Full Version: Navigating lock bugs in "My music"
Pages: 1 2 3 4 5
ok, a reply to myself..
i am a little bit further now. i have discoverd that it must be something with the mp3 tags in one (or more) files.
this is what i did so far:
my music library is devided over 67 folders. i did make a new shared map and did copy the first ten into it.
scanned it and there was no problem with artist view in library. i did this again with the second 10 etc.etc. no problems. i discoverd that it locked up again after placing the last 17 folders into the new map. so there must be something wrong with one or more tags in these folders.
tonight i will look further into it and try to find out wich file is causing the lockups. this means that i will scan each folder seperatly until the 'corrupt' one comes up. then i have to look deeper into that folder examining each file.
if i do find the problem i will post it here.
Quote:did you alter that output? i notice that the two log messages for "getdirectory()" and "fetching directory" do not match, and they should.
yes i did. i hide (at least i tried to) all my personal information from smb path - except that "piisej" which i forgot. and there is no special characters, umlauts (äåö) or accents (áé) in my smb path. definetly i do have those in mp3 names and tags.
Quote:i did make a new shared map and did copy the first ten into it.
i had this in my mind too... haven't yet tried that 'cause that is so damn slow way to find exception.. but i'm with you! :thumbsup:
@PimPandoer
yes. the underlying issue has still not been corrected.
scanning reads the tag data and puts it into the database. as a test, you can enable id3 tag reading and just browse thru those folders. this should cause a problem as well, which is what i believe julpero is experiencing.
@julpero
i'm assuming (rather hoping) that u have id3 tag reading enabled. please confirm. if you do, please disable it and see if the lockup goes away.
(kraqh3d @ oct. 19 2005,16:43 Wrote:i'm assuming (rather hoping) that u have id3 tag reading enabled. please confirm. if you do, please disable it and see if the lockup goes away.
yes i did. i disabled it and still lockups:
Quote:19-10-2005 20:37:21 info loading skin file: mymusicsongs.xml
19-10-2005 20:37:21 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 20:37:21 debug m_vechistory = (
19-10-2005 20:37:21 debug )
19-10-2005 20:37:21 debug fetching directory ()
19-10-2005 20:37:21 debug 00.[]
19-10-2005 20:37:23 debug cguiwindowmusicsongs::getdirectory(smb://xxx;xxx:xxx@xxx/xxx/)
19-10-2005 20:37:23 debug m_vechistory = (
19-10-2005 20:37:23 debug 00.[]
19-10-2005 20:37:23 debug )
19-10-2005 20:37:23 debug fetching directory (smb://xxx;xxx:xxx@xxx/xxx/)
19-10-2005 20:37:26 error exception in capplication::framemove()
19-10-2005 20:37:26 error exception in capplication::render()
19-10-2005 20:37:27 error exception in capplication::render()
19-10-2005 20:37:27 error capplication::render(), too many exceptions
then i started to clean my folder names from smb share. the first folder was named like this
Quote:--==xxx==--
which i renamed
Quote:xxx
this helped a bit and i manged to listen one song from my playlist. while song was playing i went to enable id-tag reading again and after that back to my music -> lockup. this is what i got from xbox.old.log after reboot:
Quote:19-10-2005 20:38:31 notice -----------------------------------------------------------------------
19-10-2005 20:38:31 notice new home path! q is mapped to: harddisk0\partition1\apps\xbmc
19-10-2005 20:38:31 notice starting xboxmediacenter. built on oct 18 2005
19-10-2005 20:38:31 notice home path q is mapped to: e:\apps\xbmc (harddisk0\partition1\apps\xbmc)
19-10-2005 20:38:31 notice log file is located: q:\xbmc.log
