2012-01-28, 01:54
2012-01-28, 20:49
Any reason why this fix wouldn't work in Linux? Just tried it and it won't play anything at all now.
2012-01-28, 21:41
tdw197 Wrote:Any reason why this fix wouldn't work in Linux? Just tried it and it won't play anything at all now.
Works OK for me on Linux. OS should make no difference. Is there anything in the log?
2012-01-28, 21:52
zuccster Wrote:Works OK for me on Linux. OS should make no difference. Is there anything in the log?
Will have a look once I can get the wife away from it...
2012-02-12, 04:24
Is there any chance you any would upload a compiled fix copy of the plugin . Since I only have a iPad, no windows I can't download the py file
2012-02-25, 03:15
Many thanks to Spoyser for fixing the show parsing problem and the other tweaks suggested. I've incorporated these into update 1.0.2
I've confirmed this works in both Dharma and Eden b3 (on Windows).
I believe most of the other reported problems relate to issues with older versions of the rtmp library, but anybody who has problems, please post full details in this thread so I can try to resolve.
If you installed via my repository you should automatically get an update
(My repo: http://nibor-xbmc-repo.googlecode.co...tory.nibor.zip )
Otherwise you can get a .zip for 1.0.2 from:
http://code.google.com/p/nibor-xbmc-repo/downloads/list
2012-02-25, 07:16
nibor Wrote:Many thanks to Spoyser for fixing the show parsing problem and the other tweaks suggested. I've incorporated these into update 1.0.2
Just tried now mate, working perfect. Many thanks. I had an issue with the files not playing at first, this was down to me having unblock-us activated which would leave the 'Loading' bar hanging, then nothing. After I made sure it was turned off, this update works perfect.
It has an option to download a file when I click on it, this isn't something I need at the moment, but if I do would I just assign a d/l folder and have the file will be saved into that?
2012-02-27, 10:19
Mighty_Diamond Wrote:It has an option to download a file when I click on it, this isn't something I need at the moment, but if I do would I just assign a d/l folder and have the file will be saved into that?
That is exactly how it works. If you never download you can disable the prompt in the settings, just change "Default action on select" to Play.
2012-03-02, 23:22
Hi
Brilliant plug-in (also 4OD) I can play videos using both of them using the Eden builds.
But, I can't download. I'm running:
It says Starting download and then very soon afterword says download finished, but nothing has been downloaded.
Ta
- v1.0.2 of the plug-in
- RTMPdump version 2.4 (inside get_iplayer)
Ta
2012-03-03, 01:47
dgmckenzie Wrote:Hi
Ta
getting exactly the same using exactly the same
2012-03-03, 02:00
I know it's not officially supported, but could you take a look at this Xbmc4xbox error log to see if this plugin could be made compatible? Please?
http://pastebin.com/QChmkxng
2012-03-04, 17:00
I think I have been having a similar problem on the demand 5 app. Are there any pre-requisites for it to work? My issues are:
* Nothing plays (in the log I got an error along the linesw of "Server not genuine adobe")
* I have rtmpdump installed, but when it downloads, the files is 0kb, so it appears to just create the placeholder, I understand a certain version of rtmpdump is required, is that just the newest one from the repo?
My system is: XBMC Eden RC1, Ubuntu 11.10
Thankyou for any help you can give,
Dan
Dan
2012-03-07, 13:02
Brilliant Add On. Just what i needed. ManY ThanX.
2012-03-07, 18:46
retrodans Wrote:I think I have been having a similar problem on the demand 5 app. Are there any pre-requisites for it to work? My issues are:
Dan
When you get a 0kb file is it definately saying that it has finished downloading?
If so can you look in the log file and look for a line that say something along the lines of;
COMMAND LINE: C:\Media_Tools\rtmpdump.exe --rtmp "rtmpe://bt.fcod.llnwd.net:1935/a800/o10/&" --flashVer "WIN 11,0,1,152" --swfVfy "http://admin.brightcove.com/viewer/us20111026.1813/connection/ExternalConnection_2.swf" --conn Z: --playpath "mp4:videos/19582164001/19582164001_1257557148001_b17-C5092870051B1-H264-1200-16x9.mp4?e=1331149055&h=cd0160d458a8623a70ad286fa8457cbc&__nn__=659726446001" -o "E:\Media\On Demand\Episode 51 Daddy's Movie Camera.flv" --timeout 180 --verbose
If you then paste the line into a terminal window (without the leading COMMAND LINE: bit) what happens?
2012-03-08, 03:35
Really nice plugin everything is loading but when I go to play the link I get a script fail. here is the Error log http://pastebin.com/Eai2pEXE Eden 11.0 RC2 Demand5 1.02 windows 7
Transparency skin, Thanks hope you can help
