I ran it and it seemed to work. It cached more than 14k items (mainly thumbs) and only showed 49 errors (also mainly thumbs).
However, my issue is not addressed yet. I am using Kodi as UPNP server for music. Unfortunately, Kodi only serves the albumart of albums that I have actually viewed in the Kodi interface. No idea what information is generated when the album is viewed, but this must be different than what the texture maintenance utility does. After running, still not all albumart is available over UPNP.
Very easy to replicate by trying to access Kodi music library via UPNP on VLC (IOS).
Any idea how this could be solved?
Can you run "texturecache.py jd albums <albumname>" on the client you are using to access your UPNP content (where <albumname> is the name of an album you access using UPNP) and paste the results.
Thanks for your quick reply. Unfortunately, my UPNP client is on an iphone. I tried two different clients (VLC for IOS and Glider) and result is consistent. When then hovering on the album in Kodi (in WIn 10) and re-opening the same album on my VLC client, the albuart shows up. The issue is replicable for me.
Ah OK. So you've cached all the album artwork on the "server". Make sure it's not embedded artwork using mp3 tags (artwork urls will start with "music://") as it's not possible to preload the cache with embedded artwork as they require a GUI process to extract the artwork from the music files (ie. you must view embedded artwork in the GUI in order to cache them). Assuming its not embedded and all artwork is now present in the texture cache on the server, then if artwork isn't being displayed on the client this is a UPNP issue you should talk to @
Montellese about (I see you've already found his
UPNP thread).
Thanks. Got the issue then. It is indeed embedded artwork in MP3 tags. Would it solve my issue to extract the coverart? There are tools doing so, right?
Yup, I also posted in the UPNP thread, but on a separate topic. Would also be great to hear if you have a thought on this.
(2017-07-09, 16:02)steve1977 Wrote: [ -> ]Thanks. Got the issue then. It is indeed embedded artwork in MP3 tags. Would it solve my issue to extract the coverart? There are tools doing so, right?
If you were to place the extracted cover art alongside the music files (ie. in the album folder, assuming this is how you have your albums organised) with the cover artwork called "cover.jpg" then that would work, and the cache could be pre-loaded with your cover art, although you'd need to re-scrape your music in order for Kodi to use the local cover.jpg. Not entirely sure whether Kodi "prefers" local artwork to embedded artwork - you may want to test this with one album first.
I'm not aware of any tools to automate extraction of embedded artwork.
Thanks. Was just trying to use the purge feature to delete all cache and start from scratch (using c for rebuild). Somehow, I cannot get the purge feature to work though. I tried both "texturecache.py purge" and "texturecache.py purge all", but both did not work. Any thoughts?
If you want to delete the entire texture cache the quickest way is to delete Textures13.db and the Thumbnails folder.
The "purge" command is intended for the mass deletion of artwork that matches the specific criteria, ie. "texturecache.py purge all
https://i.ytimg.com" would remove all the images cached by the YouTube addon as the artwork urls for this addon all start with "https://i.ytimg.com".
I had an issue today with a band concert DVD that I created a MKV file out of. I did it when the DVD was first released so there may not have been an entry in the movie scraper at the time, and I have scanned the library probably 20 times since then and the file has never shown up in my library.
Today I manually navigated to the file, Settings > media > library > videos > video > [selected file] > information > refresh
Then all the information and artwork were downloaded, and it was finally added to my video library. It was pretty involved and I would think a vscan should have caught it in the last few months, but it never did. I add things and run vscan all the time.
Is there a texturecache command that will look for files not currently in the DB/library or specifically excluded and try to update and add them?
Try "texturecache.py missing movies <source-name>", this will list those files in your source that are not in the library.
There's no way way to force Kodi to detect a file that the video library scan is not detecting. This is often due to the "fast hash" algorithm not detecting that the new file has been added and is a particular issue when the exFAT filesystem is used. There's a "usefasthash" advanced setting to work around this issue:
http://kodi.wiki/view/AdvancedSettings.xml#videolibrary
I got a list of a few files, thank you, this is also from a remote NTFS filesystem, not exfat.
I tried the same for audio/music, but am getting an error, what would the proper command be?
i.e. # texturecache.py missing music Music <Music> is my source name
ERROR: music is not a valid media class
ERROR: audio is not a valid media class
@J_E_F_F: texturecache.py missing songs Music
thanks, never would have thought of songs lol