19-10-2005 20:38:31 debug setting resolution 7
19-10-2005 20:38:31 debug we set resolution 7
19-10-2005 20:38:32 debug we set resolution 7
19-10-2005 20:38:32 info load language file:q:\language\english\strings.xml
19-10-2005 20:38:32 notice loaded q:\system\players\mplayer\iso639-1.xml
19-10-2005 20:38:32 notice loaded q:\system\players\mplayer\iso639-2.xml
19-10-2005 20:38:32 info load keymapping
19-10-2005 20:38:32 info loading q:\keymap.xml
19-10-2005 20:38:32 info checking skin version of: project mayhem iii
19-10-2005 20:38:32 info skin version is: 1.3
19-10-2005 20:38:32 info gui format 720x576 pal 16:9
19-10-2005 20:38:32 info gui screen offset (0,0)
19-10-2005 20:38:32 info install unhandled exception filter
19-10-2005 20:38:32 info creating subdirectories
19-10-2005 20:38:32 info thumbnails folder:q:\thumbs
19-10-2005 20:38:32 info shortcuts folder:q:\shortcuts
19-10-2005 20:38:32 info albums folder:q:\albums
19-10-2005 20:38:32 info recording folder:q:\recordings
19-10-2005 20:38:32 info screenshots folder:q:\screenshots
19-10-2005 20:38:32 info subtitle folder:q:\subtitles
19-10-2005 20:38:32 notice initialize assignment:[dhcp] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
19-10-2005 20:38:32 notice use dhcp
19-10-2005 20:38:32 info setting up network...
19-10-2005 20:38:32 info requesting dhcp
19-10-2005 20:38:33 info full duplex
19-10-2005 20:38:33 info 100 mbps
19-10-2005 20:38:33 info dynamic ip
19-10-2005 20:38:33 info dns
19-10-2005 20:38:33 info ip: 192.168.0.101
19-10-2005 20:38:33 info get local ip address:
19-10-2005 20:38:33 info ip adres:192.168.0.101
19-10-2005 20:38:33 notice start timeserver thread
19-10-2005 20:38:33 notice xbfilezilla: starting...
19-10-2005 20:38:35 notice xbfilezilla: started
19-10-2005 20:38:35 notice start led control
19-10-2005 20:38:35 notice dim lcd on playback
19-10-2005 20:38:35 notice checking the date!
19-10-2005 20:38:35 notice - current date is: 19-10-2005
19-10-2005 20:38:35 notice start dvd mediatype detection
19-10-2005 20:38:35 notice initializing playlistplayer
19-10-2005 20:38:35 info lcd not used
19-10-2005 20:38:35 notice start fancontroller
19-10-2005 20:38:35 notice load default skin:[project mayhem iii]
19-10-2005 20:38:35 info load skin from:q:\skin\project mayhem iii
19-10-2005 20:38:35 info delete old skin...
19-10-2005 20:38:35 info default 4:3 resolution directory is q:\skin\project mayhem iii\pal
19-10-2005 20:38:35 info default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
19-10-2005 20:38:35 info skin version is: 1.3
19-10-2005 20:38:35 info load fonts for skin...
19-10-2005 20:38:35 info loading fonts from q:\skin\project mayhem iii\pal16x9\font.xml
19-10-2005 20:38:35 info load font:font13 path:q:\skin\project mayhem iii\fonts\common-font13.xpr
19-10-2005 20:38:35 info load font:font14 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
19-10-2005 20:38:35 info load font:matrix8 path:q:\skin\project mayhem iii\fonts\matrix8.xpr
19-10-2005 20:38:35 info load font:font04 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
19-10-2005 20:38:35 info load font:font10 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
19-10-2005 20:38:35 info load font:font12 path:q:\skin\project mayhem iii\fonts\common-font12.xpr
19-10-2005 20:38:35 info load font:fontkb path:q:\skin\project mayhem iii\fonts\common-font13.xpr
19-10-2005 20:38:35 info load font:font101 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
19-10-2005 20:38:35 info load font:special12 path:q:\skin\project mayhem iii\fonts\special-normal-pal.xpr
19-10-2005 20:38:35 info load font:special13 path:q:\skin\project mayhem iii\fonts\special-bold-pal.xpr
19-10-2005 20:38:35 info load font:fontbl path:q:\skin\project mayhem iii\fonts\common-font12.xpr
19-10-2005 20:38:35 info load new skin...
