2014-08-31, 06:30
2014-11-11, 02:41
I seem to have found a Windows-specific python error that's going on with this addon.
If I try adding a channel to my channels in OSX, I get this log.
http://xbmclogs.com/show.php?id=347375
As far as I can tell, it starts adding the channel at line 959 and works great.
If I try adding a channel to my channels in Windows8.1, I get this log.
http://xbmclogs.com/show.php?id=347368
The error happens at line 1225.
This only happens when I try to add a channel. If I just do a search for a channel, enter the channel, and watch shows from the channel, it works great.
18:27:40 T:9688 DEBUG: CPythonInvoker(9, C:\Users\njbetzen.xbmc-nate\AppData\Roaming\Kodi\addons\plugin.video.youtube.channels\default.py): instantiating addon using automatically obtained id of "plugin.video.youtube.channels" dependent on version 2.1.0 of the xbmc.python api
18:27:40 T:9688 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: internal error in regular expression engine
File "C:\Users\njbetzen.xbmc-nate\AppData\Roaming\Kodi\addons\plugin.video.youtube.channels\default.py", line 516, in <module>
addChannel(url)
File "C:\Users\njbetzen.xbmc-nate\AppData\Roaming\Kodi\addons\plugin.video.youtube.channels\default.py", line 228, in addChannel
match=re.compile('(.+?)#(.+?)#(.+?)#', re.DOTALL).findall(args)
RuntimeError: internal error in regular expression engine
18:27:40 T:9688 INFO: Python script stopped
2014-11-19, 02:10
(2014-11-11, 02:41)natethomas Wrote: [ -> ]I seem to have found a Windows-specific python error that's going on with this addon.
I think this is the problem:
http://trac.xbmc.org/ticket/15553
2014-11-20, 07:51
Cheers, DrySoup. Your solution given at that link works perfectly. Thanks a lot.
2014-11-21, 07:12
Nice work everyone. The fix has been merged into master. With the next Kodi release everything should be working great again.
2014-12-04, 04:04
Is it normal that the channel contents will not update unless RaspBMC is rebooted?
2014-12-07, 19:55
I just found this plugin and it is just what I have been looking for, thank you! I have a question though, I'm running the plugin on Gotham 13.2 on the ATV1 with Crystalbuntu (OSMC) and I don't see an option anywhere, to add a channel to "My Channels". I can search, find and play videos on many of my favorite channels, but I cannot seem to find a way to save them for later viewing. Any thoughts? I am also a developer and would be happy to help fix this if it is an issue.
2014-12-07, 21:05
Saving channels is in the context menu.
2014-12-07, 21:51
Thank you, I was confusing the context menu and the side menu . Holding menu on the Apple TV remote did the trick.
2015-05-10, 07:08
Add-on stopped working about 3 days ago for me. When I visit a channel the only video that will pop up is one with text about device support. Anyone else getting this?
2015-05-10, 07:21
Yup same here. I believe we have to switch over to the add-on by bromix
http://forum.kodi.tv/showthread.php?tid=200735
2015-05-10, 07:27
More info about the need to move to the new version by bromix in this post
http://forum.kodi.tv/showthread.php?tid=...pid1998442
"Update, 2015-05-08: As some of you may have noticed, applications using gdata calls only return the device support video by now. This means that both Youtube Channels and our Youtube 4.4.10 can now be considered as obsolete."
2015-05-11, 07:45
(2015-05-11, 02:47)Azanura Wrote: [ -> ]I made a patch some days ago. It's available here.I suggest at least to use your own API key and not to put the one from YouTube TV in jeopardy. This KEY is for APIv1 (internal) only. I hope they don't change things based on this 'patch' and we get a problem with the other YouTube add-on with the login or the 'My subscription' fix.
2015-05-16, 16:46
