able to figure this out... maybe 2... but i for myself wouldn't put much hope in it ...
Please give me some names
I'm the author of the addon and the script error is unrelated to this problem, just to clear the confusion, if any.
I'm wondering if it is possible to check from python whether hardware acceleration is enabled or not and possible enable/disable it. Then the addon could enable/disable hardware acceleration as needed.
Br.
Tommy
twinther Wrote:I'm the author of the addon and the script error is unrelated to this problem, just to clear the confusion, if any.
Br.
Tommy
Hello Tommy
Sounds like at good solution,
except the DR HD program is bad with no VTB.
Regards Oluf
oluf Wrote:Hello Tommy
Regards Oluf
nahh ... not really a solution. The decoder should detect if he supports a format or not. And if the plugin switches the decoder off it just would mean stuttering because of lack of cpu power. In this special case there is no solution by now imho. A fix would be that the decoder detects that he can't handle the file and ffmpeg is used automtically - but thats only "cosmetic" in that case ...