19-10-2005 20:38:35 info loading skin file: home.xml
19-10-2005 20:38:35 info loading references file: q:\skin\project mayhem iii\pal16x9\references.xml
19-10-2005 20:38:35 info kaiclient: instantiating...
19-10-2005 20:38:35 debug udpclient: creating udp socket...
19-10-2005 20:38:35 debug udpclient: setting broadcast socket option...
19-10-2005 20:38:35 debug udpclient: setting non-blocking socket options...
19-10-2005 20:38:35 debug udpclient: spawning listener thread...
19-10-2005 20:38:35 debug udpclient: ready.
19-10-2005 20:38:35 info kaiclient: ready.
19-10-2005 20:38:35 info loading user windows q:\skin\project mayhem iii\pal16x9\custom*.xml
19-10-2005 20:38:35 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom1.xml
19-10-2005 20:38:35 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom3.xml
19-10-2005 20:38:35 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom2.xml
19-10-2005 20:38:35 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom4.xml
19-10-2005 20:38:35 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom5.xml
19-10-2005 20:38:35 info initialize new skin...
19-10-2005 20:38:35 info loading skin file: pointer.xml
19-10-2005 20:38:35 info loading skin file: musicoverlay.xml
19-10-2005 20:38:35 info loading skin file: videooverlay.xml
19-10-2005 20:38:35 info loading skin file: dialogvolumebar.xml
19-10-2005 20:38:35 info loading skin file: dialogseekbar.xml
19-10-2005 20:38:35 info loading skin file: dialogkaitoast.xml
19-10-2005 20:38:35 info loading skin file: dialogmutebug.xml
19-10-2005 20:38:35 info loading q:\skin\project mayhem iii\sounds\sounds.xml
19-10-2005 20:38:35 info skin loaded...
19-10-2005 20:38:35 notice kaiclient: discovering kai engine via udp broadcast.
19-10-2005 20:38:36 info activating window id: 10000
19-10-2005 20:38:36 info removing tempfiles
19-10-2005 20:38:36 notice initialize done
19-10-2005 20:38:36 notice running the application...
19-10-2005 20:38:36 debug loadlibrarya('zlib.pyd')
19-10-2005 20:38:36 warning kernel32.dll fake function disablethreadlibrarycalls called
19-10-2005 20:38:36 debug loadlibrary('zlib.pyd') returning: 0x842aa0
19-10-2005 20:38:36 debug zlib.pyd!getprocaddress(0x842aa0, 'initzlib') => 0x992210
19-10-2005 20:38:36 info -->python initialized<--
19-10-2005 20:38:36 info get url: http://www.xbox-scene.com/xbox1data/xbox-scene.xml
19-10-2005 20:38:37 debug got rss feed: http://www.xbox-scene.com/xbox1data/xbox-scene.xml
19-10-2005 20:38:37 debug rss feed encoding: utf-8
19-10-2005 20:38:37 debug parsed rss feed: http://www.xbox-scene.com/xbox1data/xbox-scene.xml
19-10-2005 20:38:37 debug filecurl::close(d06efb84)
19-10-2005 20:38:37 debug udpclient: listening.
