Hi, just getting XBMC sorted out the way i want after installing on my new ATV2 but how do i get into library mode, i have looked in the wiki but cant seem to find what im looking for exactly, i had it setup like this before on my desktop pc
http://www.google.co.uk/imgres?q=xbmc+li...80&bih=678
I Dont know if maybe im setting the sources up wrong? any help would be much appreciated
hmmm not sure if i like it like this, im happy because ive got it working the way i want so far.
Is this something that is going to be added after the beta or in a future beta or has it been removed full stop, if it has why?? it looked very neat and was plain and simple
Viewing TV Shows/Movies in library view (v11) is identical to library mode from v10. The real change is just that you don't have a "library" toggle anymore. Instead you navigate to either TV Shows/Movies or "Files".
It also gives file view the ability to show summaries if you want to browse things in a specific folder structure (like if you have a folder just for "Bob's favorite movies" or "anime"). This can be turned off if you want to use it like the old "file mode" by going to
Settings -> Video -> File lists -> Show metadata in files view
So both "modes/views" are still there, just with more options.
