Full Version: Refresh thumbnail cache
So I use Ember to manage thumbnails / posters / etc.. externally, since it's easier (for me) than the xbmc built in media manager. The problem comes when I decide to change an image that xbmc has already cached.
A search so far has only yielded two results,
1) Deleting the entire thumbnail cache, and letting XBMC refresh itself.
--- This seems wholly inefficient to me, and while it works, it's akin to using a nuke to demolish a single building. Not really a preferred method in my opinion
2) [Windows] Going through the registry to find the cache file name of what you've replaced, and just deleting that specific cache file, then letting XBMC rebuild it upon next access.
--- While this is more precise, it requires alot of manual intervention to get it to work properly, something that should be automated.
Is there a way to have xbmc refresh it's media cache for items that I know I've changed? either via api or otherwise?
I'd like to setup a timer to have it refresh it's cache on a given interval (say every 24 hours), or even something added to a web interface addon, or third party through api, to tell xbmc to refresh <this> image in it's cache.
or even a third party addon - program that generates the thumbnail cache images themselves, independent of xbmc?
And if you had searched more you would have found that XBMC refreshes the cache himself every 24hours without you doing anything
(2012-04-12, 22:33)Martijn Wrote: [ -> ]And if you had searched more you would have found that XBMC refreshes the cache himself every 24hours without you doing anything
Not true for all images. Music genre images for example does not refresh.
(2012-04-12, 22:35)sialivi Wrote: [ -> ]
Correct but he did not mention music. Only videos
Videos don't either until my video_thumbs_to_cache branch is pulled in.
(2012-04-12, 23:30)jmarshall Wrote: [ -> ]Videos don't either until my video_thumbs_to_cache branch is pulled in.
is there any ETA on when this might happen?
or possibly an alternate solution until then?
There is no alternate solution, otherwise I wouldn't be spending hours working on it.
The video_thumbs_to_cache branch will likely be pulled in during the May merge window.
thanks for the hours of hard work jmarshall. If it wasn't for developers like you working hard on XBMC we would be stuck using 2nd rate software. Big Grin
(2012-04-15, 07:55)jmarshall Wrote: [ -> ]There is no alternate solution, otherwise I wouldn't be spending hours working on it.
awesome. Thanks for the heads up. Appreciate you working on it.
(2012-04-16, 00:16)Zxurian Wrote: [ -> ]
I wish we had a add-on which ran in the meantime but perhaps that's as laborious as making it a built-in...
Check this out:
http://www.technazgul.com/2011/02/how-to...while.html
He figured out how to get it to work. I had to make some minor adjustment but the idea basically worked.