19-10-2005 20:38:37 debug udpclient tx: 14235 -> 'kai_client_discover;'
19-10-2005 20:40:45 debug freevisualisation() started
19-10-2005 20:40:45 debug freevisualisation() done
19-10-2005 20:40:45 info activating window id: 10501
19-10-2005 20:40:45 info attempting to default to:
19-10-2005 20:40:45 info loading skin file: mymusicsongs.xml
19-10-2005 20:40:45 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 20:40:45 debug m_vechistory = (
19-10-2005 20:40:45 debug )
19-10-2005 20:40:45 debug fetching directory ()
19-10-2005 20:40:45 debug 00.[]
19-10-2005 20:40:48 info activating window id: 10000
19-10-2005 20:40:48 info loading skin file: home.xml
19-10-2005 20:40:51 debug freevisualisation() started
19-10-2005 20:40:51 debug freevisualisation() done
19-10-2005 20:40:51 info activating window id: 10004
19-10-2005 20:40:51 info loading skin file: settings.xml
19-10-2005 20:40:52 info activating window id: 10015
19-10-2005 20:40:52 info loading skin file: settingscategory.xml
19-10-2005 20:41:07 info loading skin file: settings.xml
19-10-2005 20:41:08 info loading skin file: home.xml
19-10-2005 20:41:11 debug freevisualisation() started
19-10-2005 20:41:11 debug freevisualisation() done
19-10-2005 20:41:11 info activating window id: 10501
19-10-2005 20:41:11 info loading skin file: mymusicsongs.xml
19-10-2005 20:41:11 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 20:41:11 debug m_vechistory = (
19-10-2005 20:41:11 debug 00.[]
19-10-2005 20:41:11 debug )
19-10-2005 20:41:11 debug fetching directory ()
19-10-2005 20:41:14 debug cguiwindowmusicsongs::getdirectory(smb://xxx;xxx:xxx@xxx/xxx/)
19-10-2005 20:41:14 debug m_vechistory = (
19-10-2005 20:41:14 debug 00.[]
19-10-2005 20:41:14 debug )
19-10-2005 20:41:14 debug fetching directory (smb://xxx;xxx:xxx@xxx/xxx/)
19-10-2005 20:41:15 error exception in capplication::framemove()
19-10-2005 20:41:24 debug cguiwindowmusicsongs::getdirectory(q:\albums\playlists)
19-10-2005 20:41:24 debug m_vechistory = (
19-10-2005 20:41:24 debug 00.[]
19-10-2005 20:41:24 debug )
19-10-2005 20:41:24 debug fetching directory (q:\albums\playlists)
19-10-2005 20:41:24 debug 01.[q:\albums\playlists]
19-10-2005 20:41:28 debug capplication::processandstartplaylist(q:\albums\playlists\pop.m3u, 0)
19-10-2005 20:41:28 warning kernel32.dll fake function disablethreadlibrarycalls called
19-10-2005 20:41:28 info mp3codec: loaded decoder at 00ad6010
19-10-2005 20:41:28 info pap player: playing smb://xxx;xxx:xxx@xxx/xxx/blur - the best of/11-charmless man.mp3
19-10-2005 20:41:28 info activating window id: 10500
19-10-2005 20:41:28 debug paplayer: thread started
19-10-2005 20:41:28 info loading skin file: mymusicplaylist.xml
19-10-2005 20:41:28 debug playback has started
19-10-2005 20:41:28 notice start led control
19-10-2005 20:41:28 notice dim lcd on playback
19-10-2005 20:41:28 info audiodecoder: file is queued
19-10-2005 20:41:29 debug cguiinfomanager::setcurrentsong(smb://xxx;xxx:xxx@xxx/xxx/blur - the best of/11-charmless man.mp3)
19-10-2005 20:41:43 info activating window id: 10000
19-10-2005 20:41:43 info loading skin file: home.xml
19-10-2005 20:41:43 debug loadvisualisation() started
19-10-2005 20:41:43 error dll msvcp71.dll was not found in path
19-10-2005 20:41:43 error unable to load referenced dll msvcp71.dll - dll: q:\visualisations\milkdrop.vis
