Pages: 1 2 3 4 5 6 7 8 9 10 11 12
what are the filenames like?
maybe i can find -name my harddisk
see post #5 of this thread ^^
read basco read!
is there a threshold at which tvheadend starts buffering to disk? or does it start writing immediately at 'pause' press?
Same problem like basco. Version of tvheadend is the same described in post #12. XBMC is the latest build from today (RC). What I'm doing wrong?
git clone https://github.com/tvheadend/tvheadend.git
cd tvheadend
git checkout feature/timeshift
./configure --enable-timeshift
make
make install
Gone to Configuration -> General and setting the Path for Timeshift /srv/Timeshift (which exists), pause works but nothing appears. No files are written.
_BJ1
Check the filesystem permissions. The user under which tvheadend runs has to be the owner of that folder and needs write access to it.
that does not explain why it still works?
ps aux | grep tvh
hts 11050 7.8 0.3 1112104 32288 ? Ssl 05:06 39:50 tvheadend -f -u hts -g video
i did a:
chown hts:hts /mnt/storage/timeshift
i will check this evening if it makes any difference
Should be chown hts:video /mnt/storage/timeshift I guess?
i don't know. i changed it to hts:video. i'll test it this evening.
tested it....
no go.
i'm currently time shifting over 5 minutes and no file has been written.
did a
find -name tvh-*
on my hdd, no files found
tvheadend addon 1.6.4 + tvheadend:
From
759b5b1..8276b58 feature/timeshift -> origin/feature/timeshift
f991e13..963a050 dvbnetworks -> origin/dvbnetworks
3a54bc7..a420c83 master -> origin/master
Updating 759b5b1..8276b58
no timeshift.... when ./configure --enable-timeshift
before you start building.
M debian/changelog
Already on 'feature/timeshift'
ok, tested it with previous tvheadend.
i can now confirm that in tis version timeshift works:
tvheadend_3.3.199~g759b5b1-dirty~precise_amd64.deb
in this version of tvheadend (latest) timeshift does not work:
tvheadend_3.3.207~g8276b58-dirty~precise_amd64.deb
built like this:
make
./Autobuild.sh -t precise-amd64
dpkg -i ../tvheadend_3.3.207~g8276b58-dirty~precise_amd64.deb
i haven't used the packaging stuff in there, but it works fine when you compile manually
