2011-12-28, 19:19
2011-12-28, 20:20
Doesn't work here :-(
Here is my Code as i am using Opdenkamps XBMC-pvr Master.
I changed the file xbmc/cores/dvdplayer/DVDInputStreams/DVDInputStreamNavigator.cpp code this way:The debugs give me the following (which is a little confusing since trying to open /initrd.img as DVD is senseless):
Which other previous commit do I need?
@vdrfan: which version do you use? Youre nick implies that you use opdenkamp and pipelka too, right?
// libdvdcss fails if the file path contains VIDEO_TS.IFO or VIDEO_TS/VIDEO_TS.IFO
// libdvdnav is still able to play without, so strip them.
// stripping only works 100% correctly for absolute paths.
// relative paths are not expected here and wouldn't make sense, so it's safe to assume we'll have
// at least one path separator character.
strDVDFile = strdup(strFile);
int len = strlen(strDVDFile);
CLog::Log(LOGDEBUG, "===============HANNEMANN: strFile %s",strFile);
CLog::Log(LOGDEBUG, "===============HANNEMANN: strDVDFile %s",strDVDFile);
#ifndef _LINUX
if (len >= 13 // +1 on purpose, to include a separator char before the searched string
strnicmp(strDVDFile + len - 12, "VIDEO_TS.IFO", 12) == 0)
strDVDFile[len - 13] = '\0';
if(len >= 9 // +1 on purpose, to include a separator char before the searched string
strnicmp(strDVDFile + len - 8, "VIDEO_TS.IFO", 8) == 0)
strDVDFile[len - 9] = '\0';
#else
if(len >= 13 // +1 on purpose, to include a separator char before the searched string
&& strncasecmp(strDVDFile + len - 12, "VIDEO_TS.IFO", 12) == 0)
&& strncasecmp(strDVDFile + len - 8, "VIDEO_TS", 8) == 0)
#endif
#if defined(__APPLE__) && !defined(__arm__)
// if physical DVDs, libdvdnav wants "/dev/rdiskN" device name for OSX,
// strDVDFile will get realloc'ed and replaced IF this is a physical DVD.
19:09:26 T:140479310936032 DEBUG: ExecuteXBMCAction : Translating XBMC.PlayDVD()
19:09:26 T:140479310936032 DEBUG: ExecuteXBMCAction : To XBMC.PlayDVD()
19:09:26 T:140479310936032 DEBUG: CPlayerCoreFactory::GetPlayers(/initrd.img)
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: dvdimage
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: adding player: videodefaultdvdplayer (1) for rule: dvdimage
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
19:09:26 T:140479310936032 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
19:09:26 T:140479310936032 DEBUG: CPlayerCoreFactory::GetPlayers: matched 1 rules with players
19:09:26 T:140479310936032 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
19:09:26 T:140479310936032 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
19:09:26 T:140479310936032 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
19:09:26 T:140479310936032 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
19:09:26 T:140479310936032 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
19:09:26 T:140479310936032 NOTICE: DVDPlayer: Opening: /initrd.img
19:09:26 T:140479310936032 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:09:26 T:140479310936032 DEBUG: LinuxRendererGL: Cleaning up GL resources
19:09:26 T:140479310936032 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avutil-50-x86_64-linux.so)
19:09:26 T:140479310936032 DEBUG: Loading: /usr/lib/xbmc/system/players/dvdplayer/avutil-50-x86_64-linux.so
19:09:26 T:140479310936032 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/swscale-0-x86_64-linux.so)
19:09:26 T:140479310936032 DEBUG: Loading: /usr/lib/xbmc/system/players/dvdplayer/swscale-0-x86_64-linux.so
19:09:26 T:140478649464576 DEBUG: Thread CDVDPlayer start, auto delete: 0
19:09:26 T:140478649464576 NOTICE: Creating InputStream
19:09:26 T:140478649464576 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/libdvdnav-x86_64-linux.so)
19:09:26 T:140478649464576 DEBUG: Loading: /usr/lib/xbmc/system/players/dvdplayer/libdvdnav-x86_64-linux.so
19:09:26 T:140478649464576 DEBUG: ===============HANNEMANN: strFile /initrd.img
19:09:26 T:140478649464576 DEBUG: ===============HANNEMANN: strDVDFile /initrd.img
19:09:26 T:140478649464576 INFO: msg: libdvdnav: Using dvdnav version 4.1.3
19:09:26 T:140478649464576 INFO: msg: libdvdread: Using libdvdcss version 1.2.10 for DVD access
19:09:26 T:140478649464576 INFO: msg: libdvdnav: vm: DVD Title: [���>�8%2��'�������o|@9��~��,�
19:09:26 T:140478649464576 INFO: msg: libdvdnav: Unable to find map file '/home/xbmc/.dvdnav/[���>�8%2��'�������o|@9��~��,�.map'
19:09:26 T:140478649464576 INFO: msg: libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
19:09:26 T:140478649464576 INFO: msg: libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
19:09:26 T:140478649464576 DEBUG: libdvdread: Can't open file VIDEO_TS.IFO.
19:09:26 T:140478649464576 DEBUG: libdvdnav: vm: failed to read VIDEO_TS.IFO
2011-12-28, 21:34
I tried it again with eden-pvr now and its still the same.
2011-12-29, 06:45
I just wanted to let everyone know that I was having the same issue after I installed Eden with recent commercial DVDs. I was reading the post about Eden freezing on Blu-Ray and someone noted that you should try AnyDVD HD. I installed it on my machine and rebooted per the AnyDVD install req's and voila! Everything started working as it did in 10.1. I hope that helps a developer out and I'll be happy to provide some logs if necessary.
2011-12-29, 15:43
I've found a workaround for the initrd.img problem on Linux:
http://forum.xbmc.org/showpost.php?p=971939&postcount=6
2011-12-29, 16:05
it probably works because then in CDVDPlayer::OpenInputStream() it matches the protocol again (it was dvd:// earlier) and the media manager returns the true device with g_mediaManager.TranslateDevicePath("").
Unfortunately this will only open the first available device in case you have two.
The Linux Dev needs to find a more suitable way.
2011-12-29, 16:15
You're right. The workaround works for me as my HTPC's host only one optical Drive. One should keep that in mind if considering to use that ugly piece of code ;-)
2011-12-29, 16:15
BTW make sure you try with the latest trunk and not with Eden and a few manually changes.
2012-01-16, 19:51
Has this been resolved for Windows machines?
2012-01-19, 15:24
beta2 will have the fixes which are in master currently.
2012-01-21, 18:41
Can someone confirm if AnyDVD (not HD) will resolve this on Windows boxes?
I love XBMC but not being able to play the kids DVDs isn't going down well
Big thank you
Lea
Big thank you
Lea
2012-01-21, 19:06
WiSo Wrote:beta2 will have the fixes which are in master currently.
Just tried it with Beta 2 and it still freezes the home screen solid until the dvd is ejected.
2012-01-21, 21:26
I can confirm that Beta 2 seems to have fixed the problems I reported here above (2011-12-16, 22:35). XBMC plays a commercial DVD that I insert in the drive and then plays another different DVD that I insert. The per-DVD position memory appears to be working too. If I see any issues I'll post again.
2012-01-21, 21:59
blimey, beta 2 is released and I didn't know...did I miss the facebook announce? Cheers, will give it a go and let ya know.
2012-01-21, 22:26
Perfect, beta 2 solves the issue...thanks XBMC devs
