Hey,
I am new in the community of XBMC. I just downloaded and installed it in my pc.
However no addon work on it...not even weather.... every time i try to run an add-on it sais script failed (followed by the name of the add-on.
What did i do wrong please help
http://imageshack.us/f/3/33815851.jpg/
You'll need to enable debug logging in XBMC, launch the add-on to generate the script error, exit XBMC, post the debug log to a public site such as pastebin, and then post a link to that log here so we can see why the script failed. See
here for details on how to do this.
(2012-05-23, 21:30)11001097 Wrote: [ -> ]thanks for the reply
here is the link
http://pastebin.com/uzKDLPcn
does that help?
You probably have a bad install. Please try to re-install
(2012-05-23, 21:34)Martijn Wrote: [ -> ] (2012-05-23, 21:30)11001097 Wrote: [ -> ]thanks for the reply
here is the link
does that help?
I already tried that, did not work...i removed also the firewall protection from the app and still nothing.
Looks like you are having the same problem as described in this
thread. You may want to subscribe to this other thread as well as your own so you will be alerted whenever someone posts suggestions for things to try.