19-10-2005 20:41:43 warning kernel32.dll fake function disablethreadlibrarycalls called
19-10-2005 20:41:43 debug msg:loaded current preset = 0
19-10-2005 20:41:43 debug msg:preset is not held, loading a random preset. current is 0
19-10-2005 20:41:50 debug oninitialize() started
19-10-2005 20:41:50 debug oninitialize() done
19-10-2005 20:41:50 debug loadvisualisation() done
19-10-2005 20:41:52 debug freevisualisation() started
19-10-2005 20:41:52 debug freevisualisation() done
19-10-2005 20:41:52 info activating window id: 10004
19-10-2005 20:41:52 info loading skin file: settings.xml
19-10-2005 20:41:53 info activating window id: 10015
19-10-2005 20:41:53 info loading skin file: settingscategory.xml
19-10-2005 20:41:59 info loading skin file: settings.xml
19-10-2005 20:41:59 info loading skin file: home.xml
19-10-2005 20:41:59 debug loadvisualisation() started
19-10-2005 20:42:00 error dll msvcp71.dll was not found in path
19-10-2005 20:42:00 error unable to load referenced dll msvcp71.dll - dll: q:\visualisations\milkdrop.vis
19-10-2005 20:42:00 warning kernel32.dll fake function disablethreadlibrarycalls called
19-10-2005 20:42:00 debug msg:loaded current preset = 3200
19-10-2005 20:42:00 debug msg:preset is not held, loading a random preset. current is 3200
19-10-2005 20:42:03 debug oninitialize() started
19-10-2005 20:42:03 debug oninitialize() done
19-10-2005 20:42:03 debug loadvisualisation() done
19-10-2005 20:42:06 debug freevisualisation() started
19-10-2005 20:42:06 debug freevisualisation() done
19-10-2005 20:42:06 info activating window id: 10500
19-10-2005 20:42:06 info loading skin file: mymusicplaylist.xml
19-10-2005 20:42:07 warning kernel32.dll fake function disablethreadlibrarycalls called
19-10-2005 20:42:12 info loading skin file: mymusicsongs.xml
19-10-2005 20:42:13 debug cguiwindowmusicsongs::getdirectory(q:\albums\playlists)
19-10-2005 20:42:13 debug m_vechistory = (
19-10-2005 20:42:13 debug 00.[]
19-10-2005 20:42:13 debug 01.[q:\albums\playlists]
19-10-2005 20:42:13 debug )
19-10-2005 20:42:13 debug fetching directory (q:\albums\playlists)
19-10-2005 20:42:14 debug cguiwindowmusicbase::goparentfolder()
19-10-2005 20:42:14 debug m_vechistory = (
19-10-2005 20:42:14 debug 00.[]
19-10-2005 20:42:14 debug 01.[q:\albums\playlists]
19-10-2005 20:42:14 debug )
19-10-2005 20:42:14 debug cguiwindowmusicbase::goparentfolder(), strparent = []
19-10-2005 20:42:14 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 20:42:14 debug fetching directory ()
19-10-2005 20:42:16 debug cguiwindowmusicsongs::getdirectory(smb://xxx;xxx:xxx@xxx/xxx/)
19-10-2005 20:42:16 debug m_vechistory = (
19-10-2005 20:42:16 debug 00.[]
19-10-2005 20:42:16 debug )
19-10-2005 20:42:16 debug fetching directory (smb://xxx;xxx:xxx@xxx/xxx/)
19-10-2005 20:42:16 error exception in capplication::framemove()
19-10-2005 20:42:21 error exception in capplication::framemove()
19-10-2005 20:42:22 error unable to save settings to t:\settings.xml
19-10-2005 20:42:23 error unable to save settings to t:\settings.xml
19-10-2005 20:42:37 error unable to save settings to t:\settings.xml
19-10-2005 20:42:39 error unable to save settings to t:\settings.xml
19-10-2005 20:42:41 debug cguiwindowmusicsongs::getdirectory(q:\albums\playlists)
19-10-2005 20:42:41 debug m_vechistory = (
19-10-2005 20:42:41 debug 00.[]
19-10-2005 20:42:41 debug )
19-10-2005 20:42:41 debug fetching directory (q:\albums\playlists)
19-10-2005 20:42:41 error exception in capplication::framemove()
19-10-2005 20:42:44 error unable to save settings to t:\settings.xml
19-10-2005 20:42:55 error unable to save settings to t:\settings.xml
19-10-2005 20:42:56 error unable to save settings to t:\settings.xml
19-10-2005 20:43:02 debug cguiwindowmusicsongs::getdirectory(smb://xxx;xxx:xxx@xxx/xxx/kaksio-lshikuvia-2004-ser/)
19-10-2005 20:43:02 debug m_vechistory = (
19-10-2005 20:43:02 debug 00.[]
19-10-2005 20:43:02 debug )
19-10-2005 20:43:02 debug fetching directory (smb://xxx;xxx:xxx@xxx/xxx/kaksio-lshikuvia-2004-ser/)
19-10-2005 20:43:02 error exception in capplication::framemove()
19-10-2005 20:43:08 debug cguiwindowmusicbase::goparentfolder()
19-10-2005 20:43:08 debug m_vechistory = (
19-10-2005 20:43:08 debug 00.[]
19-10-2005 20:43:08 debug )
19-10-2005 20:43:08 debug cguiwindowmusicbase::goparentfolder(), strparent = []
19-10-2005 20:43:08 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 20:43:08 debug fetching directory ()
19-10-2005 20:43:08 error exception in capplication::framemove()
19-10-2005 20:43:10 debug cguiwindowmusicbase::goparentfolder()
19-10-2005 20:43:10 debug m_vechistory = (
19-10-2005 20:43:10 debug )
19-10-2005 20:43:10 debug cguiwindowmusicbase::goparentfolder(), strparent = []
19-10-2005 20:43:10 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 20:43:10 debug fetching directory ()
19-10-2005 20:43:10 error exception in capplication::framemove()
19-10-2005 20:43:13 debug cguiwindowmusicsongs::getdirectory(q:\albums\playlists)
19-10-2005 20:43:13 debug m_vechistory = (
19-10-2005 20:43:13 debug )
19-10-2005 20:43:13 debug fetching directory (q:\albums\playlists)
19-10-2005 20:43:13 error exception in capplication::framemove()
19-10-2005 20:43:17 debug cguiwindowmusicbase::goparentfolder()
19-10-2005 20:43:17 debug m_vechistory = (
19-10-2005 20:43:17 debug )
19-10-2005 20:43:17 debug cguiwindowmusicbase::goparentfolder(), strparent = []
19-10-2005 20:43:17 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 20:43:17 debug fetching directory ()
19-10-2005 20:43:17 error exception in capplication::framemove()
19-10-2005 20:43:19 debug cguiwindowmusicbase::goparentfolder()
19-10-2005 20:43:19 debug m_vechistory = (
19-10-2005 20:43:19 debug )
19-10-2005 20:43:19 debug cguiwindowmusicbase::goparentfolder(), strparent = []
19-10-2005 20:43:19 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 20:43:19 debug fetching directory ()
19-10-2005 20:43:19 error exception in capplication::framemove()
19-10-2005 20:43:20 error exception in capplication::framemove()
19-10-2005 20:43:20 error exception in capplication::render()
there is a lot of warnings about kernel32.dll - should i worry about that? and what a heck has been changed between october 2:nd and 10th releases? some (music)database? charset encoding?
i'm sorry. i forgot to mention one important detail... if you had already scanned your files, then disabling id3 tag reading wouldnt have mattered.
if the file is found in the database, then the tag information is read from there, regardless of the state of the id3 tag reading option. so, if you had scanned already, please rename your mymusic6.db file to something else as a test.
