2011-11-20, 03:08
Hello!!!
I've found a very nice and simple program to create thumbnails.
Source:
http://www.xbmcnerds.com/index.php?page=...eadID=2368
Quote:Extrathumbs creating via a batch
For those who want to read the other thread:
Extrathumbs are small images (film clips), which are a couple of skins (Aeon, Carmichael, etc.) are supported.
Place the images \ movie folder \ Extrathumbs \ thumb1 .... X. ..
Luckily you will find a small tool (Linux, Windows, Mac OS) via a batch Extrathumbs to create at will:
http://www.megaupload.com/?d=BUR5G8OP
Note: thumber-h is actually the most essential information ...
thumber.config can be opened with an editor to change settings such as Thumbgsize existing overwriting, etc. set.
Tip: I would not set the path to be scanned in the thumber.config that was neat for me problems!
ATTENTION: Thumber only works if there are films that are in one file, so FilmCD1 & FilmCD2 can create the While Thumber XBMC but it can not represent.
Source:
