(2012-07-21, 09:30)JoeBlow42069 Wrote: [ -> ]Why is this so difficult?!? All I want to do is launch Hyperspin from the main menu in Aeon Nox 3.0.1 w/ advanced launcher. When I go into the Main Menu customizer and try to select the Favorite path for HS, nothing happens. I have set up HS with advanced launcher correctly, and is working fine with other skins when HS is selected as a favorite. It even worked with the previous version of Aeon Nox!
a) it´s not difficult
b) you should invest a bit more effort.
(2012-07-21, 08:31)JoeBlow42069 Wrote: [ -> ]<setting type="string" name="skin.aeon.nox.Nox.CustomHomeItem1.Path"></setting>
Go into your
guisettings.xml and copy and paste the entire contents to
pastebin and then repost the link here.
I decided to re-install XBMC today and it fixed my problem! Everything seems to be working fine at the moment
(2012-07-22, 13:59)JoeBlow42069 Wrote: [ -> ]I decided to re-install XBMC today and it fixed my problem! Everything seems to be working fine at the moment
wow... you finally started to try to solve it yourself. congratulations.