nothing really changed... i delete old database, but:
Quote:19-10-2005 21:18:52 debug freevisualisation() started
19-10-2005 21:18:52 debug freevisualisation() done
19-10-2005 21:18:52 info activating window id: 10501
19-10-2005 21:18:52 info attempting to default to:
19-10-2005 21:18:52 info loading skin file: mymusicsongs.xml
19-10-2005 21:18:53 info set page size
19-10-2005 21:18:53 info set default cache size
19-10-2005 21:18:53 info creating version table
19-10-2005 21:18:53 info create artist table
19-10-2005 21:18:53 info create album table
19-10-2005 21:18:53 info create genre table
19-10-2005 21:18:53 info create path table
19-10-2005 21:18:53 info create song table
19-10-2005 21:18:53 info create albuminfo table
19-10-2005 21:18:54 info create albuminfosong table
19-10-2005 21:18:54 info create thumb table
19-10-2005 21:18:54 info create exartistsong table
19-10-2005 21:18:54 info create extragenresong table
19-10-2005 21:18:54 info create exartistalbum table
19-10-2005 21:18:54 info create exgenrealbum table
19-10-2005 21:18:54 info create exartistsong index
19-10-2005 21:18:54 info create exgenresong index
19-10-2005 21:18:55 info create exartistalbum index
19-10-2005 21:18:55 info create exgenrealbum index
19-10-2005 21:18:55 info create album index
19-10-2005 21:18:55 info create genre index
19-10-2005 21:18:55 info create artist index
19-10-2005 21:18:55 info create path index
19-10-2005 21:18:56 info create song index
19-10-2005 21:18:56 info create song index1
19-10-2005 21:18:56 info create song index2
19-10-2005 21:18:56 info create thumb index
19-10-2005 21:18:56 info create albuminfo trigger
19-10-2005 21:18:56 info create song view
19-10-2005 21:18:56 info create album view
19-10-2005 21:18:56 debug cguiwindowmusicsongs::getdirectory()
19-10-2005 21:18:56 debug m_vechistory = (
19-10-2005 21:18:56 debug )
19-10-2005 21:18:56 debug fetching directory ()
19-10-2005 21:18:56 debug 00.[]
19-10-2005 21:18:59 debug cguiwindowmusicsongs::getdirectory(smb://xxx;xxx:xxx@xxx/xxx/)
19-10-2005 21:18:59 debug m_vechistory = (
19-10-2005 21:18:59 debug 00.[]
19-10-2005 21:18:59 debug )
19-10-2005 21:18:59 debug fetching directory (smb://xxx;xxx:xxx@xxx/xxx/)
19-10-2005 21:19:01 error exception in capplication::framemove()
19-10-2005 21:19:40 error exception in capplication::framemove()
19-10-2005 21:19:52 debug cguiwindowmusicsongs::getdirectory(q:\albums\playlists)
19-10-2005 21:19:52 debug m_vechistory = (
19-10-2005 21:19:52 debug 00.[]
19-10-2005 21:19:52 debug )
19-10-2005 21:19:52 debug fetching directory (q:\albums\playlists)
19-10-2005 21:19:52 error exception in capplication::framemove()
19-10-2005 21:19:55 error exception in capplication::framemove()
19-10-2005 21:19:55 error exception in capplication::render()
when i first time choose my smb share i see blank list. i have to chage (default value) view: list to another, view: icons. after that i see all folders and playlists i have on my smb share, but if i try to play a playlist i have a lockup.
:veryangry: damn, this is frustrating...
its wierd that you dont see anything until you change your view. i've never seen that before.
now you've changed the situation a little. before you said you couldnt get into your share. now you can, but the lockup occurs when you play the playlist. this leads me to believe that theres some issue with tag attached to the first file in that playlist.
i forgot another thing... whenever a music file is played, the tag information is read from that file. this allows the music overlay to be populated even if id3 tag reading is disabled.
if you're so frustrated switch back to the official 1.1.0 version. the cvs is a constantly changing playground of development. if you want stability, dont use cvs. its as simple as that.
