Hi there,
i have a little problem that i can't seem to fix as i am not an expert.
Generally the audio flags show up when i am browsing through my movies in showcase viewtype. But they don't refresh. They only show up when i am in movie information view. Back to library they stay the same for every movie. When I go to movie information view of another movie the refresh again. What can i do?
Edit: Problem solved
How and where did you run the script? Which skin?
I use Aeon Nox and for all my movies with french audio or french subtitles the french flag doesn't show. As far as I looked it works fine with english, spanish and german. Any idea how I could resolve that if it's not a bug ?
PS: maybe worth-noting I'm french so I guess most of my movies will have the french audio or subtitles noted as "français" but it's recognized by XBMC without any troubles.
Ask in the Nox thread... I guess there's simply the image missing (fra.png).
Thanks, I'll have a look at that.
Edit: Yes, it was simply that. Thanks a lot.
`Black, when will submit that version to the repo?
Did it just now, should be available soon.
Thank you. I did not find any problem in this version, just so you know.
@'Black
It doesn't pick up locally stored subtitles based on system setting preferred subtitle language right?
Do you think it's possible to add such maybe let the end user chose from config?
The easiest way would be if XBMC could pick up local subtitles while scanning and adding them to the stream details. I won't add a check for local files because that's too slow and would need an extra db.
Is this script available in official repository? I have a problem finding it.
(2013-03-25, 21:09)Marx1 Wrote: [ -> ]Is this script available in official repository? I have a problem finding it.
This won't work without coded into a skin.
Skin I use supports it (confluence modified) but don't provide it, I just can't find it in plugins section. I must be missing something simple.
(2013-03-25, 22:19)Marx1 Wrote: [ -> ]Skin I use supports it (confluence modified) but don't provide it, I just don't understand how to instal script.
Download it from location mentioned and install from .zip
