Full Version: Transparency! v4.0.5 for XBMC Eden 11.0
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
neno1978 Wrote:yea! yes!, but no work for me Sad
ok, post a Debug Log on pastebin and i'll have a look.
ronie Wrote:ok, post a Debug Log on pastebin and i'll have a look.
OK. HERE IS IT http://pastebin.com/gxaGGTkN
Could be for the estructure?
my tvshows estructures is house/logo.png
etc...
other log with depurehttp://pastebin.com/mMGs7KvQ
and extra fanart no work in tvshow
my tvshow is streaming a plugin similar to icefilm is
special://home/userdata/addon_data/plugin.video.pelisalacarta.library/
this is important?
neno1978 Wrote:OK. HERE IS IT http://pastebin.com/gxaGGTkN
etc...
a structure like that should be ok.
the log you posted however is not a debuglog.
you need to enable it in Settings > System > Debugging
ok ronnie , it´s true, but i think my library is corrupted becouse movies dissapear . i.m deleting and reistaling all the library Xbmc/userdata... y them i will see if it is working fine or not. Tomorrow i will say you something , thanks Big Grin
Well, no work extrafanart and no work clearart and logos
log: http://pastebin.com/ThTSrDjr
Help pleaseee!!!Huh
In movies works peferct...
i change the estructure and nothing no work , i don´t understand
neno1978 Wrote:Well, no work extrafanart and no work clearart and logos
i don't see any messages related to those in your log.
did you browse through your tv shows when you created the logfile?
ronie Wrote:i don't see any messages related to those in your log.
yes, ronie, i browse throug my tub shows , what´s happening?
How can work in movies and no in tvshowsHuhSad
WELL look this, i see some errors diferents : http://pastebin.com/cqqr18mV
ronie Wrote:whether you see a dvd or blu-ray box depends on the video-resolution of the movie.
if xbmc hasn't determined the video-resolution, there's no way for the skin to know if it's a dvd or a blu-ray and it will fallback to the generic yellow case.
Ah, ok. I think it used to fallback to the DVD case, but I kind of like the new behaviow now that I know Smile
Quote:both should do that already.
they depend on the Settings > International > Region setting.
I set the region to US (12h), but it's still doing the month/day backwards for a Yank :p
Quote:they will only show when you enter at the root level of the videolibrary (see below)
if you jump straight to a subsection (for instance movie-titles) xbmc will not show the parent folder (..) item anymore.
Ah, it's a XMBC thing, not a T! thing then? Too bad, I used the dots alot. Speaking of which, for some reason XBMC has decided to use the fanart for one particular movie for wherever the dots do show up... Kind of random!
Quote:use the Movies > Library submenu button on the home screen.
Ah, there it is... thanks!
neno1978 Wrote:my tvshow is streaming a plugin similar to icefilm is
this is important?
ah, i missed your edit.
yes, that would be the problem.
logo/clearart/extrafanart don't work with plugins.
ronie Wrote:ah, i missed your edit.
ooooooHHHHH!!!!!
in this sking?
other skin yes
No way to do itHuh pleaseeee Wink
clock2113 Wrote:I set the region to US (12h), but it's still doing the month/day backwards for a Yank :p
i've tested it with US(12h), and the weather date shows as 01/17/2112
if you're seeing something else...then i don't know :-)
for next-aired, you may need to do a full rescan (or wait 24h for the auto update), if you have just changed the region setting.
clock2113 Wrote:Ah, it's a XBMC thing, not a T! thing then? Too bad, I used the dots alot. Speaking of which, for some reason XBMC has decided to use the fanart for one particular movie for wherever the dots do show up... Kind of random!
xbmc bug.
search your thumbnail cache for this file: ffffffff.tbn
and delete it.
neno1978 Wrote:ooooooHHHHH!!!!!
in this sking?
other skin yes
i will look into it.
but it needs a skin update, yes.
ronie Wrote:i will look into it.
Thanks!! i am waiting Big Grin
Well, i do it, is a simple parch waitin for the update; copy all srm to pc and by smb work perfectly. is hard copy, copy, scraper and copy but for the moment is a way while update come Wink
other cuestion ronie, the cd in the fanart view can be modificate how cdart?
and clearart where can see? i see logo no clearart
neno1978 Wrote:Thanks!! i am waiting Big Grin
i've added it to the svn version of Transparency!
it will be in the next stable release too.
ronie Wrote:i've added it to the svn version of Transparency!
ok!! you are a crack!! thanks!! Laugh
