2012-01-14, 15:40
2012-01-15, 15:11
Hi all, Hope this isn't off topic but Im having a prob with this, ITV and the Channel 4 add-on. The streams fail to load. It says 'working' then nothing. After looking at the log and researching I found this to be a handshake problem (?), and I believe the best way is to update the rtmpdump? I just have zero idea of how to update the rtmp I have downloaded the file but when I run the exe it does nothing.
Can someone help explain or point me in the way of how to find an easy step-by-step guide of what to do? I have been searching on this issue for a few hours, as I didn't want to post without at least searching myself for an answer, but to no avail.
Thanks in advance.
Thanks in advance.
2012-01-15, 15:26
Create a new folder called RTMPDUMP - put the unzipped rtmpdump files in there. Specify this folder in the addon configuration page.
Assumes you are using windows.
2012-01-15, 15:29
castalla Wrote:Create a new folder called RTMPDUMP - put the unzipped rtmpdump files in there. Specify this folder in the addon configuration page.
Yeah Im running Dharma on Windows. Will give it a go now, thanks for the tip.
Will report back.
2012-01-15, 15:39
I extraceted the files within the rtmpdump zip. I went into addon configuration for each of them, but could only find a rtmpdump configure in the 4od and Channel 5 addons. I selected the path, but yielded these results still...
13:32:34 T:6064 M:1241604096 NOTICE: -->Python Interpreter Initialized<--
13:32:35 T:6012 M:1241784320 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
13:32:41 T:1084 M:1241546752 NOTICE: -->Python Interpreter Initialized<--
13:32:41 T:6012 M:1241288704 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
13:32:44 T:6012 M:1242259456 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 0
13:34:57 T:5788 M:1233907712 WARNING: Previous line repeats 2 times.
13:34:57 T:5788 M:1233907712 NOTICE: -->Python Interpreter Initialized<--
13:34:57 T:6012 M:1233321984 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
13:35:00 T:1560 M:1232871424 NOTICE: -->Python Interpreter Initialized<--
13:35:00 T:1560 M:1232621568 NOTICE: search:
13:35:00 T:6012 M:1230950400 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
13:35:05 T:5696 M:1230667776 NOTICE: -->Python Interpreter Initialized<--
13:35:05 T:5696 M:1228836864 NOTICE: search:
13:35:05 T:5696 M:1228759040 NOTICE: Looking for episodes for: The Boss Is Coming To Dinner!
13:35:05 T:5696 M:1228742656 NOTICE: URL: http://www.channel5.com/shows/the-boss-i...r/episodes
13:35:07 T:6012 M:1225973760 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
13:35:08 T:3796 M:1206427648 NOTICE: -->Python Interpreter Initialized<--
13:35:08 T:3796 M:1206263808 NOTICE: search:
13:35:12 T:3796 M:1205776384 NOTICE: PLAY URL: rtmpe://bt.fcod.llnwd.net:1935/a800/o10/& playpath=mp4:videos/19582164001/19582164001_642962264001_C5152530025A-H264-480-16x9.mp4?e=1326645375&h=7717fd91b38cd87202a34bd0d356363f&__nn__=659726446001 swfurl=http://admin.brightcove.com/viewer/us20111026.1813/connection/ExternalConnection_2.swf swfvfy=true
13:35:12 T:6012 M:1204367360 NOTICE: DVDPlayer: Opening: rtmpe://bt.fcod.llnwd.net:1935/a800/o10/& playpath=mp4:videos/19582164001/19582164001_642962264001_C5152530025A-H264-480-16x9.mp4?e=1326645375&h=7717fd91b38cd87202a34bd0d356363f&__nn__=659726446001 swfurl=http://admin.brightcove.com/viewer/us20111026.1813/connection/ExternalConnection_2.swf swfvfy=true
13:35:12 T:6012 M:1204367360 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
13:35:12 T:3720 M:1204334592 NOTICE: Creating InputStream
13:35:12 T:3720 M:1203331072 WARNING: HandShake: Type mismatch: client sent 6, server answered 9
13:35:12 T:3720 M:1203331072 WARNING: HandShake: Server not genuine Adobe!
13:35:12 T:3720 M:1203331072 ERROR: RTMP_Connect1, handshake failed.
13:35:12 T:3720 M:1203331072 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmpe://bt.fcod.llnwd.net:1935/a800/o10/& playpath=mp4:videos/19582164001/19582164001_642962264001_C5152530025A-H264-480-16x9.mp4?e=1326645375&h=7717fd91b38cd87202a34bd0d356363f&__nn__=659726446001 swfurl=http://admin.brightcove.com/viewer/us20111026.1813/connection/ExternalConnection_2.swf swfvfy=true]
13:35:12 T:3720 M:1203331072 NOTICE: CDVDPlayer::OnExit()
13:35:12 T:3720 M:1203331072 NOTICE: CDVDPlayer::OnExit() deleting input stream
13:35:12 T:6012 M:1204121600 NOTICE: CDVDPlayer::CloseFile()
13:35:12 T:6012 M:1204125696 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
13:35:12 T:6012 M:1204121600 NOTICE: DVDPlayer: waiting for threads to exit
13:35:12 T:6012 M:1204121600 NOTICE: DVDPlayer: finished waiting
2012-01-15, 15:48
Not sure if it works on dharma.
Are you outside the UK?
2012-01-15, 15:54
castalla Wrote:Not sure if it works on dharma.
Im within the UK. The BBC, youtube, tvcatchup addons all work fine. Just an issue with these three.
2012-01-15, 15:57
I think you have to have at least pre-Eden ...
Update - you have nothing to lose!
2012-01-15, 15:59
castalla Wrote:I think you have to have at least pre-Eden ...
oh really? all my files, links and prefrences stay the same? Cool. Looks like its time to upgrade!
Appreciate the help mate.
2012-01-15, 16:02
I think you can just update - should keep your settings, I hope!
2012-01-15, 18:29
castalla Wrote:I think you can just update - should keep your settings, I hope!
Incase anyone is in the same situation as me...
upgrading to Eden Beta works like a charm. I exported my video library and made a back up of my add_on data first just incase. But no need, all add_ons and prefrences will be carried over. Just install Eden Beta over Dharma.
2012-01-15, 18:30
Mighty_Diamond Wrote:Incase anyone is in the same situation as me...
Thanks for the help again. Now... Lets see about writing my first xml...
2012-01-15, 18:34
Glad it worked out!
How about a live itv and/or channel 4 player!!!
2012-01-15, 18:51
castalla Wrote:Glad it worked out!
I was thinking about a usa/uk streaming addon. Ive been collecting stream links... well the html pages and figuring out how to find the strm files, then get on with a xml. No doubt will use another addon as a template.
Can't hurt to try.
2012-01-15, 18:53
Only downside to Eden is that it appears xpadder does not work with it. I use the programme as a way to use a xbox contgroller as a mouse and have my pc hooked up to a television in another room. No problems in Dharma, so Im having to figure out a way to be able to change channel in another room at the mo! lol