Confusedleep:
okay.. this is what i got..
after checking all the folders i found the one that is causing the troubles. ofcourse it was one of the last folders i did check... :veryangry:
anyway,
my complete music collection now works in the library artist view if i remove this folder before scanning. placing the folder back and scan again will cause lockup's again so i removed that folder permanent from the shared folder.
the corrupt folder is called: tv themes and contains about 105 famous tv tunes. the strange part is; when i look deeper into the mp3 tags, i cannot find anything strange at first point. no rare symbols whatsoever.(and i am to tired to try all the files one by one in xbmx.)
so you have any clues for me what to look for?
should i look into the file names or just the tags?
some artist names are written between: (artist) symbols
could that be a problem?
or what information do you need from this files to discover the problem?
pimpandoer...
heh... its always the last one Smile
be sure to also check for any apev2 tags. for mp3's, the tag order is apev2, id3v2, last id3v1. i've seen several situation of users complaining that incorrect information was being displayed and it was because they didnt realize that their files had apev2 tags in them.
yes, i guess it *could* be the filename too. that can be tested by disabling id3 tag reading and browsing to the folder. if it doesnt freeze, then its not the filenames. (just make sure that these files are not in the database.)
and what do you mean by "(artist) symbols" ?
ok - my problem was playlist... i removed all m3u-playlist from smb share and xbmc-cache. all works now fine. i even scanned id3-tags from smb share and no troubles.
i really don't understand what was wrong in my playlists... i went through them and removed all "illegal characters" from playlists and song names.
next i have to try create new playlist and try that...
if you didnt delete the playlists, please email them to me. my email is earlier in the thread.
okay,
i will try the things you did describe above and will let you know. with (artist) i mean that some names are between () symbols. (i don;t know the english word for "()" symbols )
i will let you know soon.
kraqh3d noticed this from my m3u playlist:
Quote:actually a few of them are incomplete. looking at the extinfo tags, i
see the problem. its gotta be something with the charset converter.
"moottoripyörä on moottoripyörä.mp3" gets converted into
"moottoripyã¶r㤠on moottoripyã¶rã¤"
it looks like ö is getting munged into ã¶, and ä is getting munged into ã¤.
xbmc changelog has few recent lines about charset:
Quote:09-10-2005 fixed: charset converter may waste a byte here and there when converting
11-09-2005 fixed: charset conversion from id3 tags was wrong
and because october 2nd release works and october 10th doesn't...?
i updated the xbmc version to the latest available build..(10-28-2005 pimped) rewrote the xml... deleted the saves.. and it hangs again
so here's part of the log i grabbed from the xbox:
29-10-2005 18:34:26 notice kaiclient: discovering kai engine via udp broadcast.
29-10-2005 18:34:26 notice initialize done
29-10-2005 18:34:26 notice running the application...
29-10-2005 18:34:27 warning kernel32.dll fake function disablethreadlibrarycalls called
29-10-2005 18:34:33 warning kernel32.dll fake function disablethreadlibrarycalls called
29-10-2005 18:34:42 error server returned: 301 moved permanently
29-10-2005 18:34:43 error server returned: 301 moved permanently
29-10-2005 18:34:44 error exception in capplication::framemove()
29-10-2005 18:35:04 error exception in capplication::render()
29-10-2005 18:35:04 error capplication::render(), too many exceptions
29-10-2005 18:35:04 fatal exception_access_violation (0xc0000005)
at 0x00176e79
also i took a screenshot to show point of death the machine doesn't just freeze it gives me the time to take 2-3 screenshots before it completely hangs
the file count got updated and then it stopped responding... :veryangry:
its related to this problem:
http://www.xboxmediaplayer.de/cgi-bin....t=16237
there are some characters present which are xbmc doesnt like. only solution at the moment is not to use that m3u file.
Pages: 1 2 3 4 5
