So I accidentally upgraded to Frodo last night (when do I try to think late at night
) one think has changed in this great skin.
Library update progress used to show at the top of the screen (like a status bar) and would go into the back ground if a video was started. Now they open a dialog box in the middle of the screen.
Is there any way to fix this?
Thanks in advance.
(2012-11-13, 18:19)rcrh Wrote: [ -> ]So I accidentally upgraded to Frodo last night (when do I try to think late at night) one think has changed in this great skin.
Thanks in advance.
did you upgrade Transparency! as well?
you need to install the svn version is you use xbmc frodo.
(2012-11-13, 19:13)ronie Wrote: [ -> ] (2012-11-13, 18:19)rcrh Wrote: [ -> ]So I accidentally upgraded to Frodo ...
No, I didn't do anything since everything else seemed to be working. I thought skins upgraded automatically. Is there a separate repository for the svn?
(2012-11-13, 19:26)rcrh Wrote: [ -> ]No, I didn't do anything since everything else seemed to be working. I thought skins upgraded automatically. Is there a separate repository for the svn?
noramally it should update automatically, but be don't have a repo for frodo yet.
T! svn:
http://forum.xbmc.org/showthread.php?tid=83643
(2011-12-27, 17:07)atlind01 Wrote: [ -> ]ronie Wrote:heh, alright, ok...i will then :-)
since i got 0 responses on the new release so far,
i kinda thought everybody lost interest in T! ;-)
I think most of the folkls are kind pre-occupied with the Eden features and not to mention family time during christmas might have taken precedence.
But I do love the transparency skin and thanks for all your hard work. The kind of support that we get from you is the best I have seen.
+1 for the support, keep it up
(2012-11-01, 11:25)ronie Wrote: [ -> ] (2012-11-01, 05:58)pedram Wrote: [ -> ] (2012-08-25, 22:20)amalvar Wrote: [ -> ]Hi,
Is there a 3D cover/case in T? How does it work?
Thanks,
A
I'm guessing this doesn't work yet since I added .3D and even .3DBD to the filename and it didn't pick it up.
Are there any plans to implement it in the future?
it's not supported yet.
i will look into it.
did this ever get added? I checked the changelog (for V5) and couldn't see anything so I am guessing it has not been yet, but I am just asking.
(2012-11-30, 14:15)Saner Wrote: [ -> ]did this ever get added? I checked the changelog (for V5) and couldn't see anything so I am guessing it has not been yet, but I am just asking.
nope, haven't looked into this yet.
Ok thanks for the answer.
Can you upload the zip to the theme? My xbmc rig doesn't have a connection to the internet for the time being so going to Settings > Add-ons > Get Add-ons > XBMC.org Add-ons > Skin > Transparency! will get me nowhere. Thanks in advance, I'm sure other people will appreciate it as well.
(2013-01-01, 23:51)Mutinize Wrote: [ -> ]Can you upload the zip to the theme? My xbmc rig doesn't have a connection to the internet for the time being so going to Settings > Add-ons > Get Add-ons > XBMC.org Add-ons > Skin > Transparency! will get me nowhere. Thanks in advance, I'm sure other people will appreciate it as well.
zips are available in the addon repo:
http://mirrors.xbmc.org/addons/eden/
When I go to Add-Ons I only see Program Add-Ons. I have the YouTube add-on installed but I can't see it in the menu.
(2013-01-03, 07:54)bcxm Wrote: [ -> ]When I go to Add-Ons I only see Program Add-Ons. I have the YouTube add-on installed but I can't see it in the menu.
youtube is listed under video addons.
use the videos button on the home menu to get there.
(2013-01-03, 12:13)ronie Wrote: [ -> ] (2013-01-03, 07:54)bcxm Wrote: [ -> ]When I go to Add-Ons I only see Program Add-Ons. I have the YouTube add-on installed but I can't see it in the menu.
When I go to Videos I don't see it either. It just shows my movies and tv directories.
Is there a way to add YouTube to the main menu?
